Page 2 of 3 1 2 3
Re: KV Fuel Hoses Vendor [Re: ScottSmith_Harms] #1540889
11/29/13 01:54 PM
11/29/13 01:54 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Bill, Restoration Specialties in In Windber PA?
Yes, they bought out / took over all aspects of QQE
another one you may try is
http://www.deadnutson.com/page/page/2526992.htm
He is not just mustang stuff.
As an FYI, He supplies Frank Badalson / Roger Gibson with his hose
Re: KV Fuel Hoses Vendor [Re: ScottSmith_Harms] #1540890
11/29/13 06:27 PM
11/29/13 06:27 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Scott, can you put the markings on a power steering hose? My originals are good, just can't read the lettering.
Re: KV Fuel Hoses Vendor [Re: 71birdJ68] #1540891
11/29/13 08:47 PM
11/29/13 08:47 PM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
I can't put markings on anything....Yet. I'm working on it though!
Re: KV Fuel Hoses Vendor [Re: ScottSmith_Harms] #1540892
02/16/14 04:16 AM
02/16/14 04:16 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Sorry for digging up an old thread but has anyone else seen a mix of lines. I have an early March build AAR, all original clamps in place, soft line fwd (engine bay side) is EB and carries a D10319 marking as well. The soft line at the back is the KV line.
From the looks of this thread if I need EB line I'll be making it.
Re: KV Fuel Hoses Vendor [Re: AAR#2] #1540893
02/16/14 12:13 PM
02/16/14 12:13 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Can you post pics of your originals?
Re: KV Fuel Hoses Vendor [Re: ScottSmith_Harms] #1540894
02/16/14 02:11 PM
02/16/14 02:11 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Sure, heres the front line
Re: KV Fuel Hoses Vendor [Re: AAR#2] #1540895
02/16/14 02:12 PM
02/16/14 02:12 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
And heres the rear
Re: KV Fuel Hoses Vendor [Re: AAR#2] #1540896
02/16/14 02:21 PM
02/16/14 02:21 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, looks OEM alright. EB seemed to have been phased out after 1969/70, I haven't seen any sources for it to date. I'm working on getting it and others properly reproduced but it's a challenge for sure and will be a while.
There are a lot of reproduction rubber hoses and lines out now (for most applications) that compared originals, aren't even close! It's an area of O.E. restoration detail that needs A LOT of improvement
Re: KV Fuel Hoses Vendor [Re: ScottSmith_Harms] #1540897
02/16/14 03:29 PM
02/16/14 03:29 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Totally agree, most of the KV hose markings I've seen the "K" isn't even in the ballpark.
I may have to see what I can do to replicate it myself, a difficult task, but if I have to do the EB line, It'll just be another marking.
So have you ever seen where the hose on the front and back don't match?
Hard to believe I got the very last section of EB and they were forced to use KV in the back.
Re: KV Fuel Hoses Vendor [Re: AAR#2] #1540898
02/16/14 05:20 PM
02/16/14 05:20 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
No, haven't seen that but there was certainly some mixed inventory, afterall, it was just a rubber fuel line built to spec, didn't matter who supplied it. Also, some items were delivered to the assembly line with the rubber fuel lines already attached (fuel filters, etc.) so there may have been source differentials depending on the item and the vendor.
Re: KV Fuel Hoses Vendor [Re: ScottSmith_Harms] #1540899
02/16/14 05:27 PM
02/16/14 05:27 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
How many times have you heard that the reason old lines have such faded looking ink stamps on the lines because of age/heat/wear, etc.? Here's the same one on that filter, been in the dark since forever, it's NOT faded, it looked that way when new.
Re: KV Fuel Hoses Vendor [Re: ScottSmith_Harms] #1540900
02/16/14 05:42 PM
02/16/14 05:42 PM
Scott,
Remember our 69 GTX vert that has a SPO date of 10/3/68 had the EB fuel lines up front and the KV in the back too. Seems that they were using it in late 68 also.
Re: KV Fuel Hoses Vendor [Re: ] #1540901
02/16/14 06:25 PM
02/16/14 06:25 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, like most everything, there was vendor supply overlap. Sometimes 3 or more vendors supplied the same line, same thing happens in todays manufacturing world. I have seen MOSTLY EB lines on pre 1970 cars, I cant say when KV products hit Mopar but I I'm guessing by what I've seen it was 1968 or so.
Re: KV Fuel Hoses Vendor [Re: ScottSmith_Harms] #1540902
02/16/14 11:46 PM
02/16/14 11:46 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
Awhile back I bought some dayco or thermoid emissions hose at the local parts store.
It said SAE 30R7 KX in the same font and size as the original KV marked hose I was replacing on my 79 B-van.
I know 30R7 is the SAE rating of the hose (not for fuel injection) but the KX part caught my attention…
Re: KV Fuel Hoses Vendor [Re: 135sohc] #1540903
02/17/14 01:13 AM
02/17/14 01:13 AM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
Hey Scott,
All the repo KV hose is made by a hot stamping machine, originally of course it was printed on a rotary dial machine.
I always had rubber stamps made and used an ink that was diluted slightly.
I have found a lot of variations on hoses used, from plant to plant especially.
Here are a few pics. As you can see, some have dates, most do not.
Re: KV Fuel Hoses Vendor [Re: Paul Jacobs] #1540904
02/17/14 01:14 AM
02/17/14 01:14 AM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
EB 1
Re: KV Fuel Hoses Vendor [Re: Paul Jacobs] #1540905
02/17/14 01:15 AM
02/17/14 01:15 AM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
EB with date
Re: KV Fuel Hoses Vendor [Re: Paul Jacobs] #1540906
02/17/14 01:16 AM
02/17/14 01:16 AM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
KV PCV-69 car
As you can see, Gates wasn't the only PCV hose out there
Re: KV Fuel Hoses Vendor [Re: Paul Jacobs] #1540907
02/17/14 01:18 AM
02/17/14 01:18 AM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
Another style Gates PCV hose
Re: KV Fuel Hoses Vendor [Re: Paul Jacobs] #1540908
02/17/14 01:19 AM
02/17/14 01:19 AM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
more
Page 2 of 3 1 2 3
