Vacuum Pump Question #1515646
10/11/13 07:35 PM
10/11/13 07:35 PM
Alberta, Canada
451Guy Offline OP
451Guy  Offline OP
Alberta, Canada
Hey Guys,
I am thinking about putting a vacuum pump on my 512 race motor. It is currently not set up perfectly for a pump but I will change that on the next freshen. Looking for suggestions with regards to who's to use, how many viens, drive system, Mounting location etc. Any advise would be greatly appreciated.
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank
Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car
Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T
Best ET 11.39 @ 118.11
Re: Vacuum Pump Question [Re: 451Guy] #1515647
10/11/13 07:39 PM
10/11/13 07:39 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Only one I would recommend is the Star Machine Vacuum pump with filter.
Re: Vacuum Pump Question [Re: 451Guy] #1515648
10/11/13 07:56 PM
10/11/13 07:56 PM
Cab_Burge Online work
Cab_Burge  Online Work
I bought a Moroso three vane pump for my next all out race motor, the Moroso 4 vane are supposidly better for a larger C.I. race motor(above 550 C.I.) Stars are good also Stay away from the cheaper ones like Aerospace
Re: Vacuum Pump Question [Re: Cab_Burge] #1515649
10/11/13 11:48 PM
10/11/13 11:48 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
If you research it the GZ pulls as much vacuum as you'll ever need for a fair price. Mounts easily with their kit . Pull from the front of the rocker cover. Pulls very little oil. I might empty 2oz every 10-15 passes.
Doug
Re: Vacuum Pump Question [Re: dvw] #1515650
10/12/13 02:51 PM
10/12/13 02:51 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Doug
I like that hose. You can see oil. Is that in their kit? How much for hose and fittings? Thanks, Don
Re: Vacuum Pump Question [Re: cudadon] #1515651
10/12/13 03:38 PM
10/12/13 03:38 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Doug
It all came with the kit. Or you buy parts separate. Summit carries the fittings also.
http://www.gzmotorsports.com
Doug
Re: Vacuum Pump Question [Re: dvw] #1515652
10/12/13 07:12 PM
10/12/13 07:12 PM
Jamie McGrath Offline
Doug
Doug, it looks real clean and I bet it run's like the scalded cat, but you forgot a valve cover nut on the front.
Re: Vacuum Pump Question [Re: Jamie McGrath] #1515653
10/12/13 08:43 PM
10/12/13 08:43 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Doug
There's one there now. I've checked the lash 6 times in 100 passes. ET is a work in progress. 9.25@146.6, 3340 lbs
Doug
Re: Vacuum Pump Question [Re: dvw] #1515654
10/12/13 08:51 PM
10/12/13 08:51 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
I'll give a shoot up for the GZ pumps. Great pumps for a great price. I used their super pump pro on both our 650ci b1-TS engines. That one might be overkill for your engine but one of their other pumps will do the job!
Star's are great but overkill for what you have and a price you don't want to pay.
Doug
Re: Vacuum Pump Question [Re: dvw] #1515655
11/09/13 01:10 PM
11/09/13 01:10 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
do they offer a mandrel that bolts to an ATI sb mopar damper? i'm going same route as you with v pump.
