Re: Original 340 Owners = Distributor Hold Down Survey
[Re: ScottSmith_Harms]
#1523438
10/26/13 06:22 PM
10/26/13 06:22 PM
Posts: 43,958 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
I have seen a lot of 69 340's with painted clamps, I will see what pics of original owner cars I have laying around.
JB Rhinehart, Realist
A-Body's RULE!
[Re: gdonovan]
#1523440
10/27/13 09:19 AM
10/27/13 09:19 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I wish I still had the one I noted it on, it was a very unmolested car and you could see where the paint had "fogged" the distributor and petered out about a 1/3 of the way up.
It's quite possible that for some period of time the distributors were installed before paint and simply had a loose fitting mask over them which allowed the overspray to hit the clamp and distributor bases on some of them. It could also be that they changed this process in later years and that some were painted prior to the distributors being installed. Also, I haven't seen much good original evidence on 4 speed examples (which had cast iron dual point distributors vs aluminum single points for automatic cars) was there a difference? We may never know the details but any clues we find would be nice to see so keep posting!
[Re: bremotorsports]
#1523447
10/27/13 11:07 AM
10/27/13 11:07 AM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
BUT!
Here you can plainly see the paint on the rear of the block!
But mostly bare under where the clamp masked it. Paint coverage on the back and other less visible areas were likely highly variable depending on the individual painters efforts.
