My clutch failure from Norwalk #1516951
10/13/13 09:46 PM
10/13/13 09:46 PM
Rittman Ohio
fourgearsavoy Offline OP
Rittman Ohio
First round went great with the car right on the number
Second round I came out of the water and had no clutch pedal, went straight to the floor and stayed like the linkage failed.
Well I finally got it apart and found chunks of the Polycoil springs stuck between the plate and disc.
Anybody ever seen this failure with a Ram disc before?
Gus
64 Plymouth Savoy
Dana 60
Re: My clutch failure from Norwalk [Re: fourgearsavoy] #1516952
10/13/13 09:49 PM
10/13/13 09:49 PM
Rittman Ohio
Rittman Ohio
Pic 2
64 Plymouth Savoy
Dana 60
Re: My clutch failure from Norwalk [Re: fourgearsavoy] #1516953
10/14/13 07:31 AM
10/14/13 07:31 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Gus I havent seen that but I did have one where the material basically fell apart.I had another that looked like it melted and the plate was welded to the disc.Looks like the disc was well worn on yours.Rocky
Chrysler Firepower
Re: My clutch failure from Norwalk [Re: therocks] #1516954
10/14/13 09:08 AM
10/14/13 09:08 AM
Rittman Ohio
Rittman Ohio
Yeah it was about done I have about 90 time slips on it and about 2000 street miles.
I'm gonna change over to CenterforceII plate with a Mcleod dual friction disc for a more street freindly setup.
Gus
64 Plymouth Savoy
Dana 60
Re: My clutch failure from Norwalk [Re: fourgearsavoy] #1516955
10/14/13 09:35 AM
10/14/13 09:35 AM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
Go look at my thread on my clutch. My dad just wiped out his Ram puck disc too. Obviously not the hot street / strip disc!
I got my Mcleod B/B Long / 600 series disc in and drove it over the weekend. I LOVE it. Great feel. Can't wait to break it in and try it with power.
Re: My clutch failure from Norwalk [Re: LAR_414] #1516956
10/14/13 12:08 PM
10/14/13 12:08 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Interesting as many people seems to favor the ram clutches.?
If i need a new one i thought about the ram power grip hd.
Re: My clutch failure from Norwalk [Re: LAR_414] #1516957
10/14/13 12:15 PM
10/14/13 12:15 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I just bought a Ram Powergrip HD, my disc looks absolutely identical to the disc in this picture. I don't like seeing the spring come out, but I guess random failures do happen. Tell Ram about it maybe they'll do something for your next clutch.
Lar 414, I thought those Bronze puck discs were not recommended for street use though, no?
Re: My clutch failure from Norwalk [Re: LAR_414] #1516958
10/14/13 12:31 PM
10/14/13 12:31 PM
LAR_414 Offline
LAR_414  Offline
YEah,,....A lot of stuff isn't recommended for the street, but we all do it anyways! My old disc and PP were used race pieces that I bought as a package for the transmissions. So I threw them in and ran them. I'm ok with the fact that they didn't last long.
I'll tell you this much, I've had a few different things in this car, since I switched to a stick and now it's all McLeod. PP, Disc, TO bearing, and flywheel. I really think that they sell a good quality product. The old RST twin that I took out (23 spline) was like new. Great product.
This disc and PP are currently behind 650 to 700 hp cars, according to the guys at McLeod that I talked to. No issues, no problems. Street cars with a lot of track time. They only rate the disc to 600hp though.
So my estimated 525hp+ or so isn't going to push it too the breaking point.
Re: My clutch failure from Norwalk [Re: GTX MATT] #1516959
10/14/13 12:33 PM
10/14/13 12:33 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
That's not bronze. The 600 series is ceramic on both sides and the 500 series is ceramic on one side and organic on the other. Ive used the 500 on the street for years with the same pressure plate that Lar414 has, no issues. If I had more power I would not hesitate to use the 600 series disc.
Re: My clutch failure from Norwalk [Re: GTX MATT] #1516960
10/14/13 12:40 PM
10/14/13 12:40 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
If so, why does the "disclaimer" state " Expect some chatter with street use"? I put my Ram puck disc in this past April/May. Virtually less than 100 street miles and maybe 30 trips down the track.I used a CFDF pressure plate with the Ram disc. Mine started to slip at the PID race a couple weeks back. I pulled it and it is wiped out. I've since gone back to a tried true system. CFDF is back in and will stay in from now on. The kind of driving/racing that I do, I expect some set backs from time to time. This was one of those "learning curves" that I consider a waste of time and money. Over the many years that I've owned my car, I've tried most every brand of clutch systems out there within my price range. I had wanted to install the DFX disc, but they were on back order at the time and I wanted to get on the road. So I wasted my time and money on the Ram disc. I had tried Hays and Ram in the past with no success. I should have known better. Shame on me.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: My clutch failure from Norwalk [Re: LAR_414] #1516961
10/14/13 12:40 PM
10/14/13 12:40 PM
GomangoCuda Offline
GomangoCuda  Offline
They rate it at 600hp but with what pressure plate? With the plate you have you add weight to the fingers if it slips too much. I'm sure it would be fine at 700hp and beyond.
Re: My clutch failure from Norwalk [Re: GomangoCuda] #1516962
10/14/13 12:41 PM
10/14/13 12:41 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I'm referring to the disc his dad wiped out in the other thread. And yeah Lar, OF COURSE we run stuff that's not recommended for street use on the street but I think the issue with the Bronze is the longevity for sure.
Re: My clutch failure from Norwalk [Re: 68LAR] #1516963
10/14/13 12:47 PM
10/14/13 12:47 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
From Rams website - "6000 Series Metallic
RAM 6000 Series paddle discs are the refined version of the original patented 3 point Rametallic disc. Sintered bronze metallic buttons provide crisp, clean engagement. This aggressive material allows you to use less static pressure in the clutch and achieve comparable holding power. 6000 Series discs tend to engage very aggressively and will cause clutch chatter if used in a street application. All 6000 Series discs use the Poly-coil hub damper spring for increased disc life and unmatched dampening qualities. Use 6000 series discs for bracket racing, severe duty street and strip, light duty truck pulling, and increased holding power in oval track applications requiring a stock type pressure plate."
Touche you are correct, I'll keep my fingers crossed for the PowergripHD I bought, I've heard lots of good things about them as far as holding up to a lot of power without slipping
Re: My clutch failure from Norwalk [Re: LAR_414] #1516964
10/14/13 10:35 PM
10/14/13 10:35 PM
Rittman Ohio
Rittman Ohio
Good to hear it's a smooth release clutch disc because I'm using the same one except for the plate, I'm gonna give the Centerforce II a try since a few other guys on here have had good results with them.
Gus
64 Plymouth Savoy
Dana 60
Re: My clutch failure from Norwalk [Re: fourgearsavoy] #1516965
10/15/13 07:47 AM
10/15/13 07:47 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Gus that looks like the same setup I have in the 65.Been in at least 12 years.Still hooks great and shifts at 6700 with no problems.I did use a Timken bearing though.Once you get used to it you will probally love it.Rocky
Chrysler Firepower
Re: My clutch failure from Norwalk [Re: therocks] #1516966
10/18/13 09:08 PM
10/18/13 09:08 PM
Rittman Ohio
Rittman Ohio
Hey Rocky what bearing are you talking about? I'm changing everything inside the can so I'm interested in only the best stuff I can get.
Gus
64 Plymouth Savoy
Dana 60
Re: My clutch failure from Norwalk [Re: fourgearsavoy] #1516967
10/19/13 12:57 AM
10/19/13 12:57 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
I'm surprised no one is running a paddle style disc.
I ran one the street/road course/drag strip and had no issues. No chatter. Shifting improves with the paddle disc
Poor concentricity of engine to trans will cause chatter.
Re: My clutch failure from Norwalk [Re: ThermoQuad] #1516968
10/19/13 09:58 AM
10/19/13 09:58 AM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
I would assume Gus is on top of the alignment
Give RCB a call in Rochester ...
Not less or more than a mcleod centerforce
Kit..
http://www.rochesterclutch.com/
Probably are Not many that arent made in China anymore .
Re: My clutch failure from Norwalk [Re: sogtx] #1516969
10/19/13 10:41 AM
10/19/13 10:41 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Gus I had the CF bearing in first.It sat for a few years and was growling when I started driving it again.My buddy at AZ found me an old OE style Timken at the wearhouse.Cost me like 15 bucks which was dirt cheap.Its been in at least 8 years now and still works perfect.Rocky
Chrysler Firepower
Re: My clutch failure from Norwalk [Re: therocks] #1516970
10/19/13 11:05 PM
10/19/13 11:05 PM
St. Croix, US Virgin Islands
David_in_St_Croi Offline
Why not a Tim Hyatt Soft Lock slipper clutch? Back when my car ran it was great, wind pressure up for street, wind down for track. The clutch is not why the car is not running, a bad roller lifter coinciding with an off grid house build is the primary culprit there.
https://www.facebook.com/THENEWCDRA
Proud member of the liberal scientific elite
