Page 2 of 3 1 2 3
Re: 4" Stroke Small block [Re: SCDaytona] #1517978
10/16/13 12:57 AM
10/16/13 12:57 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
my half filled 360 block uses stock main caps with studs and 4" stroke. Chuck at best machine Detroit once told me that block is good to 680hp@7500 rpm.
Re: 4" Stroke Small block [Re: SCDaytona] #1517979
10/16/13 03:50 AM
10/16/13 03:50 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
My Demon has a 1973 360 block with no fill, w/ Program 2-Bolt Center 3 main caps and a 4.100 Crankshaft, 13 to 1 CR, Nicely ported production heads and a fairly mild solid flat tappet cam [Racer Brown STX22]. The car weighs almost 3100lbs and has been 1.260 60ft, 6.09 1/8th at 111mph and 9.68 at 136mph 1/4 mile.
Car has a crank trigger and timing set at 28*. This engine has 1800+ passes and counting. Crank has not been out of block nor have heads been un-bolted from the block since they were torqued on in winter of 2006. Rod bearings and valve springs have been changed twice. Rod bearings only changed when replacing the $800 Stefs aluminum oil pans, [two of them], after smashing them up on unexpected huge wheelies.
I say build what you have and don't kill it with too much timing.
Re: 4" Stroke Small block [Re: qwkmopardan] #1517980
10/16/13 04:56 AM
10/16/13 04:56 AM
Q
Quicktree Offline
Quicktree  Offline
Q
I think this thread is about adding 4 bolt mains to a stock block. maybe some enging builders will give their
Re: 4" Stroke Small block [Re: 440W8 Duster] #1517981
10/16/13 09:33 AM
10/16/13 09:33 AM
Charleston, SC
SCDaytona Offline OP
Charleston, SC
Thanks for all the responses. Some say yes and some say no. I know a couple racers at my track have ran the 3.79 crank for years with good luck with stock blocks, but they are not available any more unless you buy the top end cranks. Our plan was to put the pro gram billet caps on, 1/2 fill, 13-1 compression and roller cam around 650 to 700 lift. My only concern was with the 4" arm, the increased torque made on the block could be an issue long term.
Tom Molnar has that crank available.
Do you have a contact for him? Not sure who he is.
Re: 4" Stroke Small block [Re: SCDaytona] #1517982
10/16/13 10:25 AM
10/16/13 10:25 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
http://www.molnartechnologies.com/molnar-cranks.html
got my crank and rods through Dan (Performance Only) here on the board.
Re: 4" Stroke Small block [Re: Quicktree] #1517983
10/16/13 11:29 AM
10/16/13 11:29 AM
Az
Crizila Offline
Crizila  Offline
Az
This debate is not new. Heard it long before I decided to go the way I did. My machinist and engine builder, Greulich Engine Machine out of Phoenix, Az talked me in to it. Said he has had good success doing it. He also suggested a half fill as part of the package. That, along with the fact that I had a 360 block in stock, tipped the scale for me.
Fastest 300
Re: 4" Stroke Small block [Re: Crizila] #1517984
10/16/13 11:34 AM
10/16/13 11:34 AM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
I'm trying to help a buddy of mine who wants to put together a 4" stroker with a 340 stock block. Plans are to put in 4 bolt mains and 1/2 fill the block. Probably 0.030 over as well. This will be using W2 heads. Is this block going to hold up or not? Trying to keep this on budget and an R block is not in his budget.
I'm doing it. No dyno #'s on the motor, but based on car weight, speed, ET, I'm guessing around 650HP. 360 stock block, 1/2 filled, 4 blt. Milodon caps. Motor in a blown application.
And from what different engine builders have told me that is pretty much the cap on hp on a factory block and it actually live for very long. I am just going off of what I have learned and heard.
Back in the swing of things at Painless again! Great to be back!
Re: 4" Stroke Small block [Re: BJS racing] #1517985
10/16/13 12:26 PM
10/16/13 12:26 PM
Q
Quicktree Offline
Quicktree  Offline
Q
same here, and I don't have the money to test it and find out. if you can't build it right the first time you probably don't have the bucks to di it again.
Re: 4" Stroke Small block [Re: J_BODY] #1517986
10/16/13 01:31 PM
10/16/13 01:31 PM
Charleston, SC
Charleston, SC
Spoke with Molnar this AM and he said the 3.79 cranks are due in Novemeber so we are going that route. Thanks for everyones input here.
Re: 4" Stroke Small block [Re: SCDaytona] #1517987
10/16/13 01:54 PM
10/16/13 01:54 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
just curious to why your going with the 3.79 vs the 4.00 stroke. seems like more cubes the better. what are the benefits of the shorter stroke?
Re: 4" Stroke Small block [Re: mopar dave] #1517988
10/16/13 02:20 PM
10/16/13 02:20 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
A shorter stroke engine it is easier and quicker to go up in the RPM's. Typically with a shorter stroke engine you can turn more RPM than with the longer stroke due to the rotating weight and centrifical forces that are increased as your stroke gets longer.
Re: 4" Stroke Small block [Re: SCDaytona] #1517989
10/16/13 02:28 PM
10/16/13 02:28 PM
ccarson Offline
ccarson  Offline
I have a 70 360 block I bought off a circle track racer it was his spare that he never used, its now .030" over with a half fill, pro-gram 2 bolt caps with ARP studs,the block was completely squared up,sonic tested we could have gone .060"-.070" over, this was the second block we tested first one had bad core shift it was also newer.
4.125" stroke X 4.030" bore= 420" with 59 deg W9 Heads.
Best Machine did all the machine work and assembly, we started out to build a nice mild 4" Stroke street motor and got carried away.
If I was to do this again it would be 48 deg R3 and full on W8 or W9
Re: 4" Stroke Small block [Re: Quicktree] #1517990
10/16/13 03:32 PM
10/16/13 03:32 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
This thread about if you can use a stock block and have success with a 4" crank and w-2 heads.
I have a bunch of high HP engines with stock 340/early 360 blocks, [basicly the same as a 340 casting], in service at this time. I have done them with the 4 bolt caps and my opinion it only adds to the cost of the finished project. Same with roller cams, No more power just a lot more money. In fact a couple times I have removed roller cams from customer engines and installed flat tappet cams and car has gone faster. Roller lifters fail and have ruined many a good bottom end. The only block failures I have experienced were due to other parts failing first.
Re: 4" Stroke Small block [Re: qwkmopardan] #1517991
10/16/13 05:33 PM
10/16/13 05:33 PM
Q
Quicktree Offline
Quicktree  Offline
Q
no roller cams because no horse power gain
Re: 4" Stroke Small block [Re: BJS racing] #1517992
10/16/13 05:57 PM
10/16/13 05:57 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Then why stroke it at all?
Why not shorten up the stroke? I have seen a few cranks under 3 inch stroke for the SB, those motors must have been real fast
BTW A shorter stroke tends to end up with heavier reciprocating parts, ever compare 340 and 360 pistons?
Re: 4" Stroke Small block [Re: HotRodDave] #1517993
10/16/13 06:22 PM
10/16/13 06:22 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
Measure the bore difference and then ask again. Yes the 340 piston is heavier because it is a bigger bore. Go find some 318/340 stock rods and weight them against a 360 stock rod. Then just for kicks weigh them all against a 273 rod. The 360 rod is the heaviest out of them all. 318/340 use the same rods. Why is that? Not trying to start any kind of anyone is wrong kinda deal. Just going with like I said earlier what I know and what I've been told.
Re: 4" Stroke Small block [Re: BJS racing] #1517994
10/16/13 06:33 PM
10/16/13 06:33 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
My 4.125 stroke small block was 1749 grams and revs like a dirt bike.
Makes killer torque without the rpm of the shorter stroke.
With eddy heads making 630 horse and averaging over 500 ft-lbs through the pull is not a bad thing while keeping things alive with a peak around 6500
Re: 4" Stroke Small block [Re: BJS racing] #1517995
10/16/13 06:43 PM
10/16/13 06:43 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I don't know many that put stock rods in a stroker making much steam . I didn't even use them in my 340 build years ago.
Re: 4" Stroke Small block [Re: DJVCuda] #1517996
10/16/13 06:50 PM
10/16/13 06:50 PM
ohio
all spooled up Offline
ohio
that engine is sweet if you have it in a car what does it run
Re: 4" Stroke Small block [Re: justinp61] #1517997
10/16/13 06:56 PM
10/16/13 06:56 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
I was using as a base idea for the arguement. Aftermarket makes the same rod for all three. same weight and what not and he would be correct that the 340 piston would weigh more because it is bigger in bore size.
Page 2 of 3 1 2 3
