Re: Rocker Geometry Measurements
[Re: HotRodDave]
#1524376
10/30/13 11:20 PM
10/30/13 11:20 PM
Posts: 31,106 Oregon
AndyF
Maybe some of you guys should look at that guys kit, it moves the shaft up to correct geometry and back to center the contact patch, the only compromise I see is the PR geometry will get worse, not a big deal on a BB but a SB is already bad. Of course a W2 is worstest yet and they can rev good so
The CAD drawings I've done say the shaft has to move down to correct geometry with a high lift cam. Moving the shaft up makes things worse on every simulation that I've run.
[Re: onig]
#1524379
10/31/13 12:16 PM
10/31/13 12:16 PM
Posts: 5,160 Texas
dannysbee
Texas
Andy I agree with you, with increased lift rocker shaft would have to be lowered assuming geometry is optimized before the additionial lift is added. I can also see how the rocker would need to be raised to compensate for the relocation of the contact point by adding the roller. This is what I have learned from these discussions Bottom line is there is only one location that is optimum for each type rocker, ratio and lift combination. The by product of your effort will be a rocker that is centered on the valve stem when the valve is on the seat and at full lift. What is acceptable other than being in this blue printed location I have no idea. Thanks to the OP for starting the discussion.
Getting old just means you were smarter than some and luckier than others.
[Re: B G Racing]
#1524380
10/31/13 12:33 PM
10/31/13 12:33 PM
Quicktree
We think this post needs to start over and maybe this guy can provide us with more detailed information on how his kits can correct common issues, and after we understand how it works, then he won't have to do a sales pitch, we will be ringing his phone off the hook. I know it would be of interest to us since we spend so much time on valvetrain corrections and end up with different fixes that are a priority for each build. I hope he comes back and helps us and himself by educating us on his method and product.
heck that makes to much sense
[Re: Quicktree]
#1524381
10/31/13 01:50 PM
10/31/13 01:50 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Sorry ,Tony I was think out loud again.I keep my mind/mouth closed from now on.
[Re: AndyF]
#1524382
10/31/13 01:51 PM
10/31/13 01:51 PM
Posts: 40 Washington
SuperStock68Dart
Washington
[Re: AndyF]
#1524383
10/31/13 01:57 PM
10/31/13 01:57 PM
BradH
FWIW, my Stage VIs required raising the shafts to get the geometry straightened out + lash caps, along w/ test-fitting a variety of rocker arms to come up w/ a combination that actually worked correctly. From what I've heard, that wasn't typical for most Stage VIs, but it's what was required with my particular set.
I think the approach required depends on the application, the particular parts used, and the rocker geometry results (e.g. Jim Miller's Mid-Lift design vs. Jesel's theory) you're looking to achieve.
[Re: B G Racing]
#1524385
10/31/13 02:27 PM
10/31/13 02:27 PM
Posts: 2,091 Delray beach, Florida
Performance Only
Then add some .100" length valves (or longer) in the mix and there's a whole host of geometry issues created. The actual geometry itself is pretty basic. achieving it is the hard part.
machine shop owner and engine builder
[Re: Performance Only]
#1524386
10/31/13 02:45 PM
10/31/13 02:45 PM
Posts: 5,160 Texas
dannysbee
Texas
Brad I would like to see an engine with one theory applied on one head and the other theory on the other. Then check the lift at the valve to see which achieves the most lift at the valve. One thing for sure the set up that has the rocker 90 degrees in relation to the valve at mid lift will have the least amount of scrub.
[Re: cudaman1969]
#1524390
10/31/13 05:33 PM
10/31/13 05:33 PM
Posts: 4,179 California
mickm
California
I wouldn't hesitate to say these last two posts are over the heads of 95% of the readers of this discussion. Oh yeah wher's my free stuff.
not sure why that's important.
are they over my head? more or less. but i still read them and learn from them, and even if i don't completely get it, it still either expands my knowledge of the subject or enables me to understand things in a little more detail the next time i read or discuss these concepts.
[Re: cudaman1969]
#1524394
10/31/13 06:59 PM
10/31/13 06:59 PM
AndyF
The concept would be easier to communicate if I took the time to post a picture. Or better yet, a short video would fully explain it in just a few frames.
I first read about the low pivot concept in a GM engine book years ago. The author didn't explain it fully but it sounded interesting. Years later I finally sat down at the CAD terminal and figured it out. The math is too complex for me so I solved the equation graphically. What you're trying to do is to solve the smallest product of load and scrub. When the valve is closed the load is small so you allow a lot of scrub. When the valve is full lift you're at max load so that is when you want zero scrub.
When you solve the equation you end up with the rocker arm perpendicular to the valve stem at about 2/3 of lift. This is below the mid-point theory which is more popular. The mid-lift approach is a simple approach that works pretty well in most applications. But if you're setting up something with 800 or 900 lbs on the nose then you might want to minimize the scrub under load.
[Re: AndyF]
#1524395
10/31/13 07:56 PM
10/31/13 07:56 PM
mickm
California
yup, that makes it perfectly clear! thanks!
