Re: Odd /6 problem
[Re: SattyNoCar]
#1532064
11/12/13 12:38 PM
11/12/13 12:38 PM
Posts: 20,217 Park Forest, IL
slantzilla
Park Forest, IL
What carb/intake are you using? You don't happen to have one of the 2 piece welded intakes do you?
Was the head or block decked much? If so the intake may not be sealing against the head. When you deck the block there is a casting block that will hold the intake away from the head.
From that pic with the head off it looks pig rich. I have seen that caused by vacuum leaks before.
Re: Odd /6 problem
[Re: rustbuckett68]
#1532067
11/12/13 02:03 PM
11/12/13 02:03 PM
Posts: 1,106 Northeast
VincentVega
Northeast
Fouled plugs don't "unfoul" themselves, and they also create carbon hotspots which screw up cylinder firing. so if you are doing all of this diagnostic work with fouled plugs, you're wasting your time
the other thing I notice is the exhaust pipe flange. it looks like the entire thing has been leaking. slant sixes are very sensitive to exhaust leaks because they are small engines and already dialed in to be very lean. that could certainly cause popping.
Make sure the heat riser valve in the exhaust manifold isn't frozen shut. that'd make it run like a dog
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: Odd /6 problem
[Re: BigBird]
#1532072
11/12/13 08:51 PM
11/12/13 08:51 PM
RapidRobert
I doubt if you have one laying around but I'd wanna swap the intake manifolds. After all this I would have to know what it was all along no matter what the cost ![](/ubbthreads/images/graemlins/apimp.gif)
Re: Odd /6 problem
[Re: RapidRobert]
#1532073
11/13/13 09:55 AM
11/13/13 09:55 AM
Posts: 1,279 Buzzardbreath Wyoming
BigBird
You don't know the kind of pack rat I am. I do have another intake laying around and I think I'll try it when I put the head back on. That is one thing I haven't tried yet.
Re: Odd /6 problem
[Re: BigBird]
#1532075
11/14/13 04:51 AM
11/14/13 04:51 AM
slantzilla
Park Forest, IL
If the EGR was stuck open it would run like crap. Glad to hear all is well again. ![](/ubbthreads/images/graemlins/thumbs.gif)
Re: Odd /6 problem
[Re: RapidRobert]
#1532083
11/16/13 12:15 PM
11/16/13 12:15 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
Was it the EGR?
If it was leaking (I had one that did) it'd be a massive vac leak
2 things cause a backfire through the carb, lean condition or fire while an intake valve is still open. Bad EGR can cause a lean condition. Glad you got her fixed.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
