Re: no oil pressure on first start up
[Re: dustpan man]
#151477
11/16/08 06:15 AM
11/16/08 06:15 AM
Posts: 416 Franklin Co. Illinois
runinonmt
Don't just look at the bearings - check them. Brother in law had a 383 with a turned crank and std. size bearings. 20 Psi oil press. Guy that built it never even Plastigaged them. What you assume to be right is what will come back to bite you. Ron
In sixty-five I was seventeen and running up one-o-one
I don't know where I'm running now, I'm just running on
Jackson Browne-Running On Empty
[Re: 72dak]
#151479
11/16/08 02:36 PM
11/16/08 02:36 PM
Posts: 16,480 Canada
CrAzYMoPaRGuY
Canada
Does oil get to the top (rockers)? When the engine was running was there loud lifter noise?
CrAzYMoPaRGuY
[Re: 72dak]
#151482
11/17/08 12:32 AM
11/17/08 12:32 AM
Posts: 2,826 NY usa
540challenger
NY usa
i took the right valve cover off to see what i had at idle and i didnt see any oil flow, the engine never knocks or makes any strange noise at all. i hit the throttle up to about 1000 rpm and oil sprayed everywhere
Might want to double check the pickup you installed. If it was to close to the bottom of the pan that might happens. Assuming it had oilpressure before the tear doing i would think the pick-up might be the problem
[Re: 540challenger]
#151483
11/17/08 11:54 AM
11/17/08 11:54 AM
RapidRobert
If you R&R the pan you might throw another pump in there. It might be as simple as the regulator sticking/sluggish from a little piece of crud. Do let us know what it ends up being. Inquiring minds want to know
