Re: 360 in 1937 truck
[Re: poorboy]
#1525690
11/15/13 04:27 PM
11/15/13 04:27 PM
Posts: 1,757 levittown pa
fstfish66
levittown pa
I've heard the Magnum 360 (5.9) heads are the best small block heads produced, but they have a different angle for the bolts that hold the intake on, so extra work/parts are required to use them on an LA motor. Gene
yes the magnum heads flow great,,but used ones are prone to have cracks in the chamber area,,and use a rocker set up not as good as pre magnums,,,the 1989 heads are same as magnums sorta and use the shaft mounted rocker systems,,
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
[Re: 36dodge]
#1525693
11/19/13 09:39 PM
11/19/13 09:39 PM
Posts: 10,672 Freeport IL USA
poorboy
Freeport IL USA
What are the specs on the cam? Unless a guy knows the numbers, the cam may work great or not so great on a street rod. A good street mannered cam for $100 would be a go, but some radical high rpm race cam might not be a good deal for a street driven car, even at $100. Least that is my ![](/ubbthreads/images/graemlins/Twocents.gif) Gene
[Re: 36dodge]
#1525697
11/21/13 02:51 AM
11/21/13 02:51 AM
fstfish66
levittown pa
.270/.270 dur, .420/.420 lift, mech
if i remember correctly,,,420 lift would be fairly close to a stock 340/360 cam,,not sure on the duration,,,look it up on all par
[Re: poorboy]
#1525700
12/01/13 06:13 PM
12/01/13 06:13 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
A true 4 link is junk for handling.
What most people think of as a "4 link" in regards to handling is not a 4 link. It's a 5 or 6 link setup.
[Re: 36dodge]
#1525705
12/01/13 10:09 PM
12/01/13 10:09 PM
poorboy
Freeport IL USA
Poorboy...Supercuda You guys are correct...4 link on a solid rear axle just is not worth it You would need IRS set up...ie Jag or other No I guess I will stick with the rear leafs..Just got to find short length version with the correct spring rate maybe Posies...do know they will be expensive as its not an off the shelf unit
Leaf springs are pretty easy, all you need is the center bolt to be at the correct location to center the rear axle in the desired location. Then mount the front leaf spring mount where it needs to be, and mount the rear mount where it needs to be. There are many options on how long the front portion of the spring is and how long the rear portion of the spring is. Spring rate is a matter of how thick and how many leafs are in the spring pack. I see no reason you can't use an off the shelf pair of leaf springs. Make your life easy, find a donner with leaf springs about the same weight as your truck, and get a new pair of springs for it. On my 54, I used a set of rear springs from a Mustang II. Put the front and rear hangers where they need to be so the rear axle was centered in the rear wheel wells and I was done. I mounted my springs outside of the frame on a 3/8" x 4" angle and bolted the Ford spring perches to the angle welded to the frame (the angle can also be bolted to the frame with 4 3/8" grade 8 bolts if you want to do all the drilling). I would also bet Mopar "A" body leaf springs would be close enough for a great ride and you can use the front leaf spring brackets from the A body too. Of course, if you want to use Posy's springs, its your money. Gene
[Re: AZ_A12_BEE]
#1525708
12/02/13 04:32 PM
12/02/13 04:32 PM
Supercuda
About to go away
About to go away
up yours
No mention of towing at all in the OP's original request, handling was mentioned.
In my book handling and towing have mutually exclusive requirements.
