Re: Headlights - all OFF when high beams activated [Re: RobX4406] #1523206
10/25/13 10:01 PM
10/25/13 10:01 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Only one wire should be hot at any time. One for lows or one for highs. I would test at the switch and at the socket for the lights. Sounds like you may have an issue at the high beam power splice under the hood. Again, the ground circuit SHOULD be ok, but since the current is doubled up in high it doesn't hurt to double check it, but you'd usually have weak lights with a poor ground, not completely zero light.
Don't be the exception.
Re: Headlights - all OFF when high beams activated [Re: Supercuda] #1523207
10/25/13 10:04 PM
10/25/13 10:04 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Check the bulkhead connector as well because it's a separate wire for each circuit from dimmer to headlights
Check power in and out of dimmer in each setting with headlight disconnected, no load. Continuity test or whatever to determine the dimmer is OK
Re: Headlights - all OFF when high beams activated [Re: MONC] #1523208
10/26/13 01:23 AM
10/26/13 01:23 AM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
I had the exact same problem with my '69 Charger. After checking switches, bulkhead connectors etc, it turned out to be a corroded/dirty terminal in the wiring connector beside the battery.
Regarding the circuit breaker in the h/lamp switch, I had one go bad in another car. In that case, the high beams would come on for a few seconds, then go out.
Let us know what you find.
Re: Headlights - all OFF when high beams activated [Re: Mopar-Al] #1523209
10/26/13 03:49 PM
10/26/13 03:49 PM
The Historic Hudson Valley
MONC Offline OP
MONC  Offline OP
I can only give my info learned that happened on my 72 cuda years ago. I went through the same issue. Everytime I hit the brights, they quit working. A guy at the dodge dealership told me my voltage reg was putting out too much and running wide open full charge. Turned out the ground was bad on the volt reg and was the culprit. I went through 2 regs before I finally got the gremlin. I changed all that everyone else said also
Thanks very much for the reply. This feedback is helpful. As I have found most of the time my electrical gremlins had to do with bad grounds. The fact the car was just painted makes me lean toward this as well.
That's why I asked if the hi-beam dimmer switch needed to be grounded as well.
Re: Headlights - all OFF when high beams activated [Re: moparfan53] #1523210
10/26/13 03:52 PM
10/26/13 03:52 PM
MONC Offline OP
MONC  Offline OP
Didn't think of this either. Thanks very much.
Will check that out too
Re: Headlights - all OFF when high beams activated [Re: MONC] #1523211
10/26/13 09:14 PM
10/26/13 09:14 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
UPDATE with my Demon today!!!
Went back out to the garage and pulled out the headlights to meter the pigtails again.
I do have power on Violet for low beams and red when in Hi Beam mode.
So I took the forward harness off the bulkhead and unwrapped it again but still saw no physical problems.
So now I put the meter on OHMs and started checking the Red wire from headlight pigtail back to bulkhead connector and what do I see?
Wait for it,
NO CONTINUITY!!!!!!!!
Started to sex-up the wire (wiggle it) and it was making and breaking.
Bad crimp on the RED at the bulkhead side of the forward light harness.
Now Hi beams and Low beams like everyone else.
Thanks for this thread to motivate me again and thanks for the help from people with suggestions.
Ron
Re: Headlights - all OFF when high beams activated [Re: RJS] #1523212
10/27/13 04:22 PM
10/27/13 04:22 PM
MONC Offline OP
MONC  Offline OP
Ok well we got RJS' light problem fixed now mine.
I first went to the connection by the battery as that was the easiest to get to.
The connections were all gummed up.
I cleaned them the best I could put some dialectric grease in there and now...
When I activate lights the high beams go on , BUT should the lows go off or stay on??
I haven't had a car with 2 lights on each side in a while I can't recall
Re: Headlights - all OFF when high beams activated [Re: MONC] #1523213
10/27/13 04:37 PM
10/27/13 04:37 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Your low beams should stay on when you hit the high beams - that is why the low beam headlight has 3 connection points : 1) ground, 2) low beam, 3) low beam with high beam
If the headlight goes out with the low beam, check the bulb . . . probably bad filament for the high beam circuit.
Cheers
Mark
Re: Headlights - all OFF when high beams activated [Re: a12rag] #1523214
10/27/13 05:54 PM
10/27/13 05:54 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Cheers
Mark
The low beam bulb has two filaments, one for lows and one for high. So it should turn off the lows and turn on the highs when the high beam is selected by the dimmer switch. IOW, in high beam mode you should have all four lights lit up.
Re: Headlights - all OFF when high beams activated [Re: Supercuda] #1523215
10/27/13 08:10 PM
10/27/13 08:10 PM
MONC Offline OP
MONC  Offline OP
Would 1 low beam bulb not having a good high beam filament cause both not to light up?
I noticed I have 3 newer bulbs and what looks like an original GE bulb in one of the low beam spots.
Re: Headlights - all OFF when high beams activated [Re: MONC] #1523216
10/27/13 11:06 PM
10/27/13 11:06 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Nope, if one's out then that's all that will not light up, assuming no one funked up the wiring.
Re: Headlights - all OFF when high beams activated [Re: Supercuda] #1523217
10/28/13 12:50 PM
10/28/13 12:50 PM
MONC Offline OP
MONC  Offline OP
Then I suspect it's more than a bulb issue.
So now I have alternating lighting bulbs.
Outers ( low) are on when light switch from dash goes on and inners (high beams are off)
Inners ( high) go on when hi beam dimmer switch clicked but Outer bulbs (lower) go off...
I am thinking it still could be that electrical connector by the battery. It's real tough to clean all the gummed up female connectors.
The male spades cleaned up nice.
Tried getting the female connectors out of the housing but couldn't.
Re: Headlights - all OFF when high beams activated [Re: MONC] #1523218
10/28/13 11:46 PM
10/28/13 11:46 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
there is a tab on the female terminal that engages the housing you need to depress to get it out.
You can see it in this picture
http://www.rowand.net/Shop/Tech/images/AutomotiveElectricalConnector-Packard56.jpg
a bit of info on how to release them
http://www.rowand.net/Shop/Tech/images/AutomotiveElectricalConnector-ManualPage.jpg
Re: Headlights - all OFF when high beams activated [Re: Supercuda] #1523219
11/05/13 12:23 PM
11/05/13 12:23 PM
MONC Offline OP
MONC  Offline OP
Appreciate the info Supercuda.
I knew there was a tab to release, but have had difficulty in the past getting them to release, and now my old eyes can't see that close anymore, making it more difficult.
Good info though, thanks.
Re: Headlights - all OFF when high beams activated [Re: MONC] #1523220
11/05/13 12:49 PM
11/05/13 12:49 PM
CT
GTX MATT Online content
GTX MATT  Online Content
CT
Maybe I'm pointing out the obvious here and missed part of your problem, but '69 and up the low beams always go off when the high beams are on. '67 and '68 all four will stay on.
Re: Headlights - all OFF when high beams activated [Re: GTX MATT] #1523221
11/05/13 02:09 PM
11/05/13 02:09 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
As pointed out, the low beam low filament gets switched to high filament when high beams are activated. All 4 bulbs should light.
Re: Headlights - all OFF when high beams activated [Re: buildanother] #1523222
11/10/13 02:22 PM
11/10/13 02:22 PM
MONC Offline OP
MONC  Offline OP
* UPDATE *
Fixed the issue.
It was that connector by the battery. Went back and cleaned it up some more and now when high beams are one, all 4 lights are on, low beam only the lows are on.
Thanks to everyone for their insights and special thanks to Moparfan53 for the pic reference and the answer to my problem
Onto much bigger issues...
Re: Headlights - all OFF when high beams activated [Re: MONC] #1523223
11/10/13 09:07 PM
11/10/13 09:07 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Glad to hear you got it fixed.
