Re: rebuilding a 1969 NASCAR Nichels HEMI
[Re: hemi-itis]
#1520130
10/22/13 05:39 PM
10/22/13 05:39 PM
Posts: 208 Munich, Bavaria
docford
Munich, Bavaria
Diamond or CP should be able to handle the task.
I just talked to Mike Knowles at DIAMOND. It sounds like we are good to go for a new set of custom made pistons :-)
[Re: 23T Hemmee]
#1520131
10/22/13 05:42 PM
10/22/13 05:42 PM
docford
Munich, Bavaria
.... I'm confused about your rod length though, the ones I had were 7.061" for the std stroke, and I know they made a 6.96 and a 7.176" which I think were for the 404 and 394 destrokers. I had a Petty 394 back in the 70's and it had 7.350" Carrillo's with a 3.480" stroke Moldex and Fordgetrue pistons so I don't know if the Petty's didn't like what the factory came up with and just came up with their own or if the factory just outsourced since a lot of the combinations were one/offs anyway as it seemed Nascar kept downsizing the restrictors on a monthly basis depending on how may races the Mopars won. Wow, sorry for the run on sentences, but I'm too tired to go back and fix it...
We measured the rods with more precision and they are of 7.061" length indeed.
[Re: ScottSmith_Harms]
#1520136
11/06/13 07:01 PM
11/06/13 07:01 PM
docford
Munich, Bavaria
I have a correct Holley carb for that engine. neat piece!
Interesting how much different is it from the regular 1050 Dominator ?
[Re: docford]
#1520137
11/07/13 11:39 AM
11/07/13 11:39 AM
Posts: 2,678 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I assume you would want Lemans float bowls. I had a Superbird with a Hemi engine and a NASCAR air cleaner and only Lemans float bowls would fit. There was more than one NASCAR air cleaner for a HEMI. I have a spare filter element for one of them that I don't need.
2011 Drag Pak Challenger
[Re: rickseeman]
#1520138
11/07/13 12:05 PM
11/07/13 12:05 PM
Posts: 1,240 Saline, MI
efisixpack
Saline, MI
rick, are you referring to the filter element that slides into the cowl area? If so could you post pics and dimensions?
Scott, any ida what an nos nascar dominator would be worth?
When I die I want to go like my Grandfather did, quietly in his sleep. Not screaming like the passengers in his car.
[Re: rickseeman]
#1520140
11/24/13 06:55 PM
11/24/13 06:55 PM
docford
Munich, Bavaria
No it is a round one.
mine got a flat filter that fit on a cavity in the cowl at the end of the air cleaner
[Re: docford]
#1520141
11/24/13 06:57 PM
11/24/13 06:57 PM
docford
Munich, Bavaria
I placed the order for new pistons at CP :-)
