Re: setting cal tracks with mono springs ?
[Re: dennismopar73]
#1519266
10/19/13 08:04 PM
10/19/13 08:04 PM
Posts: 1,532 off the grid
340B5
off the grid
One silly question. You didn't leave the pinion snubber on the diff did you?
Yeah, it's got a smallblock.
[Re: mopar dave]
#1519268
10/19/13 08:18 PM
10/19/13 08:18 PM
Posts: 3,422 Toronto
mshred
Toronto
which D/A's would you recommend? QA1,Strange or Afco.
Never really heard anything good about QA1 and had a friend get royally screwed by them...I like my Strange's, but the customer service was pretty bad and they were VERY rude when I had to get my shocks fixed and re-valved...Afco makes a good shock from what I have heard, with more adjustment then the stranges, but they are 100 bucks more each shock...Or you could pull out your wallet and get Santhuff's.
For the price I like my strange's though
[Re: 340B5]
#1519269
10/19/13 08:29 PM
10/19/13 08:29 PM
Posts: 1,532 crisfield, maryland 21817
82ramIndy493
Pinion snubbers are not needed with CalTracs. CalTracs replace them and are tons better.
[Re: mopar dave]
#1519270
10/19/13 10:00 PM
10/19/13 10:00 PM
Posts: 1,553 baldwinsville new york
a493demon
I have afco d/a and they work nice . and customer service is very good . I talked to eric.
[Re: a493demon]
#1519271
10/20/13 08:17 AM
10/20/13 08:17 AM
Posts: 1,629 pa
572charger
pa
on mine ive got the bars in the lower hole , 1 flat preload on the drives side 3 flats on the pass ranchos on 5 25 yr old 90 /10 on the ft stock suspension 31x16.50 et streets at 12 lbs air it goes 1.36 - 1.38 60s at 3910 lbs with the ft tires 12 - 18 inches in the air runs 9.60s at 139-140 mph but i can't get it to leave on spray yet, it bounces and i loose my 60 ft might try the afco shock on the rear never realy messed whith it since it worked well on motor
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
