Re: ^%$&* Stupid Brake shoe retainers
[Re: RapidRobert]
#1515174
10/11/13 02:18 AM
10/11/13 02:18 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
I thought the round thingy was to unwrap the springs from the top post.
[Re: kentj340]
#1515176
10/11/13 02:31 AM
10/11/13 02:31 AM
Posts: 469 Hawaii
Dodgeballs
Hawaii
Yeah - it didn't seem to work for the retainer. But I did use it for the springs.
[Re: kentj340]
#1515179
10/11/13 02:22 PM
10/11/13 02:22 PM
Posts: 21,454 It's a dry heat
gtx6970
It's a dry heat
It is , it will not work on the hold down springs . Thats what the second tool is for
[Re: Dodgeballs]
#1515180
10/11/13 05:59 PM
10/11/13 05:59 PM
Posts: 1,822 Colorado
denfireguy
Colorado
I have found it easier to use a 1/4 or 9/32 nut driver. Grasp the rear side of the pin with needle nose pliers to hold it perpendicular to the rear plate. Push the retainer onto the pin with the nut driver aligning the slot to clear the end of the pin. Compress the spring completely and turn the pin with the pliers a quarter turn and you are done. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: burdar]
#1515183
10/12/13 03:49 PM
10/12/13 03:49 PM
Posts: 469 Hawaii
Dodgeballs
Hawaii
The first time you use the proper tool, you'll kick yourself for not buying one sooner. It literally takes less than two seconds with the tool.
I've already kicked myself, my trash can, my dog...
