Re: 22 inch rad ???
[Re: 68gtx]
#1531462
11/11/13 03:51 PM
11/11/13 03:51 PM
Posts: 1,294 Ontario, Canada
FJ5_Fish
Ontario, Canada
Fender tag does say 4 speed and 3.23 sure grip yes the SO # match the body. But I did not even know what a SO# was until I purchased the car. Like i said novice to mopars. I just think if you were going to go to all that trouble to stamp a trans and redo the tag it would be for $$$ . Maybe someone before us did pay a chunk a money for the car but I didn't and the guy before me didn't. Well none the less I am putting it back together for me to keep. Maybe i will put the 26 inch in??? Honestly its still a 68 GTX 440 4 speed with a dana and I love to drive it. Well I did before it went to the paint shop!!Thanks Larry J
3.23 on the tag and it has a Dana? I think you better post a pic or the numbers off of the tag.
Re: 22 inch rad ???
[Re: 68gtx]
#1531463
11/11/13 05:18 PM
11/11/13 05:18 PM
Posts: 1,028 NB, Canada
moparfan53
NB, Canada
Did 68 RR have rocker molding and wheel opening moldings??...
Rocker moldings were an option. Wheel opening moldings were not available on a RR.
Re: 22 inch rad ???
[Re: 68gtx]
#1531464
11/11/13 05:19 PM
11/11/13 05:19 PM
moparfan53
NB, Canada
Can someone post a picture of a factory 4 speed tunnel weld and also mine does have that same seam sealer you find in the trunk seams but some has chunked off so I can see the weld. Also I talked with one of the guys at the body shop and he feels like its the correct factory tunnel not after market and weld and seam sealer. Maybe the ? is would it have seam sealer on the tunnel weld??? Without a BS we may never know!!! Thanks LJ
Based on what you have told us so far, I don't think a pic of a factory tunnel will be of any help to you. ![](/ubbthreads/images/graemlins/Twocents.gif)
You said the "fender tag does say 4 speed and 3.23 sure grip yes the SO # match the body", so we know the tag belongs to the body and the car was built as a 4spd. I don't see any reason to further question the 4spd part.
The 3.23 axle is a different story. A 3.23 axle has to be a 8.75 axle, not a Dana, as the Dana axle was not available in 3.23 ratio.
It seems like you are saying the car has a 3.23 ratio Dana, which is not possible from the factory. Either you have a 3.23 axle, in which case it is not a Dana, or you have a Dana, in which case it would not be 3.23 ratio.
The 8.75 vs Dana difference is easy to see at a glance. In case you are not familiar with these axles this thread has an illustration of various Mopar axles.https://board.moparts.org/ubbthreads/show...e=1#Post7917915
You do not need the BS to answer your questions. Since the fender tag matches the body, it has the info you need. Look at the model code and engine code, that will tell you what car model and which engine the car had originally.
Let us know what you find.
No matter what the tag says, it will be a nice car to have! ![](/ubbthreads/images/graemlins/thumbs.gif)
What color combo is it?
Drive it and enjoy it! ![](/ubbthreads/images/graemlins/drive.gif)
![](http://i1219.photobucket.com/albums/dd423/moparfan53/68fendertag.jpg)
Re: 22 inch rad ???
[Re: moparfan53]
#1531466
11/11/13 05:50 PM
11/11/13 05:50 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
He already said the Dana wasn't original. He said the tag shows the 4spd and the 3.23's (which is an 8 3/4 ratio) so I suspect either he's misreading the tag or it's a fake.
...and since it's a '68, you can't match the FT/VIN to the Body without the broadcast sheet.
DAve
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
Re: 22 inch rad ???
[Re: 68gtx]
#1531467
11/11/13 05:50 PM
11/11/13 05:50 PM
moparfan53
NB, Canada
THE # UNDER AX IS 68 I WAS TOLD IT IS A 3.23 BY PRIVIOUS OWNER?? IS THAT RIGHT? I AM NEW TO MOPARS. THANKS LARRY J
Ok... now things are starting to make more sense. That is not a 3.23 code. My sample tag above has a 3.23 sure-grip axle (code 48). I am fairly sure the "68" code was used for a 3.54/Dana as well as a 3.55/8.75. Your engine code will determine which axle.
Re: 22 inch rad ???
[Re: DPelletier]
#1531468
11/11/13 06:05 PM
11/11/13 06:05 PM
moparfan53
NB, Canada
DAve
Good point about the Dana, I forgot he said the BOM was from 1969. ![](/ubbthreads/images/graemlins/blush.gif)
I realize the BS is needed to match the vin to the car. My point was that his/our questions about whether the car was originally a RR/383/4spd/3.23 or a GTX/440/4spd/3.54 could be answered by the fender tag info only (I am ASSuMEing it is not a fake). I was not referring to the "numbers matching" aspect of the car.
Alan
![](/ubbthreads/images/graemlins/beer.gif)
Re: 22 inch rad ???
[Re: 68gtx]
#1531470
11/11/13 06:28 PM
11/11/13 06:28 PM
Posts: 18,632 jersey shore
flypaper
I hate Texas
I hate Texas
jersey shore
this is from a 68 gtx.....
![](http://i26.photobucket.com/albums/c144/flypaper38/sale%20stuff/2006_0416stuff0115.jpg)
![](http://i26.photobucket.com/albums/c144/flypaper38/sale%20stuff/2006_0416stuff0116.jpg)
Re: 22 inch rad ???
[Re: 68gtx]
#1531471
11/11/13 06:54 PM
11/11/13 06:54 PM
DPelletier
Ok so i just got off the phone with the guy I bought the car from. Both of us are not i repeat not mopar data experts. Here is what we found out AX 68 3.54 dana. but he also confirmed as I did it is a 69 dana not 68. He remembers the radiator that is in the car was put in by a friend after the original one started leaking. He said his friend told him that he had one that should work but he had to modify it??? I think I need to have the body shop measure the opening in my car it may just have the wrong radiator in it. If thats the case I am a DUMB A$$... Thanks Larry J
If your car has a factory 26" opening then the mystery is solved! Now that we know it was a Dana/4spd car, if it does have the opening for the 22" rad, then I'd suspect its either a rebody or front clip replacement.
Good luck.
1974 'Cuda
