Page 2 of 6 1 2 3 4 5 6
Re: 400 Stroker Build Suggestions [Re: Streetwize] #1521315
10/31/13 04:44 AM
10/31/13 04:44 AM
Missouri
68KillerBee Offline OP
Missouri
What about oiling system? Would the stock stuff be good enough on a stroker? I have a brand new 402 pan I bought earlier this year. Sounds like I will need a different windage tray.
I've been looking at just getting a S60 rear from Dr. Diff with 3.54 or 3.73's. Buying an original dana and getting it up to snuff with an S60, I'm better off getting the S60 right off the bat. Just need to sell my air grabber hood to pay for that.
What clutch set up do A833 drivers use?
I want this to be very streetable so I'm thinking 470, maybe a 500. But probably not
-Devin
Re: 400 Stroker Build Suggestions [Re: 68KillerBee] #1521316
10/31/13 08:43 AM
10/31/13 08:43 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Been thinking of putting a spare short block togather myself using a 400 block we have down at the shop. We currently race a pump gas RB 512 with a Hughes girdle, and what a beast...33" tall tires and a 4.56 gear leaving at 1900, shifting at 6400...9.97 and there is more left in it.
What's interesting is we had 4.88 gears, and switched to 4.56's and the 60ft remained the same, and yet, overall, the car went faster...TORQUE is KING!
Re: 400 Stroker Build Suggestions [Re: 68KillerBee] #1521317
10/31/13 10:56 AM
10/31/13 10:56 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
-Devin
I would put the 70 up Hemi pan on it , you don't have any more oil passage length but having the extra oil is a good thing , you'll probably want to add the hemi skid plate though because the pan will be flush with the bottom of the K. Do the oil system mods , minus the cam bearing restriction , outlined in the tech section, Especially the enlarging of the passages from the main galley to the mains , sometimes they could be restricted by casting .
Re: 400 Stroker Build Suggestions [Re: JohnRR] #1521318
10/31/13 10:48 PM
10/31/13 10:48 PM
IN
ahy Offline
ahy  Offline
IN
-Devin
Agree you want at least some extra oil capacity and the Hemi pan is a great option. You didn't state stroke and CI which makes this a fun post.
With Stealth heads, you can set it up to make about the same power with a 3.75 stroke/451 cu in, 3.9x/470, 4.15/496 and 4.25/512. The bigger engines will have more torque and make peak power at lower RPM. The 451 and 470 usually use a piston with enough compression height so top ring supports are not required... a benefit. The 512 is really big for Stealth heads and would run out of breath at pretty low RPM (low 5000's?). The 496 with 6.76 rod uses a short light piston with top ring support. It revs like a smaller lighter engine. That said the short piston is considered a durability drawback... although my Ed head lowdeck 496 has 15k miles and no signs of distress at all.
As many have said, vendors you mentioned are good as well as others. I worked with Muscle Motors for several reasons. They mildly ported and prepped the heads, helped me pick a "custom" cam, provided other parts and advice.
Re: 400 Stroker Build Suggestions [Re: ahy] #1521319
11/01/13 09:48 AM
11/01/13 09:48 AM
gregsdart Online content
gregsdart  Online Content
The bigger the motor, the more streetable it will be, and the fastest under your restrictions. You have a beautiful ride there, do it justice with a very good build and stretch the budget to the minimum good parts your chosen engine builder wants you to run. The great thing about a 512 is it will have the most torque down low, and the car will pull like it has 4.10 gears in it, even though it has 3.54s. You will not regret this choice.
Re: 400 Stroker Build Suggestions [Re: 68KillerBee] #1521320
11/01/13 10:00 AM
11/01/13 10:00 AM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Stealth heads are not going to really support a 500+ inch motor in my amatuer opinion. 470 is great low deck combo with a light piston & will work within your head limits. Check out the motor just built & dynoed on FABO. Look in the Big Block section. Had over 600ft of torque & over 580hp. A nice street motor that puts the power down by putting together a package.
Re: 400 Stroker Build Suggestions [Re: 80fbody] #1521321
11/01/13 11:12 AM
11/01/13 11:12 AM
Missouri
Missouri
470 seems like the magic number to shoot for. The one on fabo sounds awesome, except the whole "$10,500-11,500"! My budget will be A LOT lower than that. Plus I still have to change over to 18 spline stuff and Dana rear. Hmmmm once again I do appreciate all of the comments that will help me through this build. I will try to change this into a"in progress" thread as I build the motor.
Re: 400 Stroker Build Suggestions [Re: 68KillerBee] #1521322
11/01/13 11:25 AM
11/01/13 11:25 AM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
You can do it for alot less, imo. That's a shop build with dyno, warranty, etc. You can do it a ton cheaper if you shop wisely & maybe pull a few goodies from the parts section here.
Re: 400 Stroker Build Suggestions [Re: 80fbody] #1521323
11/01/13 02:07 PM
11/01/13 02:07 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
What the smaller cube people don't seem to take into account IMHO when they quote the "same" or similar HP and torque numbers as the 500 cube combos is the fact that it takes more compression and RPM to hit those numbers. That means finding gas that it will be happy with might become a challenge IF you were to push the envelope more towards a max effort.
It also means having to spin it up to 6800+ to get that peak number and being as this looks more like a street brawler than a track car, how often will you really get to do that without attracting the "wrong" kind of attention. Also the kind of cam it will take to make those 500 cube numbers while fun at first might get old a little quicker than some will admit.
Will Stealths support 500 cubes? Depends on how high you intend to spin it. What they will support is the same HP number a 470 will at less RPM. To use my arbitrary 500 @ 6800 number for the 470, the 500 combo should hit the same number at say 5000 and the torque curve will be proportionately lower as well.
What that means in the real world is that at basically a dead idle you could side step the clutch, smash the throttle to the rug and watch the back of the car disappear in a cloud of tire smoke. With 3.23 gears. Torque is your friend.
To use my own 8.9:1 combo and assuming your B-body is 3800 lbs you could be running mid 12.Oh's on regular gas and a reasonably power brake friendly cam.
You said you were going with an 18 spline and a Dana too. Nice upgrades but unless you have them already or intend a lot of track time with DOT slicks or better I would spend some of that money having Modern or Dwayne Porter optimize your Stealths. The tires will be the fuse that will protect your driveline. Dwayne would also be the go to guy to spec you the "right" cam for your project.
Kevin
Re: 400 Stroker Build Suggestions [Re: Twostick] #1521324
11/01/13 07:24 PM
11/01/13 07:24 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Kevin
When looking at HP only, you make good points, Kevin. However, there is another side to the 500" coin. SHORT PISTONS with OIL SUPPORT RINGS. Source uses a 1.12 ht. piston for goodness sake! Not that it cant work, it will.... but for a street motor that is going to see mostly low RPM use, Its not the way I would go. The longevity OR reliability of a 500" short block won't be what a similarly built 470 would. The guys goals are low 12 second street car for goodness sake. Building a 500 cube short block that requires oil support rings for this desired performance level does not make sense to me. Besides, its not like 470 cubes is small. It would still be the biggest mill at most any cruise night burger stand.
My : 1)470 2)451
Re: 400 Stroker Build Suggestions [Re: StealthWedge67] #1521325
11/01/13 08:36 PM
11/01/13 08:36 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Point taken.
What is the shortest CH that gets the oil ring out of the pin? Does anyone make a piston for a 4.15 stroke and a 6.535 rod?
Kevin
Re: 400 Stroker Build Suggestions [Re: Twostick] #1521326
11/01/13 10:28 PM
11/01/13 10:28 PM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
I have the oil support rails in my 499 lowdeck and have had zero issues with them. I had the engine apart twice, for other reasons, and both times they were no worse for wear. This is mainly a street car that I drive everywhere. Sees the track probably 2-3 times a year.
Re: 400 Stroker Build Suggestions [Re: StealthWedge67] #1521327
11/01/13 10:44 PM
11/01/13 10:44 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Kevin
My : 1)470 2)451
My little 470 is a hoot to drive around and race and even w/275-280 @.050 duration, 8" vert and 1050 dommy, it idles and drives fine and doesn`t overheat..........
Re: 400 Stroker Build Suggestions [Re: 68KillerBee] #1521328
11/01/13 11:11 PM
11/01/13 11:11 PM
My first 512 pump gas low deck stroker with 9.25 to 1 comp. ratio made 644 ft. lbs. at 4500 RPM and 612 HP at 5600 with a set of midly ported big valve 906 eads on it with a six pak on CA pump swill in 2004 Very streetable and bullet proof, other than having the Mopar brand roller lifter wheels break in half twice on two different lifters Go big and don't look back I've built, raced and dyno tune all sizes of Mopar Wedge and Hemi motors, bigger C.I. is always better, you don't have to have work the motor as hard and you don't need to open the throttle plates as far to make the same power as the smaller motors do at WOT
Re: 400 Stroker Build Suggestions [Re: Cab_Burge] #1521329
11/02/13 12:22 AM
11/02/13 12:22 AM
GEORGIA
barracuda7199 Offline
GEORGIA
Not to high jack your thread but what if we throw a 440 block in for comparisons sake? My current 440 has developed a knock in the bottom end so this thread is where I am as well in the research stage such as the OP. Same money to build a 493 as a 512. What about oil pickups? Will the 1/2" pickup work with a 4.25" stroke? Pin in the oil ring with a RB block?
Re: 400 Stroker Build Suggestions [Re: barracuda7199] #1521330
11/02/13 01:52 AM
11/02/13 01:52 AM
As for those Stealth heads not supporting 500 inches, well, I heartily disagree. They will support them just fine, just at a lower rpm. I have run 535 cubes with 906 heads, so I have some experience with this. A stealth headed 451 will peak torque about 4500 rpm with the right parts, a 512 with the same heads 3900 rpm. The 451 will want more rpm, say up to 6,000 with a street/strip cam. The 512 would be making the same power by 5300 rpm. Which one do you think will pull hardest with a street gear?
Re: 400 Stroker Build Suggestions [Re: gregsdart] #1521331
11/02/13 02:26 PM
11/02/13 02:26 PM
Missouri
Missouri
It is sounding like 470 is a happy medium to go to. I'm sure this will be more than fast enough for me for now. Especially coming from my "fastest" vehicle going a 13.9 in the quarter. I will mull it over for a bit with my cousin (has built a stroker for his duster) and the guy doing machine work about going bigger than that.
I will probably wait until December to buy all of the parts, in anticipation that some businesses will have some sort of christmas sales.
Our truck is broken for the moment so I can't pick up the block I found yet. But its apparently a standard bore 1973 motor.
Re: 400 Stroker Build Suggestions [Re: 68KillerBee] #1521332
11/08/13 04:12 PM
11/08/13 04:12 PM
Missouri
Missouri
I am going to convert this to my build thread once it gets rolling. In the mean time, our truck should be fixed by Monday to get the motor, I'll take it apart next week and hopefully get it to the machine shop to see what it needs to be bored out to. Then the decisions will begins.
I currently just have hp exhaust manifolds on the car with 2.5 inch exhaust and an x pipe and electric cutouts. I've always wanted to keep it looking stock from the engine bay (main reason I got stealth heads) but I know how important headers can be. Got lucky and scored a set that was just bolted up to a car but they found out it wouldn't fit. Paid 250 and brand new they are ~900!! Gotta love Craigslist. Only down side is they say they're for a 440, but TTI's website seems to show them to be the same as for a B motor. "440-178C5" is the part number and they have 1 7/8 od tubes. Says it's good for 400-600 hp.
Am selling my air grabber hood this week hopefully so that will free up a bunch of money. Getting excited
TTI's website: http://www.ttiexhaust.com/Category-Headers/383440-178/383440-178headers_RB.htm
Re: 400 Stroker Build Suggestions [Re: 68KillerBee] #1521333
11/08/13 04:33 PM
11/08/13 04:33 PM
JohnRR Offline
JohnRR  Offline
If you can use a shelf piston have it bored to 4.375 , assuming it sonic checks ok , that is a standard oversize for 400 based strokers.
Assuming this hasn't been said.
Re: 400 Stroker Build Suggestions [Re: JohnRR] #1521334
11/08/13 05:48 PM
11/08/13 05:48 PM
Missouri
Missouri
Bore .035 over, got it.
Thanks!
Looks like the 1 7/8's headers I have are specific for 383 or 440. The 1 3/4's are interchangeable, dang. Waiting for a call back from TTI. Looks like I gotta find someone to swap these with.
