Page 2 of 3 1 2 3
Re: 360 in 1937 truck [Re: poorboy] #1525690
11/15/13 04:27 PM
11/15/13 04:27 PM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
I've heard the Magnum 360 (5.9) heads are the best small block heads produced, but they have a different angle for the bolts that hold the intake on, so extra work/parts are required to use them on an LA motor. Gene
yes the magnum heads flow great,,but used ones are prone to have cracks in the chamber area,,and use a rocker set up not as good as pre magnums,,,the 1989 heads are same as magnums sorta and use the shaft mounted rocker systems,,
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: 360 in 1937 truck [Re: fstfish66] #1525691
11/18/13 03:46 AM
11/18/13 03:46 AM
NH
3
36dodge Offline OP
36dodge  Offline OP
NH
What do u think.....found a friend...
An Edelbrock 2177 cam and lifter kit $100
Should i pick it up? Hmmmm that with a dual plane intake
fresh vlv job and my headers?
Re: 360 in 1937 truck [Re: 36dodge] #1525692
11/19/13 08:46 PM
11/19/13 08:46 PM
NH
3
36dodge Offline OP
36dodge  Offline OP
NH
cam & lifters $100??? all new still in the box
is it worth the effort?
Re: 360 in 1937 truck [Re: 36dodge] #1525693
11/19/13 09:39 PM
11/19/13 09:39 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
What are the specs on the cam? Unless a guy knows the numbers, the cam may work great or not so great on a street rod. A good street mannered cam for $100 would be a go, but some radical high rpm race cam might not be a good deal for a street driven car, even at $100.
Least that is my
Gene
Re: 360 in 1937 truck [Re: poorboy] #1525694
11/20/13 03:51 AM
11/20/13 03:51 AM
NH
3
36dodge Offline OP
36dodge  Offline OP
NH
.270/.270 dur, .420/.420 lift, mech
Re: 360 in 1937 truck [Re: 36dodge] #1525695
11/20/13 01:44 PM
11/20/13 01:44 PM
dogdays Offline
dogdays  Offline
Do it. Its Summit price is $200.
You can use stock springs. If the exhausts have rotaters, remove them and the springs and replace with the same stuff that's on the intake.
318 roller cam springs like I found on my '86 Fifth 318 are a little stiffer than the stock springs and would be a decent upgrade.
Specs are 204/204 @ 50 lift, 110LSA
0.420 lift.
It's really really close to the old Comp 252H grind, they claimed 0.425 lift otherwise everything else's the same.
I bought one several years ago to use in a 318 and have never gotten around to using it.
It's one step bigger than a stock 360 cam and makes a really nice cam for a 318. It'll get more power from the 360 with excellent manners.
R.
Re: 360 in 1937 truck [Re: 36dodge] #1525696
11/21/13 02:49 AM
11/21/13 02:49 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
if new in box sure its worth 100 but are the specs what you need ?? flipping it for more may be hard to do,,,
2015 cherokee
2013 R/T classic
Re: 360 in 1937 truck [Re: 36dodge] #1525697
11/21/13 02:51 AM
11/21/13 02:51 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
if i remember correctly,,,420 lift would be fairly close to a stock 340/360 cam,,not sure on the duration,,,look it up on all par
2015 cherokee
2013 R/T classic
Re: 360 in 1937 truck [Re: fstfish66] #1525698
11/30/13 08:43 PM
11/30/13 08:43 PM
NH
3
36dodge Offline OP
36dodge  Offline OP
NH
Passed on the cam..seemed like the specs were not aggressive enough.
Just bought a 742 empty carrier housing....who has the internals?
Got another ??? should I go with rear leafs or 4 link? 4 Link is better for handling right?
Re: 360 in 1937 truck [Re: 36dodge] #1525699
12/01/13 06:08 PM
12/01/13 06:08 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Again, unless your planning on doing some heavy cornering, I doubt you will notice the difference between a 4 link and leaf springs, the 4 link will be more complex to set up if its not already done. Personally, I like to keep things simple, the more fancy you get, the more difficult the project becomes, and the more things can go wrong down the road.
Gene
Re: 360 in 1937 truck [Re: poorboy] #1525700
12/01/13 06:13 PM
12/01/13 06:13 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
A true 4 link is junk for handling.
What most people think of as a "4 link" in regards to handling is not a 4 link. It's a 5 or 6 link setup.
Don't be the exception.
Re: 360 in 1937 truck [Re: Supercuda] #1525701
12/01/13 07:51 PM
12/01/13 07:51 PM
NH
3
36dodge Offline OP
36dodge  Offline OP
NH
Poorboy...Supercuda
You guys are correct...4 link on a solid rear axle just is not worth it
You would need IRS set up...ie Jag or other
No I guess I will stick with the rear leafs..Just got to find short length version
with the correct spring rate
maybe Posies...do know they will be expensive as its not an off
the shelf unit
Re: 360 in 1937 truck [Re: Supercuda] #1525702
12/01/13 08:24 PM
12/01/13 08:24 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Does it really matter on these old truck so? They will never be a Porsche so anything is an improvement over a straight axle
The advantage a 4 link has over a leaf springed rear axle is when combined with air bags you can adjust the ride height
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: 360 in 1937 truck [Re: poorboy] #1525703
12/01/13 09:04 PM
12/01/13 09:04 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Not a big deal. If you have the LA and Mag heads side by side, I used the common bolt holes on the end of both heads to create a wooden jig and drilled and threaded my Mag heads for an LA intake. And I am WAY less experienced fabricator than Poorboy! I got one hole drilled crooked, but it seals fine. A drill press would do better than the hand drill I used.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: 360 in 1937 truck [Re: AZ_A12_BEE] #1525704
12/01/13 09:20 PM
12/01/13 09:20 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't think the cost benefit ratio is on the plus side there. You can get a well sorted out and handling parallel rear leaf setup for well under $1k. I seriously doubt you could get a 4 link/airbag setup for even close to that. And I am of the type that I set the ride height and leave it alone, I do not need a remotely adjustable ride height setup.
Re: 360 in 1937 truck [Re: 36dodge] #1525705
12/01/13 10:09 PM
12/01/13 10:09 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Poorboy...Supercuda
the shelf unit
Leaf springs are pretty easy, all you need is the center bolt to be at the correct location to center the rear axle in the desired location. Then mount the front leaf spring mount where it needs to be, and mount the rear mount where it needs to be. There are many options on how long the front portion of the spring is and how long the rear portion of the spring is. Spring rate is a matter of how thick and how many leafs are in the spring pack. I see no reason you can't use an off the shelf pair of leaf springs.
Make your life easy, find a donner with leaf springs about the same weight as your truck, and get a new pair of springs for it. On my 54, I used a set of rear springs from a Mustang II. Put the front and rear hangers where they need to be so the rear axle was centered in the rear wheel wells and I was done. I mounted my springs outside of the frame on a 3/8" x 4" angle and bolted the Ford spring perches to the angle welded to the frame (the angle can also be bolted to the frame with 4 3/8" grade 8 bolts if you want to do all the drilling). I would also bet Mopar "A" body leaf springs would be close enough for a great ride and you can use the front leaf spring brackets from the A body too.
Of course, if you want to use Posy's springs, its your money. Gene
Re: 360 in 1937 truck [Re: poorboy] #1525706
12/01/13 10:44 PM
12/01/13 10:44 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
I use a lot of mini truck springs(toyota,Dodge D50,and nisson )all work real nice, and easy to add or subtract leafs. Ron...
Re: 360 in 1937 truck [Re: Supercuda] #1525707
12/02/13 12:09 AM
12/02/13 12:09 AM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Not everyone is the set and forget kind, especial those that use their rig for towing or hauling loads so just because you like like leafs springs doesn't mean a 4 link doesn't have its uses for others. Would I 4 link my Coronets, hell no, but I plan on eventually towing a jet ski trailer with my 37 and I want it low so the 4 link will serve my purpose. I fixed the screwed up springs to get my 37 roadworthy because it was easy and cheap.
Re: 360 in 1937 truck [Re: AZ_A12_BEE] #1525708
12/02/13 04:32 PM
12/02/13 04:32 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
No mention of towing at all in the OP's original request, handling was mentioned.
In my book handling and towing have mutually exclusive requirements.
Re: 360 in 1937 truck [Re: Supercuda] #1525709
12/02/13 05:37 PM
12/02/13 05:37 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
As is good handling and ride quality
Page 2 of 3 1 2 3
