Re: EFI in tank pump question
[Re: jbc426]
#1533590
11/16/13 03:20 PM
11/16/13 03:20 PM
Posts: 22,794 Bitopia
jcc
Bitopia
So how is this surge tank vented, and the return lines plumbed to the surge tank, top or bottom draw? Is LP pump always oversized in capacity relative to HP pump so air/vacum is never introduced into surge tank?
[Re: jcc]
#1533592
11/16/13 10:10 PM
11/16/13 10:10 PM
Posts: 3,291 West Coast, USA
jbc426
West Coast, USA
All the feeds and returns go to the top of the surge tank, however the high pressure electric pump does draw fuel from the bottom of the surge tank and feeds it out the top.
Any air that does get introduced into the surge tank when the low pressure pump's pick-up is uncovered momentarily by high G-forces and/or low fuel levels is quickly purged out the top of the surge tank and sent back to the main fuel tank.
This design feature is what almost invariably leaves the high pressure pump submerged in fuel, while the pick-up in the main tank is momentarily uncovered and allowing it to suck air on occasion without affecting the pure fuel flow to the high pressure side.
[Re: Stanton]
#1533594
11/17/13 05:36 AM
11/17/13 05:36 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I am not impressed with some of the designs in drag cars not having the pickup in the back of the tank. When the fuel surges back, the pickup needs to be there. On roundy round cars, the pickup is on the outside edge of the tank. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: Stanton]
#1533595
11/17/13 01:27 PM
11/17/13 01:27 PM
jbc426
West Coast, USA
And for what it is you could buy a pump from "Tanks" and build your own surge canister to put it in and be a couple hundred bucks ahead
Yes, Stanton, there are a lot of interesting possibilities including what you're suggesting. There are a lot of talented fabricators out there who can build their own systems and lots of salvage and surplus yards that are full of cool fuel pumps, canisters and fittings that could be adapted for use in surge tanks systems.
I bought my own Duestchwerks pump on-line and decided to go with the convenience of Radium Engineering's high-quality surge tank.
When considering building my own tank, ( I have no experience welding aluminum) I found one of the more difficult parts to source when looking at building your own tank, is the electrical connector for the fuel pump. There is also the issue of creating a fuel proof seal to allow access inside the canister for installing and removing the pump. The rest is easy, especially if you can tig aluminum and precision machine things well.
One aspect of the Radium designs I don't like, is the lack of room to install a particle screen on the end of the high pressure pump once it's installed in their tank. This requires the installer to ensure that nothing but highly filtered fuel reaches the surge tank.
I am running 2 of those water separator/ fuel filters in my system, one between the main tank and low pressure pump, and another one just before the surge tank. They only flow enough fuel to feed 450 hp, but filter down to 2 or so microns. When I upgrade my engine and eventually supercharge it, I will have to either add additional filters plumbed in parallel or change to another style of filter with more flow. There are not a lot of high-flow filters out there that both filter particles that small and trap water.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
