92-93 d150/d250 headers? #1531569
11/10/13 09:04 PM
11/10/13 09:04 PM
scratchnfotraction Offline OP
anyone running headers with a magnum engine in a 92-93 d150/d250 2x or 4x4 truck chassis with a v-8 nv4500 hydro bell housing with nv4500 5 speed?
in the middle of conversion on the 85 truck chassis. 85 2x truck long tube headers do not fit with magnum manual nv4500 bell housing.
so do 92-93 magnum trucks use the ramhead shorty header like the 92-93 v-8 DAK
any long tube headers for the magnum truck chassis?
anyone use the DAK magnum manifolds?
kinda stuck here..now what do i do??
pics would be great.
Re: 92-93 d150/d250 headers? [Re: scratchnfotraction] #1531570
11/10/13 09:15 PM
11/10/13 09:15 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
How about some pulling truck headers coming out the hood or some Zoomies ??
seriously other than the Mag manifolds, something like this is about it..they sure have small tubes.
http://www.summitracing.com/parts/sum-g9044/overview/
I am truckless..
Re: 92-93 d150/d250 headers? [Re: scratchnfotraction] #1531571
11/10/13 09:59 PM
11/10/13 09:59 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Sean used a set of long tubes on his 360 magnum in his 88 W150 conversion. Not sure what brand they are, they kind of look like Hedmans. I told him to check for port alignment as they were designed for an LA and he said they had good alignment. Truck pulls like a raped ape. He's using an NV4500.
Sheldon
Re: 92-93 d150/d250 headers? [Re: RUNCHARGER] #1531572
11/10/13 10:34 PM
11/10/13 10:34 PM
who is sean? maybe the 4x4 headers are different than the 2x headers?
any chance of a pic of header at starter location?
Re: 92-93 d150/d250 headers? [Re: scratchnfotraction] #1531573
11/10/13 11:13 PM
11/10/13 11:13 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I have had a set of the Summit headers on mine for over ten years, I had them coated and they are still in great shape. I hooked them to the stock Y pipe
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: 92-93 d150/d250 headers? [Re: RUNCHARGER] #1531574
11/11/13 09:05 PM
11/11/13 09:05 PM
Sheldon
think I may have found a set that will work, it moves the #7 tube more to the front of engine.
foot note say it will only work with the low torque(short) LA style sarter.
I only need 1.5" for the mini starter to fit. when I got my 85 truck I had a set like this gave to me and i run them a while. I had to R&R the driver side with the LA style starter (short) but when I went to a mini starter I could R&R it with out R&R of the header. then they rusted thru and I replaced them.
i replaced them with the hedman 79080 2x truck headers.
looks like the hedman 79170 2x or 4x4 truck headers will fit, #7 tube is out of the way of the mini starter.
what I have 79080
Re: 92-93 d150/d250 headers? [Re: scratchnfotraction] #1531575
11/11/13 09:11 PM
11/11/13 09:11 PM
these are the 79170 2x or 4x4 hedman headers with # 7 tube moved further forward to make room for the LA style starter.(short) should have plenty of room for a mini in there with these.
now to roll the dice on IF they are whats in the pic they used for advertisment purpose.
here are the 79170 hedman truck headers
what do you think? ya or nay ???
if sean/sheldon use long tubes with a magnum/nv4500 in a 88 4x4...this has to be the headers i would think.
any thing else for a 92 is the ram head shortys like a DAK uses.
Re: 92-93 d150/d250 headers? [Re: scratchnfotraction] #1531576
11/12/13 12:11 AM
11/12/13 12:11 AM
RUNCHARGER Offline
RUNCHARGER  Offline
Yep: Edit again, the SECOND set photoed look like Sean's.
I paged Sean, I'll let you know what he says.
Sheldon
Re: 92-93 d150/d250 headers? [Re: 340SHORTY] #1531577
11/12/13 11:55 AM
11/12/13 11:55 AM
RUNCHARGER Offline
RUNCHARGER  Offline
Sean is using a mini starter, he'll try to get some photos today.
Sheldon
Re: 92-93 d150/d250 headers? [Re: RUNCHARGER] #1531578
11/12/13 12:41 PM
11/12/13 12:41 PM
thanks, I have a mini starter also.
the #7 tube on the 79080 needs to move over toward fram 2" or move forward 2" so it seems eyeballing it holding the starter aclose to mounted as i can.
I had a set of the 79170 on this truck when i got it, then rplaced with the newer 79080 set.
I just dont see hammering the tube flat or trying to bend it out of the way.
I do know I had to R&R the header with a LA style starter with the 79170 but went to a mini starter and could R&R it with out R&R of header.
I orderd up a set so we shall see in a day or so.
a pic would be awsome if he has the mini on with a set of 79080 hedmans.
thanks for rhe effort and help.
cant wait to row the 5 speed.
i also place who you 2 guys are now.. you son has the bad ass 4x4 rig he ahs been wrenching on for a while now.
Re: 92-93 d150/d250 headers? [Re: scratchnfotraction] #1531579
11/13/13 12:03 AM
11/13/13 12:03 AM
RUNCHARGER Offline
RUNCHARGER  Offline
I think I have them downsized. Photo 1.
Sheldon
Re: 92-93 d150/d250 headers? [Re: RUNCHARGER] #1531580
11/13/13 12:03 AM
11/13/13 12:03 AM
RUNCHARGER Offline
RUNCHARGER  Offline
Photo 2.
Re: 92-93 d150/d250 headers? [Re: RUNCHARGER] #1531581
11/13/13 12:04 AM
11/13/13 12:04 AM
RUNCHARGER Offline
RUNCHARGER  Offline
3.
Re: 92-93 d150/d250 headers? [Re: RUNCHARGER] #1531582
11/13/13 12:05 AM
11/13/13 12:05 AM
RUNCHARGER Offline
RUNCHARGER  Offline
4. They do look like the 170 headers. Hope this helps.
Re: 92-93 d150/d250 headers? [Re: RUNCHARGER] #1531583
11/13/13 08:22 AM
11/13/13 08:22 AM
thank you for the pics, they are worth a 1000 words.
they look almost exact but a couple slight changes maybe.
the pass side looks like a match,
the driver side has the tubes arranged a little different but look close enuff...#7 tube seems to be out of the way of the starter.
I think I am good with the 79170
I am hopeing that changes down the line are the differance between your pics and the advertising pic for 78170 headers.
big help and thank you.
Re: 92-93 d150/d250 headers? [Re: scratchnfotraction] #1531584
11/13/13 12:44 PM
11/13/13 12:44 PM
RUNCHARGER Offline
RUNCHARGER  Offline
You're welcome. Sean is on Ramcharger Central as Mr Gutsy I believe.
Sheldon
Re: 92-93 d150/d250 headers? [Re: RUNCHARGER] #1531585
11/13/13 01:00 PM
11/13/13 01:00 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
yep and has a BADAZZ RC/Truck
Re: 92-93 d150/d250 headers? [Re: 76dodgeboy] #1531586
11/15/13 09:15 PM
11/15/13 09:15 PM
79170 75-91 w150/RC fit the 85 2x truck chassis ans #7 tube is well out of the way for the short LA starter and plenty o room for a mini starter now.
rolled the dice and won for a change.
Re: 92-93 d150/d250 headers? [Re: scratchnfotraction] #1531587
11/15/13 09:16 PM
11/15/13 09:16 PM
Re: 92-93 d150/d250 headers? [Re: scratchnfotraction] #1531588
11/15/13 09:18 PM
11/15/13 09:18 PM
thanks for the help Sheldon & Sean!
