Re: KV Fuel Hoses Vendor
[Re: mccannix]
#1540916
02/17/14 01:42 PM
02/17/14 01:42 PM
Posts: 768 Dry Heat AZ
AAR#2
Dry Heat AZ
Found these fuel filter shorties some time back at a Mopar Parts Supplier inventory where they had sat since the 70's.
Are you completly sure about that? I'm having issues trying to enlarge the photo and remain clear but the lettering does not seem to match that of samples I've seen from early 70's production.
[Re: AAR#2]
#1540917
02/17/14 02:57 PM
02/17/14 02:57 PM
Posts: 4,784 Ontario, Canada
mccannix
Ontario, Canada
Well they were close enough for Dave from ECS as they are shown here on his site. http://www.ecsautomotive.com/productdesc.php?co=c&id=60 Dave purchased them from me several years ago. Here's a picture of one of some singles I have left.
[Re: mccannix]
#1540918
02/18/14 12:18 AM
02/18/14 12:18 AM
AAR#2
Dry Heat AZ
I'll chalk it up to a blurry image on the first photo, but certainly the last photo looks legit
[Re: ScottSmith_Harms]
#1540921
02/18/14 02:37 AM
02/18/14 02:37 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
so what would be better a repo that you can read, or a unreadable original. I had the ends of the pressure line re plated.
If you are shooting for O.E. correct, the faded original would be "more correct" (IMO, results may vary depending on the judging body), also, you could lose points for pitting or a non original plating color etc. that is evident on your original parts, but I'd still lean towards that scenario as opposed to a reproduction.
[Re: 71birdJ68]
#1540923
02/18/14 11:19 AM
02/18/14 11:19 AM
Our 69 GTX still has its original power steering pressure line and the rubber is in great shape. The stamped lettering on it is very faded and almost not able to be read. The gold cad metal ends on it still has some of the plating left but we are going to send it out to have it replated since the plating is almost totally gone on one end and very little left on the other end. I, too, would love to find a way to get the yellow lettering back onto the rubber part of the hose though.
[Re: gtx6970]
#1540924
02/18/14 03:27 PM
02/18/14 03:27 PM
Posts: 12,432 Warren, MI
71TA
Warren, MI
Bill, Restoration Specialties in In Windber PA?
Yes, they bought out / took over all aspects of QQE
another one you may try is http://www.deadnutson.com/page/page/2526992.htm
He is not just mustang stuff. As an FYI, He supplies Frank Badalson / Roger Gibson with his hose
That Dead Nuts guy makes some incredible pieces. He's not afraid to charge for them either.
Brake Booster Hose writeup from his site
The Story Behind the Hose
After discovering Marti Autoworks and other Mustang parts supplier didn't make this hose I checked with Ed Meyer. Ed told me the Mopar guys did a poor reproduction of this hose but it was all that was available. I ordered one for my car anyway then compared it to some of my originals. The reproductions ink color was wrong, the font type was way off, the date code wasn’t smaller than the rest of the type and the printing method was modern. I then decided to reproduce the hose to my standards. After a year of work I’m finally happy with the results. The yellow ink color was custom mixed to get it just right. Each letter needed to be custom made to match originals since the font they used on the originals is not available. The date codes are a smaller size so they also had to be made one letter at time. Modern rubber hose printing equipment failed to get the right look so I custom made a hose printer and process that replicated the manufactures original process. I ended up with brake booster hose that looks Dead Nuts On to me.
