Re: A little sunday excitment. Not what I was hoping for!
[Re: Dragula]
#1525141
10/29/13 01:38 PM
10/29/13 01:38 PM
Posts: 2,224 Arlington, Tx.
BJS racing
Arlington, Tx.
There is absolutely no adjustment that can be made on the chassis. You can adjust the toe on the front and that be all there is.
Back in the swing of things at Painless again! Great to be back!
[Re: BJS racing]
#1525144
10/29/13 01:53 PM
10/29/13 01:53 PM
Posts: 8,165 Left Coast
BobR
Left Coast
Have you scaled the car?
[Re: BJS racing]
#1525148
10/29/13 03:10 PM
10/29/13 03:10 PM
Posts: 12,422 Taxes & Virus's R-US, NY
Dragula
Well, that is an issue. I have seen a couple of different chassis set-ups, but is there no way to aim the rear, or change the chassis flex with a lengthening or shortening of a mid chassis bar? Somthing caused it to drive left...I like the tires thought...VC breather leak then? A picture of this non-adjustable chassis might help...
[Re: BJS racing]
#1525150
10/29/13 04:51 PM
10/29/13 04:51 PM
Dragula
I don't have may pics of the car right now. Dennis the founder of Painless owns the car and I am driving it. This is actually a 15-20 year old new chassis that was hanging in a guys shop that he never did anything with. Its a Neil & Parks chassis? I don't remember exactly who but someone like that. It was built as a top fuel fed car back then.
I can tell you, that much Hp pointed in the wrong direction off the launch is just scary. If you know you didn't get somthing slippery under that tire or had your air pressure way off,look for loose/ bent bolts, bent axle, somthing...It picked the tires up after it launched and steered left. I have tinkered with four links and had a similar situation, we bent all the brackets on it. Use a 6" scale and start looking at it...
[Re: BJS racing]
#1525155
10/29/13 08:27 PM
10/29/13 08:27 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
It also seemed to me you were a little out of the groove on the first pass. I'll have to back & watch it again. Really don't mind as I love the FED's Maybe one day I'll end up with one Looking forward to more vids!
[Re: Dduster]
#1525158
10/30/13 10:58 AM
10/30/13 10:58 AM
BJS racing
Arlington, Tx.
Yeah that pass I don't know what the deal was with it. The second pass (he didn't record the burn out) was much better.
[Re: BJS racing]
#1525161
10/30/13 12:17 PM
10/30/13 12:17 PM
Quicktree
My dad always ran front motored stuff and had a front motored dragster that ran low 5's. Wheelie bars will be a must or eventually you will bend or break the chassis. He also always ran a open differential saying it was to make the car go straight. One other thing is that you were at the worst prepped track in DFW. Good luck with it!
Jake, did your dad run weight in the front of the car? If so how much? That is what I am trying to figure out so when I build the weight bar I make it big enough but not to big you know?
I don't think you can add enough weight to over come the front to rear weight bias, the motor and fat driver are right over the rear wheels just about
[Re: BJS racing]
#1525163
10/30/13 12:47 PM
10/30/13 12:47 PM
Quicktree
Man your memory must really be bad. You must not remember what I look like even though I stayed at your house for almost a week. I'm not exactly fat!
yea I remember, I figured with all those wheel stands you gained a lot of weight quit messing around and put some bars on that thing before you break it in half. when you get it figured out you can take them off.
[Re: BJS racing]
#1525166
10/31/13 07:53 PM
10/31/13 07:53 PM
Posts: 462 Stockholm, Sweden
fed
Stockholm, Sweden
Whats the specs on the engin? I thinking of a blower on my Fed.
Cuda, -70 Valiant-65 AWB, Valiant Signet200 -65 Topchopped dragcar. Topolino Fuel Altered. NostalgiaFED Sold, SuperComp Bantam Altered, Sold Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
[Re: fed]
#1525167
10/31/13 08:14 PM
10/31/13 08:14 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I would love to pick up an FED
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: 80fbody]
#1525168
11/01/13 09:49 AM
11/01/13 09:49 AM
Posts: 3,059 Swamps of South Jersey.
wildcargo
Is that due to too much traction from the right wheel? Around 50 sec. it looks like the left tire isn't in the same sort of groove as the right. Could just be camera trickery though.
I was wondering if any one picked up on that also, line it up better,
