Edelbrock Victor Max Wedge Heads - OOTB Results
#1516644
10/13/13 12:51 PM
10/13/13 12:51 PM
Posts: 485 Central California
MoParFish
Central California
Just thought I'd post results of a couple shakedown runs last weekend on new combo using Out-of-the-Box Victor MW heads. Was looking for combo results like this a while back but didn't seem to find a lot on these heads out of the box. I was tempted to do at least a little clean up on 'em with a sanding roll but, wanted to see true ootb results. 440/511 4.25 stroke. Flat tops .010 in the holes. 13-1 Victor MW heads (77949) No port work, no clean up, no surfacing or valve job. Did check valve contact and clearance for pushrods. Chambers ccd right at 70. Solid roller 274/280@.050 .674/.674 lift w/1.6 HS rockers. Super Victor intake & 1050 2 circ. 35 deg timing. Hooker Super Comp 2.125 - race bullets 727 footbrake 8 inch ATI converter Caltracs 4.10 Dana 3800lb with me in it. 10.44@128 1.473 60ft shifting around 7400, I kinda wanna bring it down to 7k or less Still got some things to do but was pretty happy.
Re: Edelbrock Victor Max Wedge Heads - OOTB Results
[Re: MoParFish]
#1516646
10/13/13 01:18 PM
10/13/13 01:18 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I didn't know that was a brand new combo, Nice. Air was about 2000+' da most of the weekend on my weather station, what time was that run?
"Just a Bracket car dressed up like a streetcar"
[Re: Just-a-dart]
#1516648
10/13/13 01:54 PM
10/13/13 01:54 PM
MoParFish
Central California
It was the last hit before eliminations 1:45?. I didn't end up running first round as I was fighting that trans leak and header gasket went. I figured I'd cut my losses and save for next time. Had a fun time. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: gregsdart]
#1516649
10/13/13 02:03 PM
10/13/13 02:03 PM
MoParFish
Central California
Thats a nice start, but I am betting there is much more in it. I did best shifting a 499 with unported 440-1 heads at 6800, my 528 cube motor with those same heads ported flowing 380 with a .775 lift roller (283/296/110)I shift at 7100. I am betting your combo may like 7,000 better than 7400.
Yeah, had the shift lite set at 6900 and saw it come on but was still pullin. Figured I better shift someday. I need to abide by the light but like to defy authority Will try lower rpm shifts next time ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Crizila]
#1516651
10/13/13 02:16 PM
10/13/13 02:16 PM
MoParFish
Central California
What size tire and what rpm were you going through the traps at?
Tires are 29/10.5w-15 and according to the playback tach trapped 6700 on that pass.
[Re: MoParFish]
#1516652
10/13/13 02:33 PM
10/13/13 02:33 PM
Just-a-dart
Glendora Ca.
It looked like you guys were having fun. At 2.15pm my weather was 90.6 f/ 29.37"bp /19.8% hum/ 3099' da. Thought you might want that so you have something to compair to
[Re: Just-a-dart]
#1516653
10/13/13 03:55 PM
10/13/13 03:55 PM
MoParFish
Central California
Thanks Rod, I appreciate the info... Mike
[Re: MoParFish]
#1516654
10/13/13 05:28 PM
10/13/13 05:28 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Are these the new style chamber, or the older style? ( what is the date of manufacter?) Depending on which one it is, you might be surprised at what you are leaving on the table with those OOTB. ![](/ubbthreads/images/graemlins/whistling.gif)
RIP Monte Smith
[Re: CompWedgeEngines]
#1516655
10/13/13 07:48 PM
10/13/13 07:48 PM
MoParFish
Central California
Not sure which ones they are exactly. Purchased new last December. The boxes show "Lot Date" of 10/04/2012. Where is the date code on the head? I hear ya on leaving some on the table, just had to do it so I know plus, I didn't want to get greedy Maybe have something to look forward to later on...Was shooting for mid/low 10s with this combo so in the ballpark...
[Re: 493_DART]
#1516657
10/14/13 12:17 AM
10/14/13 12:17 AM
MoParFish
Central California
Sounds like a MEAN combo ! ![](/ubbthreads/images/graemlins/thumbs.gif)
I think your shift point is WAY too high .
With that cam and big cubes... Try shifting at 6500 . I bet you a cheeseburger it goes at least a tenth faster
Cheeseburger? Just ate & now I'm hungry again Yep, next time out gonna pay attention to the shift light & not my ears.
[Re: MoParFish]
#1516658
10/14/13 12:28 AM
10/14/13 12:28 AM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
give it a try--- my 493 loves to shift at 5800 !
[Re: tboomer]
#1516660
10/14/13 11:22 AM
10/14/13 11:22 AM
Posts: 290 Cincinnati, Ohio
d7cook
Cincinnati, Ohio
70cc's out of the box. I thought they where supposed to be 75cc?
1967 Coronet, 1989 Daytona tube chassis.
Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT.
-Banned for life from V8Buick.com-
[Re: d7cook]
#1516661
10/14/13 12:59 PM
10/14/13 12:59 PM
MoParFish
Central California
I thought so too. I "carefully" filled a few different chambers using a 100cc graduated cylinder, starting with 100cc then subtracting what's left in the cylinder. I'm sure pro head/engine guys use a burette. I imagine I could be a little off...
[Re: MoParFish]
#1516662
10/14/13 01:06 PM
10/14/13 01:06 PM
BradH
1. Your Lot Date is definitely the later production w/ the smaller chamber (advertised 72 cc) and more restrictive ports. 2. Yes, you're leaving a lot on the table by having run them as true OOB heads. Porting, chamber work & valve job are all areas for improvement. Me, I can't run ANYTHING OOB... but my junk's never together to run much, either. ![](/ubbthreads/images/graemlins/whistling.gif)
