2009 Dodge Avenger front end noise? #1527420
11/02/13 02:53 PM
11/02/13 02:53 PM
Chesterfield Twp. Mi.
John Burdine Offline OP
I have a 2009 Dodge Avenger, getting a clunky/rattle noise from the front suspension, struts seems to be fine, at least not blown out.
just throwing it out there for some tips on what to look for.
thanks, John
Re: 2009 Dodge Avenger front end noise? [Re: John Burdine] #1527421
11/02/13 05:42 PM
11/02/13 05:42 PM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
Check the sway bar end links. When they get play in them , they rattle when you hit small bumps....
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: 2009 Dodge Avenger front end noise? [Re: Dartsport540] #1527422
11/02/13 06:37 PM
11/02/13 06:37 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Seen alot of those cars while I worked at the dealer with the lower ball joint(s) worn slam out while still under warranty. Also check the inner and outer tie rod ends and sway bar bushings too.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
