Re: Mini-tubbed B body racers tire/wheel question?
[Re: HemiDart68]
#1537685
11/21/13 01:42 PM
11/21/13 01:42 PM
Triple Threat
Renton Washington
Find a tire with a stiff sidewall and run tubes if you can. You sidewalls will last longer. If my tires only lasted 30 runs i'd be in the poor house.
[Re: HemiDart68]
#1537686
11/21/13 01:51 PM
11/21/13 01:51 PM
Posts: 681 COLUMBUS, OH
Whompin_Wedge
COLUMBUS, OH
Is anyone using a 14 in. wheel/tire combination in a mini-tubbed B body? I am currently using a 12 in Centerline Autodrag wheel with a Goodyear 31/14.0.15 slick.I have no problems with clearance but I wear out my sidewalls quickly(30 passes). I have been told that going to a 14 in wheel would give me a flatter footprint as well as allowing more tire pressure which would save the sidewalls. They do make a 32 in. stiff sidewall Goodyear but I don't think that will fit. I don't want to waste money buying the 14. in Centerline($300 EACH) to find out. I saw in an earlier post that the Percy tool could give me a good idea if the tire/wheel will fit but there is nothing better than having someone who is already doing this let me know. Thanks Mike
I would consider using a 10.5W on your existing wheel. You will get a nice footprint with your existing 12 inch room. 14 would be hard to pull off on a mini tub car.
I would suggest the 10.5W as well
Casey
[Re: Triple Threat]
#1537687
11/21/13 02:27 PM
11/21/13 02:27 PM
Posts: 1,301 Penna
70satelliteguy
Penna
"Find a tire with a stiff sidewall and run tubes if you can. You sidewalls will last longer. " I should have mentioned that I do run tubes. Goodyear does not make a stiff sidewall in the 31/14.0.15 slick. "If my tires only lasted 30 runs i'd be in the poor house." That is why I am trying to find a solution to my problem Do you think a 10.5W is enough for 900 HP A3600 lbs.? Thanks Mike
[Re: 70satelliteguy]
#1537689
11/21/13 08:13 PM
11/21/13 08:13 PM
Posts: 9,871 MI, usa
dvw
MI, usa
I run consistent mid 9.30@146, 3345lbs, with 10.5W31 on a 10"rim w/o tubes. Been 9.25@147.6. Still same 60 after 90 passes. Low 1.30s with no spin on a foot brake. Doug
[Re: dvw]
#1537690
11/21/13 08:31 PM
11/21/13 08:31 PM
Posts: 1,301 Penna
70satelliteguy
Penna
"I run consistent mid 9.30@146, 3345lbs, with 10.5W31 on a 10"rim w/o tubes. Been 9.25@147.6. Still same 60 after 90 passes. Low 1.30s with no spin on a foot brake." Maybe I should not be afraid of going to a smaller tire to solve my problem Thanks Mike
