Re: Ever see a 440-1 head like this? [Re: Barnstorm] #1514535
10/10/13 05:35 PM
10/10/13 05:35 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
My bad...Fel-Pro 8519 PT1
that's what i was thinking you meant. that is a stock replacement gasket and should NEVER have been used in that application. at a 14:1 10 year old engine i think you are now the undisputed king of using the 8519 well beyond what it was ever intended to be used for
i popped one at around 11.5:1 and blame myself for using a stock gasket
Re: Ever see a 440-1 head like this? [Re: Barnstorm] #1514536
10/10/13 06:52 PM
10/10/13 06:52 PM
AndyF Offline
AndyF  Offline
$25 head gasket + $500 cylinder head repair > $200 cometic gasket set
Re: Ever see a 440-1 head like this? [Re: AndyF] #1514537
10/10/13 07:28 PM
10/10/13 07:28 PM
Mo.
racerx Offline
racerx  Offline
Mo.
I usually run 35 degrees with the Indy head so 36 should work.
Might be a topic for a different thread but maybe everyone with Indy heads should compare ignition timing. Might be interesting to see what different people are running.
Thats a good ideal it ought to be interesting
Re: Ever see a 440-1 head like this? [Re: racerx] #1514538
10/10/13 07:47 PM
10/10/13 07:47 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
We have 440-1's and only run 32 degrees. An efficient combustion chamber doesn't need a lot of timing.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: Ever see a 440-1 head like this? [Re: AndyF] #1514539
10/10/13 09:29 PM
10/10/13 09:29 PM
Minnesota
Barnstorm Offline OP
Minnesota
What Cometic number would you recommend...I'll pull the other head and replace both.
The little old lady from Pasadena is back!
