Re: Cummings mileage
[Re: moretoys]
#1530688
11/15/13 06:10 AM
11/15/13 06:10 AM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
lose the egr valve & cooler, and the particulate filter (catalytic convertor).aftermarket companies sell egr removal kits. gain hp/torque and mileage.also need to program pcm computer so the light stays out.
How important is it to actually remove the EGR compared to having the programmer disconnect it?
[Re: SpareParts]
#1530690
11/17/13 01:52 AM
11/17/13 01:52 AM
Posts: 1,805 ky hills
thehemikid
ky hills
Previous owner (somewhere in its life) abused 96, 3500, 46re, ext.cab, long bed, 4x4, 280k, stock exhaust with catalytic converter(may be nothing left in there, don't know), & no motor mod's. Tires are taller than stock though.
My 1st pull was with a 28' inclosed with car. Not knowing what speed would give the best mpg, doing ~65-70 I got ~10 mpg. I was hoping for 12. I could feel the wind pushing hard on the flat nose of the trailer. Maybe I had a head wind too, don't remember.
This yr had a chance to check it empty, on a trip 20.7, that surprised me a little.
To town & around & back, don't know.
Now do some fuel mods and get more mpg. 12v > 24v
I would if the stock trans would live,..but everything I read on the Dodge Cummins Diesel Forum, suggests that eventually it would fail.
To do engine mod's I'd have to do trans mod's too. I know there are some easy cheap engine mod's, but the trans, are not. So I decided to leave it be for now. Not that I couldn't afford it. I just put the money elsewhere. Got used to its 185 hp.
Even with its 185hp diesel in an over 7,000lb 3.54 geared truck w/ 2" taller than oem tires, it pulls better that a 220hp B350 3.54 gear at 5200lb. ![](/ubbthreads/images/graemlins/Twocents.gif)
