HEI conversion #1522485
10/24/13 12:25 AM
10/24/13 12:25 AM
Kent, Wa
340SHORTY Offline OP
Truck Nut
Truck Nut
Kent, Wa
Does anyone remember who made/makes the disc that goes under the dist to mount a HEI module???
I am truckless..
Re: HEI conversion [Re: 340SHORTY] #1522486
10/24/13 12:42 AM
10/24/13 12:42 AM
Martinsville, VA
440child Offline
440child  Offline
Martinsville, VA
This guy does, but he's out of stock until at least November.
http://www.designed2drive.com/
Re: HEI conversion [Re: 440child] #1522487
10/24/13 12:45 AM
10/24/13 12:45 AM
Kent, Wa
Truck Nut
Truck Nut
Kent, Wa
Yep. Thats the 1, and Nov is only a week away.. thanks
I am truckless..
Re: HEI conversion [Re: 440child] #1522488
10/24/13 12:46 AM
10/24/13 12:46 AM
That's it, for that kind of money ($40.50) I'd get a piece of aluminum & trim it & bolt it on myself. Be sure to use heat sink paste
Re: HEI conversion [Re: 440child] #1522489
10/24/13 04:58 PM
10/24/13 04:58 PM
Nampa, ID
MadMatt Offline
MadMatt  Offline
Nampa, ID
Actually, I happen to know he will have them by the beginning of next week.
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: HEI conversion [Re: MadMatt] #1522490
10/24/13 05:29 PM
10/24/13 05:29 PM
BDW Online content
BDW  Online Content
Looks neat, but what's the benefit?
Re: HEI conversion [Re: BDW] #1522491
10/24/13 07:20 PM
10/24/13 07:20 PM
dogdays Offline
dogdays  Offline
The earlier four pin GM HEI module is small, puts out a really big spark, and is cheap. The only thing is it needs a heat sink to keep from frying.
If you already have an electronic distributor it's an easy mod. Plus there's no box on the firewall cluttering things up!
That's what the advantage is.
R.
Re: HEI conversion [Re: dogdays] #1522492
10/24/13 09:37 PM
10/24/13 09:37 PM
30 yrs ago I did that swap with the yellow Accell super coil the big yellow beast with NO ballast & it was a killer setup. Accell later wrote me & said to use a .8 ohm ballast with it but I had no failures or misfiring but as you know mixing & matching ign parts can be a crap shoot even with the recommended combos, sometimes you get lucky
Re: HEI conversion [Re: dogdays] #1522493
10/26/13 01:42 PM
10/26/13 01:42 PM
Nampa, ID
MadMatt Offline
MadMatt  Offline
Nampa, ID
R.
Another advantage is the GM HEI chip is available almost any place, any time, if you have a problem. I have the stock electronic ignition set up on my car, so I'm just going to use an extra plug spliced in to wire in the HEI chip, then I'll have 2 ignition systems available just by unplugging one and plugging in the other. No more getting stuck on the side of the road!
