Page 3 of 4 1 2 3 4
Re: What are the best double adjustable rear shocks ? [Re: Monte_Smith] #1527776
11/05/13 04:10 PM
11/05/13 04:10 PM
Mohnton, Pa
DodgeCharger Offline OP
Mohnton, Pa
I'll put my adjustable front shocks back on and slow down the transfer.
Re: What are the best double adjustable rear shocks ? [Re: DodgeCharger] #1527777
11/05/13 06:51 PM
11/05/13 06:51 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Looking back at this post you initially said "...He said that for drag radials to work the rear needs to come up slow when you push it down."
That is 100% correct for drag radials. I got my AFCO's and had the valving reworked for drag radials. I believe I paid almost $700 shipped getting them from Mark Menscer. They work like a champ! I went 1.42 a few Fridays ago and believe I have some mid 1.3's with a little more boost and a boost controller.
1967DartGT said: " I sent them to Mark Menser motorsports and he revalved them for me. He is a dealer for strange, afco, Penske, koni and a few more brands. Call him and he will set up a custom shock for your car. Mark (910)624-1119 "
Re: What are the best double adjustable rear shocks ? [Re: DodgeCharger] #1527778
11/05/13 06:54 PM
11/05/13 06:54 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Not sure why you think it is turning the tires for 60ft. Highly unlikely on drag radials. Like I said earlier, they are hooked or not and generally they slip at all, they spin hard.
Watching the video, the car looks way too loose in the front to me. It stretches the front end completely out real early and then sets the front end right back down, which will unload the rear
Monte
My 60ft times are way off and I have a racepak system. It shows the drive shaft rpm. The car is hooking at the hit of the throttle but then is spinning more than it should.
Put up a screen shot of a graph where you think it is spinning
Monte
Re: What are the best double adjustable rear shocks ? [Re: Monte_Smith] #1527779
11/05/13 07:03 PM
11/05/13 07:03 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
... radial friendly valving...
Monte - I've done a lot of motorcycle damper tuning over the years (changing high & low speed compression & rebound valve stacks on motocross bikes) and am curious how you would describe how radial-type settings would differ from bias-ply.
Thanks,
Brad
Re: What are the best double adjustable rear shocks ? [Re: Monte_Smith] #1527780
11/05/13 08:39 PM
11/05/13 08:39 PM
Mohnton, Pa
Mohnton, Pa
Monte
Monte
Hi Monte,
I don't know how to post a racepak file.
But I can describe what it looks like. I was told it was spinning when the drive shaft rpm flat lines the goes up then flat lines again. It almost looks like stair steps.
Re: What are the best double adjustable rear shocks ? [Re: TheOtherDodge] #1527781
11/05/13 08:43 PM
11/05/13 08:43 PM
Mohnton, Pa
Mohnton, Pa
I did call him. He said $850. Originally he said I could use stock Strange shocks based on my ET. When I told him the weight and horsepower of my car he said they won't work I need a custom valve AFCO.
Re: What are the best double adjustable rear shocks ? [Re: DodgeCharger] #1527782
11/05/13 08:45 PM
11/05/13 08:45 PM
Arizona
Chris'sBarracuda Offline
Arizona
Monte
Monte
Hi Monte,
Here..
http://windows.microsoft.com/en-us/windows7/products/features/snipping-tool
Chris..
Re: What are the best double adjustable rear shocks ? [Re: Dyno1] #1527783
11/05/13 08:46 PM
11/05/13 08:46 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
http://www.jegs.com/p/JEGS-Performance-P...483367/10002/-1
dont know who makes them for jegs...but just put a set on a 71 Duster with ladder bars...
they look like QA1's
Was at QA1 display at sema show..and yes..those are the same shocks.
Tony
70 AARCuda Vitamin C
Re: What are the best double adjustable rear shocks ? [Re: 70AARcuda] #1527784
11/05/13 10:53 PM
11/05/13 10:53 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Just thought I would throw this out there...There is a company called Viking..Apparently the guy running it used to work for QA-1, and the shocks resemble them somewhat. There are a couple of threads over on the bullet talking about them, and so far there are some pretty good reviews. Best part is they are cheaper than QA-1's or Afco's and Strange.
Just an option for those looking...I did look in their online catalog and they do have mopar applications. A friend of mine who is looking to upgrade his shocks in the rear of his fox body mentioned the name to me, so I did a little digging and this is what I have come up with.
Just another option out there
Re: What are the best double adjustable rear shocks ? [Re: DodgeCharger] #1527785
11/05/13 10:56 PM
11/05/13 10:56 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Worth every penny
Re: What are the best double adjustable rear shocks ? [Re: DodgeCharger] #1527786
11/05/13 11:05 PM
11/05/13 11:05 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Monte
Monte
Hi Monte,
May be tire spin, may not be. The g-meter will tell you a lot. You don't have to post a file. You could just take a picture of the graph on your computer screen and post it here
Monte
Re: What are the best double adjustable rear shocks ? [Re: mshred] #1527787
11/05/13 11:16 PM
11/05/13 11:16 PM
Dyno1 Offline
Dyno1  Offline
FYI Vi-King Shocks are owned and run by Chris & Christy King, former CEO of QA1. QA1 and Vi-King are located about 1/2 mile apart in Lakeville,MN. Nice people run both companies.
Re: What are the best double adjustable rear shocks ? [Re: Monte_Smith] #1527788
11/06/13 09:31 AM
11/06/13 09:31 AM
Mohnton, Pa
Mohnton, Pa
Monte
Monte
Hi Monte,
Monte
Here is a Race pak screen shot
Re: What are the best double adjustable rear shocks ? [Re: DodgeCharger] #1527789
11/06/13 09:33 AM
11/06/13 09:33 AM
Mohnton, Pa
Mohnton, Pa
Hopefully you can see it I don't know how to make it larger.
Re: What are the best double adjustable rear shocks ? [Re: DodgeCharger] #1527790
11/06/13 10:33 AM
11/06/13 10:33 AM
Lancaster, Pennsylvania
Sweigart1022 Offline
Give me a call (610-375-6180 ask for Shane) I work at Penske Racing Shocks. Nothing we build comes off "the shelf". Everything is custom built for your application. Our double adjustable shock goes for $550 per shock. Once you have the shocks its not like we are done with you. You can call in at anytime and we can also look at your racepak data to help you tune the car. I as well am a drag race so I know the importance of shocks and can help relate.
Re: What are the best double adjustable rear shocks ? [Re: Sweigart1022] #1527791
11/06/13 10:43 AM
11/06/13 10:43 AM
Houston, Texas
Houston, Texas
What do you 60ft and what is your ET and MPH, weight of car, converter, trans, transbrake, etc?
Re: What are the best double adjustable rear shocks ? [Re: TheOtherDodge] #1527792
11/06/13 11:09 AM
11/06/13 11:09 AM
Mohnton, Pa
Mohnton, Pa
1.45 60ft 10.05 et 137 mph 3950 lbs 5200 stall foot brake 4.10 gear 325x50x15 ET Street Radial 28 inches tall.
Re: What are the best double adjustable rear shocks ? [Re: Sweigart1022] #1527793
11/06/13 11:33 AM
11/06/13 11:33 AM
Mohnton, Pa
Mohnton, Pa
Thanks for the offer but $550 each is a little higher than I was looking to go if I can get it working for less.
Where are you located? Do you have experience with setting up shocks for drag radial cars?
I just noticed your car in your signature. I've seen you run at the track.
Re: What are the best double adjustable rear shocks ? [Re: DodgeCharger] #1527794
11/06/13 12:05 PM
11/06/13 12:05 PM
Canada
onig Offline
onig  Offline
Canada
I just watched the video of the car launching.
Is it normal for radial tires to wrinkle on the launch or is he running too low a pressure?
Onig
69 Dart
Re: What are the best double adjustable rear shocks ? [Re: onig] #1527795
11/06/13 12:14 PM
11/06/13 12:14 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
The best shock is the best you can afford.Prices are all over the place.Talk with some of the suspension guys with experience and get recommendations for your particular application and budget.
Page 3 of 4 1 2 3 4
