Re: 48RE overdrive lost AGAIN! [Re: Rhinodart] #1533450
11/15/13 06:03 PM
11/15/13 06:03 PM
MINNESOTA
BRONZEBEE Offline
BRONZEBEE  Offline
MINNESOTA
I think you need too start over and pull it out and inspect the case for cracks,i have seen many leaks but not from the top of the case,unless it is blowing out the dipstick and running down.
The overdrive going out is the end result of the problem you haven't fixed yet.
If your builder is just replacing burnt clutches and nothing else you haven't fixed the problem.
If you pull the o/d out and replace it it will happen again
Re: 48RE overdrive lost AGAIN! [Re: BRONZEBEE] #1533451
11/15/13 11:41 PM
11/15/13 11:41 PM
Round Lake Beach, Illinoisy
Rhinodart Offline OP
Rhinotruck
Rhinotruck
Like I said above, the trans works fine, shifts great and the fluid smells as good as that nasty stuff can smell! I do believe the trans needs to come out, I tried to find out where the fluid was leaking from with no possible way to see it.
JB Rhinehart, Realist
A-Body's RULE!
Re: 48RE overdrive lost AGAIN! [Re: Rhinodart] #1533452
11/16/13 12:31 AM
11/16/13 12:31 AM
Rhinotruck
Rhinotruck
Anyone know anything about this company and product?
http://www.dttdiesel.com/product-p/dttod.htm
A-Body's RULE!
Re: 48RE overdrive lost AGAIN! [Re: Rhinodart] #1533453
11/17/13 12:10 PM
11/17/13 12:10 PM
Kansas
cascius Offline
cascius  Offline
Kansas
DTT is a very reputable company with a great product. Steve Condalay is the owner and will do anything he can to help someone out, whether they buy his product or not. I spent a few years working at a diesel shop here locally that got it's start in transmissions through DTT, but now does it's own thing. Another good one to look into would be Goerend. They are top notch as well.
Re: 48RE overdrive lost AGAIN! [Re: cascius] #1533454
11/17/13 10:07 PM
11/17/13 10:07 PM
Rhinotruck
Rhinotruck
Thanks! I know about Gorend but didn't see a ready to go overdrive unit, maybe I need to look at little further...
A-Body's RULE!
Re: 48RE overdrive lost AGAIN! [Re: Guitar Jones] #1533455
11/18/13 12:11 AM
11/18/13 12:11 AM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
Maybe you need a new trans guy. Just saying...
for those of you guys that say this I know a farmer near me that has an 05 Cummins truck (4 door yuk) that has had this happen 3 times, O/D case splits around the trans mount boss.
Re: 48RE overdrive lost AGAIN! [Re: Rhinodart] #1533456
11/18/13 12:42 PM
11/18/13 12:42 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
i saved the attached image about reliabilty mods to the OD, maybe posted here on Moparts or another board.
The image may be from DTT, or Sonnex
Re: 48RE overdrive lost AGAIN! [Re: 360view] #1533457
11/18/13 12:45 PM
11/18/13 12:45 PM
USA
3
360view Offline
360view  Offline
3
USA
My original 46RH Overdrive unit from 1995 with about 200,000 miles on it is now slipping on any hill over about 2% grade and i am looking for someone to rebuild it
Re: 48RE overdrive lost AGAIN! [Re: 360view] #1533458
11/18/13 09:02 PM
11/18/13 09:02 PM
Rhinotruck
Rhinotruck
I also found that there is no mount for the OD unit and it just sits above the skid plate rattling around until it breaks. There is an aftermarket mount kit I will be buying when I get the new OD unit.
A-Body's RULE!
Re: 48RE overdrive lost AGAIN! [Re: 360view] #1533459
11/19/13 02:20 PM
11/19/13 02:20 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Have you confirmed it's not the torque converter clutch causing this?
Re: 48RE overdrive lost AGAIN! [Re: goldmember] #1533460
11/20/13 01:54 PM
11/20/13 01:54 PM
USA
3
360view Offline
360view  Offline
3
USA
Yes, TCC is ok and there is no slippage in locked up third gear
Re: 48RE overdrive lost AGAIN! [Re: 360view] #1533461
11/20/13 11:42 PM
11/20/13 11:42 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
If you were further south or west I could recommend someone. Find a trans guy(over 40yrs old) that builds for the local racers(they can give you names) and go with him,it's not hard to do.
