Re: B1BA MC HEADS
[Re: scottb]
#1528225
11/03/13 06:52 PM
11/03/13 06:52 PM
Triple Threat
Renton Washington
Yes its possible. I run them on my car it has been a best of 10.36@128 @3575#. Remove almost 600 pounds to your target weight and it will go 9's. The problem with them is the cost and need for expensive pieces. Have to run T&D's or Jesels. No one makes a header for them, I have adapted W2 headers on mine. For the money, you're better off with Indy or something else.
Re: B1BA MC HEADS
[Re: kingdust]
#1528227
11/03/13 10:21 PM
11/03/13 10:21 PM
Posts: 3,396 Pa
Hot 340
Pa
I looking for some input on these heads is there enough head there to run 10 flat in a 3000 lb car with a 416 short block I forgot all about these heads no ones running them its hard to find any real info thanks for the help ive already looked at shadydell
call scott koffel @ koffels.
and when you have him on the phone ask him why dont they revise it up a bit to make it a more attractive offering... I cant imagine it taking alot of effort, and they have had to lose money on all the more they are selling now. And get the price reasonable so they will sell more and make a few bucks too. Would make an easy w5 replacement head.
Re: B1BA MC HEADS
[Re: scottb]
#1528228
11/04/13 07:00 PM
11/04/13 07:00 PM
Posts: 236 Richmond , Virginia
chagjr
Richmond , Virginia
B1BA heads-- My car went 10.22 @ 130 MPH --3060lbs that includes my weight.
I am running a set of Hedman Husler headers.
F.A.S.T/1969 SUPER BEE/383/AUTO/AVS 11.58 @ 117.98 1.71 60ft mph F.A.S.T Legal
1969 DART SWINGER/340(420CI)/6.52 @ 105.39 1.45 60ft (1/8 mile)10.22 @130.5 (1/4 mile)
Harry
Re: B1BA MC HEADS
[Re: Triple Threat]
#1528230
11/04/13 07:11 PM
11/04/13 07:11 PM
Posts: 20,671 in a cattle trailer down by th...
Guitar Jones
I don't think they are they that great of a head. There are better options.
Re: B1BA MC HEADS
[Re: Guitar Jones]
#1528231
11/04/13 07:24 PM
11/04/13 07:24 PM
Posts: 11,728 Portage,michigan
B3422W5
Portage,michigan
I agree... They have been talked about on here a bit over the years. Cant say as I have seen any 9 sec cars running them , which should be easy with a head that supposedly can go 350 ish.
Think I would rather have the 230 small indy head that is a proven to make power and is likely cheaper with more options( headers, intake, etc)
Re: B1BA MC HEADS
[Re: B3422W5]
#1528232
11/04/13 10:52 PM
11/04/13 10:52 PM
Triple Threat
Renton Washington
My motor went 9's in a lighter car, that's not theory, it happened. Its making more power than it did back then, but is in a heavier chassis now.
Are they the best head for the $, no. I was the first to say that, but, they aren't total boat anchors either. I've been shopping around for a better 59 degree head to replace mine, but I don't think it's economical to switch.
FWIW my car has been 129 and change at 3575+, you can make your own power assumptions.
Re: B1BA MC HEADS
[Re: Triple Threat]
#1528233
11/04/13 11:07 PM
11/04/13 11:07 PM
B3422W5
Portage,michigan
I guess my point was that I have yet to see that head run as well as its " potential" airflow would see to indicate. for a head that is supposed to flow 350cfm( well more than an indy or w5 head) they don't see to carry that over at the track. As an example, my old w5 motor has been 140 at 3200 pounds and those heads flowed nowhere even close to 330, much less 350. I agree there are way better options out there than this Brodix head, at least based on what have seen and heard. And that with a 2.15 valve, W5 has 2.08, indy 2.100.
Re: B1BA MC HEADS
[Re: B3422W5]
#1528234
11/04/13 11:23 PM
11/04/13 11:23 PM
Triple Threat
Renton Washington
Right, and if you compare flow numbers its fairly apparent why, the mid and low lift numbers just aren't there. Peak numbers are great for bragging, and that's about it. It's about area under the curve ladies and gents. For reference, my heads flow: Intake Flow@28" 0.100 80 0.200 150 0.300 205 0.400 255 0.450 275 0.500 281 0.550 290 0.600 300 0.650 310 0.700 315
Re: B1BA MC HEADS
[Re: Triple Threat]
#1528235
11/04/13 11:40 PM
11/04/13 11:40 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Why not a w9 in a 59 degree? You can get those to flow 375+, same money as b1s. You need T&D or jesel and adpt a set of headers. Heck you can get bare new heads cheaper then the brodix.
Brett Miller W9 cnc'd heads STR Chassis fabraction
