Re: SEMA and the SB Victor 16 heads
[Re: mshred]
#1532983
11/14/13 09:11 PM
11/14/13 09:11 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Between the different valve angle and the 2.15 intake valve size i thing sales will be low if they ever do come out.
true I guess as a bolt on deal...but maybe not if you are building a motor around them
Custom pistons would be your only option and valve to bore ratio kinda leans toward an aftermarket block with a big bore. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) If that's the case why not go W8 or W9.
True
Yes but then you need to find them. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Quicktree]
#1532984
11/14/13 09:12 PM
11/14/13 09:12 PM
MattW
Ontario Canada
are they any better than indy's? doesn't sound like it
I bet you the quality will be better. Matt
[Re: MattW]
#1532985
11/14/13 10:55 PM
11/14/13 10:55 PM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
...and that was our hope when we were waiting for them to come out.
[Re: MattW]
#1532986
11/14/13 11:12 PM
11/14/13 11:12 PM
Posts: 11,689 W. Kentucky
justinp61
W. Kentucky
Add to that, you probably won't be talked to like you're an idiot either.
[Re: justinp61]
#1532987
11/14/13 11:41 PM
11/14/13 11:41 PM
Posts: 20,204 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I would really like to know who Edelbrock approached to help design this head. I'm betting late into the project they realized they headed in the wrong direction with this head. In order to sell it at a reasonable price to the average guy doing a build with a stock production block it a failure. Mopars aftermarket small blocks are over priced and unreliable if you can even find one. After two long talks with Trickflow they at least want to talk to the average Joe to see what's needed. I see them releasing a big block first and hopefully move toward an out of the box 300+ cfm head.
[Re: pittsburghracer]
#1532988
11/14/13 11:50 PM
11/14/13 11:50 PM
Posts: 3,428 Toronto
mshred
Toronto
Nice to hear that stuff about trickflow, the question is will it ever actually happen in the near future.
#1532990
11/15/13 12:08 AM
11/15/13 12:08 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Look for the trickflow heads at next years PRI.
Brian Hafliger
[Re: ScottSmith_Harms]
#1532995
11/15/13 01:55 AM
11/15/13 01:55 AM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
I'd just like to see a current aluminum version of pretty much ANY SB head that looked "as cast" on the ends like iron heads (like the old Batten W2 heads, or the old Diamond W2 heads) all of the current offerings look like ugly aluminum bricks on top of a cast iron block.... 300 flow would be nice two. but secondary to appearances for me (and more stock 340 guys than you might think).
Don't hold your breath.
[Re: goldmember]
#1532996
11/15/13 01:58 AM
11/15/13 01:58 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I'm not, but there is no doubt in my mind at all, there's a market for them. Just like the 440 Source "Stealth" 440 heads.
#1532997
11/15/13 02:05 AM
11/15/13 02:05 AM
goldmember
Gainesville,FL
You should come up with a design that makes HP and looks like you want them to. Bet you'd make a ton of $$ on that deal.
[Re: goldmember]
#1532998
11/15/13 02:13 AM
11/15/13 02:13 AM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Just here to are you? ![](/ubbthreads/images/graemlins/wave.gif)
#1532999
11/15/13 02:22 AM
11/15/13 02:22 AM
goldmember
Gainesville,FL
Maybe! you want to call 440source and explain your needs? ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: goldmember]
#1533000
11/15/13 03:12 AM
11/15/13 03:12 AM
Posts: 1,090 north cakalaky
instigator
north cakalaky
Let's tell Vic to bring them one....when they come out I will probably pick up a set just knowing them for quality and supporting a great american company that spends large volumes of money to take a chance on us SBM guys developing them.......The 6 bolts and beefy deck thickness appeals to us boosted folks also...Though I do already have a set of 230cc 360-2's on the motor now , I would love to compare them...
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
[Re: instigator]
#1533001
11/15/13 03:24 AM
11/15/13 03:24 AM
instigator
north cakalaky
Also looking at the pics on edelbrocks site they have a nicely placed water outlet port right in the center of the head to get some extra cooling flowing between the center exhaust ports.....a notoriously hot area on power adder motors.
