Re: Return line fuel system?
[Re: Thumperdart]
#1540719
11/28/13 10:47 PM
11/28/13 10:47 PM
Posts: 354 Livonia Michigan
440dart
Livonia Michigan
I run a BG 250 pump, on a street car. this is the way I was told to run the return line. Before the return system was installed, the pump allways sounded like it was laboring, and very loud. Now with the return, you almost can't here it with the engine running. It holds a constant 7 lbs.
Yes I live in Michigan, so there is still 1 light on
[Re: 440dart]
#1540722
11/28/13 11:05 PM
11/28/13 11:05 PM
Quicktree
2nd. pic.
is that a dead head regulator used as a return?
[Re: Quicktree]
#1540724
11/29/13 01:41 AM
11/29/13 01:41 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
2nd. pic.
No , it's a bypass. I have the same one.
[Re: 440dart]
#1540725
11/29/13 10:26 AM
11/29/13 10:26 AM
Challenger 1
Cincinnati, Ohio
2nd. pic.
I see low flow steel hydraulic fittings, should use tube 90,60, 45s on fuel systems. Also notice the settings are weird. Also I would not run the gauge during normal running. Just used it to set it up and then take out and plug it. It won't live like that.
[Re: 440dart]
#1540726
11/29/13 10:29 AM
11/29/13 10:29 AM
Challenger 1
Cincinnati, Ohio
A regulator, bypass etc should never be mounted solid to the motor, because vibration will unset the regulator and cause cracks in your fittings hanging on the end like that...if you make power.
[Re: Quicktree]
#1540727
11/29/13 01:25 PM
11/29/13 01:25 PM
Posts: 8,165 Left Coast
BobR
Left Coast
2nd. pic.
It's a return style regulator. 440Dart is my brother.
[Re: Challenger 1]
#1540728
11/29/13 01:27 PM
11/29/13 01:27 PM
BobR
Left Coast
That motor makes about 700 HP. You may be right about the solid mounting but it's been that way for 4+ years. He's had zero issues and he drives it on the street pretty regularly.
[Re: BobR]
#1540729
11/29/13 02:35 PM
11/29/13 02:35 PM
Posts: 1,019 Finland
mafo
Finland
I use a slightly different setup, cant say if it s better or not but it seems to work ![](http://www.product-engr.com/images/PE_9500.gif)
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: SLOW67]
#1540731
11/29/13 10:50 PM
11/29/13 10:50 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Mine currently has a Mallory 4309 reg. that is boost referenced and a 3/8 feed and return to the tank, with a walbro 190 pump. It just dumps back in the top of the cell but I do have foam in it. Right now it is all plumbed in 3/8 fuel injection hose so NHRA frowns on that plus its a safety item too I suppose. I wanted to simplify it and upgrade the line at the same time but I guess I'll just buy twice the material and put it back the way it is.
Are you saying its all rubber hose... change that out and run tubing ![](/ubbthreads/images/graemlins/wave.gif)
