Re: 440 Fires up - runs nice @ high RPM BUT will not idle.
[Re: ThermoQuad]
#1530474
11/11/13 11:26 AM
11/11/13 11:26 AM
Challenger 1
Cincinnati, Ohio
Attention all those whom have posted trying to help...did you direct the OP to the six pak tuning guide, with the recommendation to read it and then apply it...or did you provide haphazard guesses to fixing the problem?
Just wondering...
It sure helped me a bunch as I read it like 4 times before touching my car. If he's new to 6 paks, he sure should have read it before starting the car as the carbs need adjustments when new.
[Re: Mr.Yuck]
#1530475
11/11/13 11:28 AM
11/11/13 11:28 AM
Challenger 1
Cincinnati, Ohio
"and the engine vacuum has no bearing on the end carbs opening..as they opened based on the center carb...not the engine..."
perhaps, as the linkage has to be "open" for the blades to open, but if you say have a 6.5 PV and the vac drops to 3-4 it's not going to run right.
I tuned my 6-pack out of the box like this... unhooked the outboards, turn the mixture screws all the way in then back out 1 turn, turn the idle screw up to about 2200, unhooked vac advance, fired the motor, let it warm up set advance to 38* in at 2200, brought the idle back down to 900 or so, set mixture screws for best vac reading, hooked up the outboards and went for a blast. However if you have a vacuum leak, that's not going to work.
The out board carbs need to have the idle mixture tuned, otherwise it'll be too rich at idle from my experience.
[Re: MASSMOPAR]
#1530476
11/11/13 11:36 AM
11/11/13 11:36 AM
Challenger 1
Cincinnati, Ohio
Big time vacuum leak ?
YUP -- We think it may be the center carb is defective.
There's nothing wrong with the center carb, the whole thing needs to be tuned is my bet or installed correctly.
[Re: elmor353]
#1530478
11/13/13 02:18 PM
11/13/13 02:18 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
I'll toss in to check the outboards are closed at idle. Some gaskets hang into the bores and the blades will catch and hang.
and x6 or 7 on the tuning it properly. Set timing curve, then tune center carb, then all three.
[Re: PHJ426]
#1530481
11/15/13 02:59 PM
11/15/13 02:59 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
If you are running an MSD distributor that uses bushings to alter mechanical advance, I have some that are 10 and 14* so you can get more initial timing. That 509 cam will want a lot of initial timing if it's anything like the others, more than 16* and more like 20+. Last one I tuned wanted to be locked out at 36*. Probably idle around 950-1000 rpm. Find the point at which your engine kicks back on the starter or cranks very hard when warmed up. That's your initial timing limit. Then start tuning it up. Should start quickly with no multiple cranking. The tech section tuning guide is a great resource! ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: ThermoQuad]
#1530482
11/15/13 10:16 PM
11/15/13 10:16 PM
Posts: 3,456 Fly Over States
PHJ426
Fly Over States
Just wondering...
Certainly,
He needs to read the Six Pack guide, understand it....then apply it.
There is nothing like a well tuned 6 pack.
