thanks now I need to know how far the valve cover on the passengers side should be from the shock tower ? mine is touching it and the rear header tube on the driver side is touching the frame
c
Your problem is you have elephant a ear front mount, you probably could move the engine a inch by just loosening up the water pump bolts and rotating the engine. Get a motor plate from AndyF.
what type of motor plate does he sell?
Google AREngineering Andy is a member here on Moparts and also a sponser. I've got his motor plates in both of my barracudas, perfect fit and they look fantastic.
