Page 2 of 9 1 2 3 4 5 6 7 8 9
Re: Borgeson Stering Box [Re: 1fastabody] #1519538
10/24/13 12:02 PM
10/24/13 12:02 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
As good as the swap to a Borgeson box may sound, one thing to consider, for those who care, is that most sanctioned club rules (say, for autocross competition having guidelines of rules), will not allow this swap within certain classes/categories, or else, the swap will end up bumping your car into another class/category.. then.. you have an entire new set of rules to comply with and try to remain competitive with the balance of the class.
This swap would not be legal in the SCCA Solo class/category of E/Street Prepared... and it would be questionably legal in the Street-Mod class/category... but certainly OK in the C/Prepared all-out race class/category. Another club that I'm becoming active in, for hi-speed road-course autocross events/championship series (www.mcscc.org) doesn't allow this type of swap in the class that I plan to run.
In other words, as I've always advised, be ready to accept the consequences. I believe this is a great weight reducer as its prime advantage, and installing the box with the fast-ratio arms would make a huge difference compared to a ps box without the fast-ratio arms, especially for running through tight pylon autocross events.
My current T/A ps box, having the correct pitman and longer idler arms, AND with the Saginaw pump, plus with a reduced diameter steering wheel (mine is 11.5" diameter.. not really too small).. all combines to react very quickly through pylon manuevers, as well as on street/hwy/and road courses. Granted, the heavier weight of the original T/A ps box is there, but that's something that, according to the club "rules"... has to be accepted.
Re: Borgeson Stering Box [Re: 1fastabody] #1519539
10/24/13 09:01 PM
10/24/13 09:01 PM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
Bergman,
Maybe you can chime in on this, Is there any advantage to going to the larger pitman shaft box?
I don't think there is any appreciable different among the 2. It comes down to what you have to start with. If its an A body they have different pitman/idler/centerlink fir each respective box.
Re: Borgeson Stering Box [Re: 1fastabody] #1519540
10/24/13 11:27 PM
10/24/13 11:27 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
Bergman,
the boxes are the same price, but I did notice that if your buying the stock ratio pitman and idler arms, the price for the smaller arms are about double than the ones for the bigger shaft.
Re: Borgeson Stering Box [Re: dangina] #1519541
10/25/13 12:35 AM
10/25/13 12:35 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Bergman,
Yes. The bigger spines are cheaper.
The bigger shaft starts in 1973 and the aftermarket is more likely to carry and have better prices on parts for the newer cars.
Fall Fling 28 October 19, 2024 at Woodley Park, Van Nuys CA
300+ Mopars, 125+ swap, midway, Friday Malibu cruise,
Re: Borgeson Stering Box [Re: autoxcuda] #1519542
10/25/13 04:24 AM
10/25/13 04:24 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
If you have a small shaft Borgeson powersteering box you can use the pitman arm for a manual box on a '73 A-body.
Re: Borgeson Stering Box [Re: 1fastabody] #1519543
11/01/13 02:08 PM
11/01/13 02:08 PM
None
71rm23 Offline
71rm23  Offline
None
Here ya go
7908036-800118DIM.pdf (449 downloads)
Re: Borgeson Stering Box [Re: 71rm23] #1519544
11/01/13 10:01 PM
11/01/13 10:01 PM
dangina Offline
dangina  Offline
Here ya go
the diagram should show where you have to do some clearancing with a die grinder on the box lol
did they ever fix that issue yet?
Re: Borgeson Stering Box [Re: dangina] #1519545
01/22/14 03:22 PM
01/22/14 03:22 PM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
Does this box require cutting the steering column? I'd be interested in going this route but I am hesitant to butcher my column...
Re: Borgeson Stering Box [Re: cjskotni] #1519546
01/22/14 04:40 PM
01/22/14 04:40 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
No it does not, Bergmann above sells everything needed for a bolt in swap.
Mopar to the bone!!!
Re: Borgeson Stering Box [Re: 72Swinger] #1519547
01/22/14 09:19 PM
01/22/14 09:19 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
Here's a photo of the Bergman adapters installed in my A-body. This is with the stock PS pressure line
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Borgeson Stering Box [Re: dickdale] #1519548
01/22/14 09:53 PM
01/22/14 09:53 PM
USA
rftroy Offline
rftroy  Offline
USA
How much lighter is the Borgeson over the factory unit ?
Borgeson weighs 22 pounds... Stock, anyone?
Just weighed the power steering box from my 70 Roadrunner - accurate shipping scale.
With no pitman arm, hoses, or input shaft coupler:
34lb-10.5oz.
Robert
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: Borgeson Stering Box [Re: cjskotni] #1519549
01/22/14 11:34 PM
01/22/14 11:34 PM
dangina Offline
dangina  Offline
You do if u have a manual column
Re: Borgeson Stering Box [Re: goldduster318] #1519550
01/22/14 11:37 PM
01/22/14 11:37 PM
dangina Offline
dangina  Offline
So stock lines now hook up to the box? I thought u needed adapters
Re: Borgeson Stering Box [Re: dangina] #1519551
01/23/14 08:15 AM
01/23/14 08:15 AM
The Netherlands
The Netherlands
I ordered a new hose-kit from Borgeson to replace the older and hardened hoses on the car. The kit comes with hoses AND adapters.
The Borg hose-kit (which I bought) only worked with a saginaw pump. I changed over from a Federal pump to the Saginaw, which I had laying around anyway.
Re: Borgeson Stering Box [Re: BigBlockMopar] #1519552
01/23/14 01:27 PM
01/23/14 01:27 PM
Berwyn, IL
challenger70 Offline
Berwyn, IL
UGHHH! I just got my stage 3 box back from firm feel, and just read the article in Mopar Action about this (I am a lot behind on magazine reading). Is there a appreciable difference between the FF stage 3 and this box? Lets say you had a freshly rebuilt FF box, would you still do this swap? What does a complete swap run?
Re: Borgeson Stering Box [Re: challenger70] #1519553
01/23/14 01:45 PM
01/23/14 01:45 PM
Mopar Mitch Offline
Mopar Mitch  Offline
The lighter weight of the Borgeson box is a great plus... 10 pounds here, there.. especially off the front end, all adds up towards a better handling modified vehicle. IF this were "legal" in the club racing rules for the specific classes that I choose to run, which, unfortunately it's not for my present classes (SCCA E/SP, and others), I'd be most interested I doing this swap.
The only down-side I see with the Borgeson box is that the steering turns lock-to-lock (3.5?) is greater than the T/A fast-ratio box (2.7)... and fastest steering is what's needed E/Specially in pylon autocrossing.
Re: Borgeson Stering Box [Re: challenger70] #1519554
01/23/14 03:45 PM
01/23/14 03:45 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
We run FF 3 with quick ratio on big tracks and really have no issues at all. I can't imagine the difference is substantial enough to lose sleep over.
1968 Pro-Touring Dodge Charger
*2011 Optima Ultimate Street Car Challenge Invitee
http://www.popularhotrodding.com/features/1203phr_1968_dodge_charger/index.html
Re: Borgeson Stering Box [Re: Mopar Mitch] #1519555
01/23/14 04:23 PM
01/23/14 04:23 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Std power steering is 16:1
T/A quick ratio arm makes it 12.7:1
The Borgeson is 14:1 Which is little quicker than splitting the difference.
Re: Borgeson Stering Box [Re: BigBlockMopar] #1519556
01/24/14 01:28 AM
01/24/14 01:28 AM
dangina Offline
dangina  Offline
thanks for the pic, I gotta check the ones I got, I asked boregson for some lines without using adapters that, ones that bolt to the saginaw pump and their box and they sent me a set, put on the front it says for a late mustang? I haven't gotten around to installing it yet..
Re: Borgeson Stering Box [Re: dangina] #1519557
01/24/14 06:10 AM
01/24/14 06:10 AM
The Netherlands
The Netherlands
The description of the hose-kit on Summit ( brg-925102 ) says indeed;
"Connects GM power steering pumps to 1979-97 Mustang rack and pinion."
You need to have a Saginaw steeringpump with this kit with it's fitting on the back of the pump.
The Federal (type) pumps are different and the hosekit ends are angled wrong for these pumps aswell.
