1968~1970 Charger rear window regulator pictures. #1525934
10/30/13 12:41 PM
10/30/13 12:41 PM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
Hi there. Question for you all. Working on a 68 Charger and I'm installing all the glass. Everything fits real well but the back quarter glass is two inches short of meeting the door glass! With both the door glass and the back glass up I can stick my hands in between them. Kinda funny. I'm looking for pictures of the area where the rear window regulator bolts to..... behind the rear trim panel. I want to see if I have it all bolted in correctly. Thanks, Troy
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: 1968~1970 Charger rear window regulator pictures. [Re: Troy] #1525935
10/30/13 01:39 PM
10/30/13 01:39 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
i don't know if this helps
Re: 1968~1970 Charger rear window regulator pictures. [Re: CSK] #1525936
10/30/13 01:46 PM
10/30/13 01:46 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Re: 1968~1970 Charger rear window regulator pictures. [Re: CSK] #1525937
10/30/13 02:36 PM
10/30/13 02:36 PM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
That helps! Thank you very much!
Re: 1968~1970 Charger rear window regulator pictures. [Re: Troy] #1525938
11/01/13 02:01 PM
11/01/13 02:01 PM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
I got it all fixed. I had everything correct but it was just way out of adjustment. The car will be on its way to Sema tomorrow! Thanks again.
