Re: 22 inch rad ??? [Re: 68gtx] #1531459
11/11/13 03:02 PM
11/11/13 03:02 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
No ? about it being a GTX. The question was is it possible to have a 440 4 speed with a 22 inch radiator and 3.23 sure grip. We know the rear end is a dana but is not original to the car BOM 1969 dated. Thanks Larry J
No, not as far as I know. If it was a '69 I'd be 100% sure....I'm only 95% sure in your case.
Basically, all "axle package" cars got the 26" rad and all 440-4spd cars got axle packages. Since all GTX's had 440's as the base engine...
I have better info on '69's and '70's but this shows a larger rad for all 440-4spd cars;
To make any better call, we'd need to see pictures of the fender tag but something doesn't sound right. I suppose it's possible that some 1968's were built before the "mandatory axle package (and related 26" rad)" was instituted. Some more research appears to be in order.
Whatever you do, whether it's correct or whether the car was originally an automatic, I wouldn't go cutting out the rad support (with the matching SO numbers to the quarter) unless you determine that the car is a rebody anyway. Otherwise you're going to kill the resale value of the car.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 22 inch rad ??? [Re: 68gtx] #1531460
11/11/13 03:07 PM
11/11/13 03:07 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Never heard of a 440 4spd car that was a 22" radiator, or 8-3/4 rear axle
Re: 22 inch rad ??? [Re: gtx6970] #1531461
11/11/13 03:11 PM
11/11/13 03:11 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Not 'originally'.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: 22 inch rad ??? [Re: 68gtx] #1531462
11/11/13 03:51 PM
11/11/13 03:51 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Fender tag does say 4 speed and 3.23 sure grip yes the SO # match the body. But I did not even know what a SO# was until I purchased the car. Like i said novice to mopars. I just think if you were going to go to all that trouble to stamp a trans and redo the tag it would be for $$$ . Maybe someone before us did pay a chunk a money for the car but I didn't and the guy before me didn't. Well none the less I am putting it back together for me to keep. Maybe i will put the 26 inch in??? Honestly its still a 68 GTX 440 4 speed with a dana and I love to drive it. Well I did before it went to the paint shop!!Thanks Larry J
3.23 on the tag and it has a Dana? I think you better post a pic or the numbers off of the tag.
Re: 22 inch rad ??? [Re: 68gtx] #1531463
11/11/13 05:18 PM
11/11/13 05:18 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Did 68 RR have rocker molding and wheel opening moldings??...
Rocker moldings were an option. Wheel opening moldings were not available on a RR.
Re: 22 inch rad ??? [Re: 68gtx] #1531464
11/11/13 05:19 PM
11/11/13 05:19 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Can someone post a picture of a factory 4 speed tunnel weld and also mine does have that same seam sealer you find in the trunk seams but some has chunked off so I can see the weld. Also I talked with one of the guys at the body shop and he feels like its the correct factory tunnel not after market and weld and seam sealer. Maybe the ? is would it have seam sealer on the tunnel weld??? Without a BS we may never know!!! Thanks LJ
Based on what you have told us so far, I don't think a pic of a factory tunnel will be of any help to you.
You said the "fender tag does say 4 speed and 3.23 sure grip yes the SO # match the body", so we know the tag belongs to the body and the car was built as a 4spd. I don't see any reason to further question the 4spd part.
The 3.23 axle is a different story. A 3.23 axle has to be a 8.75 axle, not a Dana, as the Dana axle was not available in 3.23 ratio.
It seems like you are saying the car has a 3.23 ratio Dana, which is not possible from the factory. Either you have a 3.23 axle, in which case it is not a Dana, or you have a Dana, in which case it would not be 3.23 ratio.
The 8.75 vs Dana difference is easy to see at a glance. In case you are not familiar with these axles this thread has an illustration of various Mopar axles.https://board.moparts.org/ubbthreads/show...e=1#Post7917915
You do not need the BS to answer your questions. Since the fender tag matches the body, it has the info you need. Look at the model code and engine code, that will tell you what car model and which engine the car had originally.
Let us know what you find.
No matter what the tag says, it will be a nice car to have!
What color combo is it?
Drive it and enjoy it!
Re: 22 inch rad ??? [Re: moparfan53] #1531465
11/11/13 05:30 PM
11/11/13 05:30 PM
68gtx Offline OP
68gtx  Offline OP
THE # UNDER AX IS 68 I WAS TOLD IT IS A 3.23 BY PRIVIOUS OWNER?? IS THAT RIGHT? I AM NEW TO MOPARS. THANKS LARRY J
Re: 22 inch rad ??? [Re: moparfan53] #1531466
11/11/13 05:50 PM
11/11/13 05:50 PM
DPelletier Offline
DPelletier  Offline
He already said the Dana wasn't original. He said the tag shows the 4spd and the 3.23's (which is an 8 3/4 ratio) so I suspect either he's misreading the tag or it's a fake.
...and since it's a '68, you can't match the FT/VIN to the Body without the broadcast sheet.
DAve
Re: 22 inch rad ??? [Re: 68gtx] #1531467
11/11/13 05:50 PM
11/11/13 05:50 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Ok... now things are starting to make more sense. That is not a 3.23 code. My sample tag above has a 3.23 sure-grip axle (code 48). I am fairly sure the "68" code was used for a 3.54/Dana as well as a 3.55/8.75. Your engine code will determine which axle.
Re: 22 inch rad ??? [Re: DPelletier] #1531468
11/11/13 06:05 PM
11/11/13 06:05 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
DAve
Good point about the Dana, I forgot he said the BOM was from 1969.
I realize the BS is needed to match the vin to the car. My point was that his/our questions about whether the car was originally a RR/383/4spd/3.23 or a GTX/440/4spd/3.54 could be answered by the fender tag info only (I am ASSuMEing it is not a fake). I was not referring to the "numbers matching" aspect of the car.
Alan
Re: 22 inch rad ??? [Re: moparfan53] #1531469
11/11/13 06:22 PM
11/11/13 06:22 PM
68gtx Offline OP
68gtx  Offline OP
Ok so i just got off the phone with the guy I bought the car from. Both of us are not i repeat not mopar data experts. Here is what we found out AX 68 3.54 dana. but he also confirmed as I did it is a 69 dana not 68. He remembers the radiator that is in the car was put in by a friend after the original one started leaking. He said his friend told him that he had one that should work but he had to modify it??? I think I need to have the body shop measure the opening in my car it may just have the wrong radiator in it. If thats the case I am a DUMB A$$... Thanks Larry J
Re: 22 inch rad ??? [Re: 68gtx] #1531470
11/11/13 06:28 PM
11/11/13 06:28 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
this is from a 68 gtx.....
Re: 22 inch rad ??? [Re: 68gtx] #1531471
11/11/13 06:54 PM
11/11/13 06:54 PM
DPelletier Offline
DPelletier  Offline
If your car has a factory 26" opening then the mystery is solved! Now that we know it was a Dana/4spd car, if it does have the opening for the 22" rad, then I'd suspect its either a rebody or front clip replacement.
Good luck.
Re: 22 inch rad ??? [Re: flypaper] #1531472
11/11/13 07:06 PM
11/11/13 07:06 PM
68gtx Offline OP
68gtx  Offline OP
My tunnel looks just like that one. I think it most likely just has the wrong radiator in it. My buddy has a way of getting me going if you know what I mean. And all of us have had only GM stuff. None of us know a lot about mopars. But I will let you guys know what the body shop says. Thanks Larry J
Re: 22 inch rad ??? [Re: 68gtx] #1531473
11/13/13 04:01 PM
11/13/13 04:01 PM
68gtx Offline OP
68gtx  Offline OP
Finally the body shop called and confirmed it does have a 26 inch opening. This is what happens when you do not have the car in front of you. I was concerned that I had a converted auto car. As my wife likes to say you are dumb a$$ sometimes she right!!!!! Thanks Larry J
Re: 22 inch rad ??? [Re: 68gtx] #1531474
11/13/13 06:50 PM
11/13/13 06:50 PM
DPelletier Offline
DPelletier  Offline
Good news and thanks for letting us know the outcome.
Re: 22 inch rad ??? [Re: DPelletier] #1531475
11/14/13 10:15 PM
11/14/13 10:15 PM
restos just aren't my thing
gtsuperbee Offline
gtsuperbee  Offline
I don't want to say I told you so Larry, but... I told you so .
Restoring a car to look "only" as good as the factory made it is like getting a boob job for your wife and having the doctor make them two different sizes to seem more natural
Re: 22 inch rad ??? [Re: gtsuperbee] #1531476
11/14/13 10:20 PM
11/14/13 10:20 PM
68gtx Offline OP
68gtx  Offline OP
GT still have not had time to pull that bell off but i will try this weekend. I will call you. Thanks Larry J
