Re: Fuel pump for NOS [Re: Leon441] #1537363
11/20/13 08:44 PM
11/20/13 08:44 PM
Toronto
mshred Offline
mshred  Offline
Toronto
I have used a holley black copy cat pump with -10 to the pump, -8 to the regs (2 holley 12-803's, one for motor one for nitrous), -6 to the carb bowls and fuel noid...I ran a 125 and 150 shot, with 5.5psi fuel pressure flowing through a 73 holley jet, and I had no fuel pressure issues at all going down track.
That said, I am thinking of upgrading my pump over the winter to have the extra insurance on spray...maybe even a separate fuel cell if im really feeling the addiction lol
Re: Fuel pump for NOS [Re: Biginchmopar] #1537364
11/20/13 08:44 PM
11/20/13 08:44 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Ignition:
Re: Fuel pump for NOS [Re: Biginchmopar] #1537365
11/20/13 09:22 PM
11/20/13 09:22 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Jeff are you going to run both the giggle juice and your meth injection?
Re: Fuel pump for NOS [Re: Leon441] #1537366
11/20/13 09:24 PM
11/20/13 09:24 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Thanks Leon...
You really could use more pump. Sense we do not know how much power the car has on motor or how hard it hooks it's hard to say how much pump you really need.
not hooking well right now 1.60-1.70 will be adding cal-tracs or SS springs. I'm hoping for 1.55's w/o the N2O
How much your car can MPH now in the 1/8 or 1/4 would give us some idea what kind of HP you really have.
Car runs 7.30's in the 1/8 and 11.40's (thru the mufflers) @ 119.8 in the 1/4
It has a fuel cell w/ a sump if that matters.
Re: Fuel pump for NOS [Re: GTX MATT] #1537367
11/20/13 09:26 PM
11/20/13 09:26 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
yes unless I hear it's not a good idea. and it's meth/water, (washer fluid) not straight meth
Re: Fuel pump for NOS [Re: Mr.Yuck] #1537368
11/20/13 10:04 PM
11/20/13 10:04 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Not stating this from my own experience as I've never played with nitrous, just what I've read/heard, but it should allow you to not have to pull as much timing (if any), but I'd be careful and retard it plenty to be safe. I just thought I'd mention it since it may be something of importance to someone helping you out with the fuel system.
Make sure you buy the cheap washer fluid that doesn't have the other junk mixed in. IMO you'd be safer with a true 50/50 mix of meth and water though.
Re: Fuel pump for NOS [Re: GTX MATT] #1537369
11/20/13 10:42 PM
11/20/13 10:42 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
only the cheap stuff, I'll probably back the timing down to 32-34 to start with.
