Re: Edelbrock Victor Max Wedge Heads - OOTB Results
[Re: Cab_Burge]
#1516685
10/16/13 12:06 AM
10/16/13 12:06 AM
Posts: 3,616 Riverside, Ca
G_bob
Riverside, Ca
Here are the numbers Brian reported with my MW Victors: Edelbrock Victor MW heads OOTB vs. IMM valve job: lift int. int. 200 144 148 300 212 222 400 262 276 500 289 310 600 323 331 700 336 338 After Bracket style porting: lift int. ex. .200 158 133 .300 234 184 .400 287 223 .500 326 251 .600 348 270 .700 356 284 Link to the build thread from the way-back machine... 505" MW Victor Build
[Re: Cab_Burge]
#1516686
10/16/13 10:04 PM
10/16/13 10:04 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The Eddy web sites indicates that they CNC the 440 Victor head to make it the M.W.victor head so seeing results for a set opened up by a competent head porter would be good Maybe there is hope for mine
i'll admit, ive only had a couple of different Victor MW heads in my shop......but those heads i had my hands on were definately NOT std port heads with the intake opening CNC'd out to a MW size. i was as surprised as anyone when i saw the first one, since i just assumed thats how they were going to do it, but it was its own MW sized port as cast.
[Re: fast68plymouth]
#1516687
10/16/13 10:07 PM
10/16/13 10:07 PM
Posts: 1,051 The Great White North
RAMM
The standard port Victors and the MaxWedge Victors are dedicated and separate castings. I thought initially they were the same with a relocated pushrod hole and port opening machining--they are not. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
#1516688
10/16/13 11:15 PM
10/16/13 11:15 PM
Posts: 485 Central California
MoParFish
Central California
Howdy Mr Porter, I must say, I'm pretty happy with that cam and your advise. I told you I was shootin for 10.50s. You said "It'll run 10.50s like falling off a log". Pretty much did it on the first shakedown pass off the trailer with no dyno time. Threw it together and went to the track. Should get better next time out. Thanks again!! Mike
#1516689
10/16/13 11:24 PM
10/16/13 11:24 PM
Posts: 43,393 Bend,OR USA
Cab_Burge
I looked at mine yesterday in the late afternoon, thier definetitily cast as Max wedge all the way to the bowls, no CNC work in sight Me thinks the Eddy Tech rep don't speak, have seen or understand Mopar heads at all ![](/ubbthreads/images/graemlins/shruggy.gif)
#1516691
10/16/13 11:47 PM
10/16/13 11:47 PM
MoParFish
Central California
hey Mike......i'm glad its working out as well as expected. its nice when i plan comes together like its supposed to ![](/ubbthreads/images/graemlins/punkrocka.gif)
the engine bay looks nice and clean
Thanks! Here's a pic of car last year with old motor (440w452s) leavin' on a bit of spray. ![](/ubbthreads/images/graemlins/grin.gif)
