Re: dash "suede" paint ??
[Re: FJR doc]
#1538664
11/26/13 01:23 AM
11/26/13 01:23 AM
Posts: 6,020 Salem
Grizzly
Moparts Proctologist
Salem
That looks awesome, FJR doc. ![](/ubbthreads/images/graemlins/drool5.gif) And $65.00? Well done. ![](/ubbthreads/images/graemlins/bow.gif) Gonna write that one down in my little resto notebook, thanks for the tip. ![](/ubbthreads/images/graemlins/beer.gif)
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#1538665
11/26/13 03:07 PM
11/26/13 03:07 PM
Posts: 6,585 SE Pa.
LimeliteAero
SE Pa.
YUP!
That looks AWESOME! Nice job!
[Re: demon]
#1538668
11/26/13 11:18 PM
11/26/13 11:18 PM
Posts: 628 Mass
Mike Mancini
Mass
Hi Guys,
Just to clarify...The stuff we sell is the real deal. I bought out an old PPG jobber local to my town that had boxes and boxes of unopened bases,toners and additives dating from the 50's-70's. The paint shop closed in 1979, so nothing is newer than that.
We are very low on the additive, we have sold it to many many people over the last few years, but its about gone.
If you are getting too much gloss or too rough texture, it is most definately an application issue. If you use too much pressure it will make the additive stand up causing a rougher finish. If you spray it too wet and don't allow enough time between coats, it will gloss up. The key is light coats, low pressure to get the perfect suede "fuzzy" feeling.
Any original sample is not really a perfect reference due to the way lacquer breaks down and degrades simply with time, not to mention other outside forces.
Any questions, please call the shop. 401-267-0055
Thanks Mike
[Re: FJR doc]
#1538669
11/26/13 11:33 PM
11/26/13 11:33 PM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
Is your dash black? If so, I tried various paints but eventually went with powder coating. I felt that the Tiger black matte fine texture was an exact match to my original dash frame. My local coater blasted and coated my frame, glove box door and ash tray door for $65. It looks sexy!
I too did powdercoating, dash, steering column, ash tray for less than $100, finish is perfect and way more durable than paint, I have no clue why people mess with a paint that is a crapshoot at best
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
[Re: MOPARMIKE69]
#1538672
11/27/13 10:57 AM
11/27/13 10:57 AM
Posts: 3,060 Western New York
sixpackbee
Western New York
I also used Mikes stuff on the Daytona just recently and had good results. You can't spray it like you would outside panels for a good finish.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
[Re: Mike Mancini]
#1538673
11/27/13 12:00 PM
11/27/13 12:00 PM
Posts: 892 MA
steve70
MA
Hi Guys,
Thanks Mike
I was just at Mike's shop to drop off a gauge cluster for restoration and got to see a few complete dash's that were ready to be shipped out. The complete assemblies that I saw were absolutely beautiful and the texture looked perfect.
1970 Challenger T/A 4 speed
[Re: Mike Mancini]
#1538676
11/27/13 02:38 PM
11/27/13 02:38 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Hi Guys,
Thanks Mike
Thanks for posting Mike, as I said, it might have been an application technique issue and not your product. I still have leftover paint and a couple dashes to shoot, could you offer some tips on getting it right so I don't waste more material? Specific gun pressure, room temperature, spray distance, etc. that might help? ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Stanton]
#1538678
11/27/13 03:30 PM
11/27/13 03:30 PM
AZ_A12_BEE
Dreaming of the 808
Get the paint wrong - easily strip it off and redo it. Get the powder wrong and its a whole different ballgame!
I my case and probably others as well, there is rust in the top corners which is not severe enough to cut out but enough to need a skim coat of bondo. This means powder is not an option as it won't adhere to the bondo. Also, doing an ashtray you only want the door done, not the tray itself. Unless you pop it apart and re-rivet it you're pretty much dinked there as well.
Not true in the ash tray, they just mask it off with special high temp tape.
My metal is perfect so powdercoating is the ticket, if my was rusty and had bondo I too would have had to use paint.
37 Plymouth PU
[Re: AZ_A12_BEE]
#1538679
11/27/13 03:44 PM
11/27/13 03:44 PM
Posts: 2,637 Nashville, TN
MOPARMIKE69
Nashville, TN
AZ A12 Bee I would love to see an up close side shot of your dash.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
