Re: Building a 440 with low compression pistons.. opinions.
[Re: BSB67]
#153984
11/22/08 03:44 PM
11/22/08 03:44 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
If you have them, and your goal is 400 hp thru manifolds, then use them. You can't use a flat top to get good quench, or a compression ratio that will be pump fuel friendly and idle smooth. If you were looking for more power, ther are things to do to combat that, but it's not worth doing for your goals. The best two options are to run a KB hyper quench dome, or a flat top with a 452/906 style open chamber head... Or, spring for a dished forged piston. I'd just build it for the low compression and enjoy it.
[Re: dogdays]
#153987
11/23/08 01:09 PM
11/23/08 01:09 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
How about a set of aftermarket Hemi length rods? R.
That would work once you get the pin sized sorted out , but then you run into another issue , potential piston to valve clearance since there is no valve relief .
Pistons would be the cheaper route , or he can just ignore the ramblings and build what he has ????
[Re: JohnRR]
#153988
11/23/08 02:30 PM
11/23/08 02:30 PM
Posts: 1,072 The Sunny Shuswap
dodgefarmer
The Sunny Shuswap
Those pistons will more or less give you a factory stock compression ht. for that engine. The engine will need a balance as that piston is approx. 30gr. heavier than oem. IMHO this is the way to go for a nom. 67 R/T.
Randy
[Re: dodgefarmer]
#153989
11/23/08 04:44 PM
11/23/08 04:44 PM
Posts: 3,691 MO
cdp
MO
Mopar Muscle did a Resto 440 Build-up, (march/april 2001) and used the 2266 pistons on a stock 69-HP rebuild. They decked the block (.020) to compensate for the thicker Felpro Blue gaskets. Piston-in-the-whole was .069.
They got 357HP with stock cam, 906 heads, avs carb, etc.
By the time they added headers, changed out carb and intake Holley's, they got 420 hp still with the stock cam.
464HP with a 274H cam, roller rockers, and good push rods.
I don't think the 2266 pistons are going to hurt you any.
