Page 6 of 7 1 2 3 4 5 6 7
Re: msd ignition woes [Re: sshemi] #1511278
03/26/14 06:47 PM
03/26/14 06:47 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Hey im the 100th poster of this topic!
Do i win another digital 6 that doesnt work?
Re: msd ignition woes [Re: mickm] #1511279
03/26/14 11:19 PM
03/26/14 11:19 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
oh, and the guy from MSD just told me that i CANNOT run the blaster coil horizontally. it must be run vertically, or there isn't enough oil to cover the windings, and it will heat up and break down.
from the coil instructions from MSD:
It is recommended to mount the PN 8202 and 8223 coils in an upright position. The High Vibration Coil, PN 8222, can be mounted in any position due to its epoxy potting compound.
Been running the same Blaster coil for 20 yrs and has always been horizontal, never had an issue.
Ok
Re: msd ignition woes [Re: mickm] #1511280
03/27/14 02:47 PM
03/27/14 02:47 PM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
Recurve a known good dist.... Get a good MSD Box..
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: msd ignition woes [Re: racerhog] #1511281
03/27/14 03:27 PM
03/27/14 03:27 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Here's a stupid question, and perhaps it's already been answered.....do you have the MSD tester?
Re: msd ignition woes [Re: camastomcat] #1511282
03/27/14 03:59 PM
03/27/14 03:59 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Been reading this post with interest...from my days as a field engineer for a computer maker it perked my interest.
Low resistance of the plug wires shouldn't be a factor, good or bad, assuming the wires are shielded, which most any wires on the market are.
Resistance is defined as r = E over I...e voltage, I is current. You( in a perfect world) want as little drop in voltage and current to where they are used, as possible. The more resistance a given foot of wire has, the more voltage and current it takes to overcome it, thus reducing effectiveness. Look at a plug wire as a drain in a sink. If the drain is perfectly clear, it will dispose of the most water. If it gets clogged up with hair, etc less water will pass through the drain.
Plug wire is the same way, less resistance, more voltage and current get through, more resistance less voltage and current.
That all said, a few ohms difference( the reading of resistance) in a given foot of plug wire isn't going to make a hill of beans difference in performance Its just a sales tool to sell wire..10 ohms or 100 ohms per foot, both are still way overkill. Msd stuff puts out a TON of juice
My guess is the digital box you are using is picking up some kind of unshielded interference.
My first thought would be to put the digital 6 on the fenderwell away from everything and try it. I had a digital 6 in my Duster that replaced a bad 6al box, never a peep out of it..was installed circa 2005-2006, and is still in the car today( I no longer own it)
In short, move the box away from possible interference and try it, I suspect the issue will go away. just my thought..
418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car
1.41 best 60 foot
6.54 @ 105.20
Re: msd ignition woes [Re: camastomcat] #1511283
03/27/14 04:47 PM
03/27/14 04:47 PM
California
mickm Offline OP
mickm  Offline OP
California
didn't know there was a tester? where do i find one?
Re: msd ignition woes [Re: B3422W5] #1511284
03/27/14 04:50 PM
03/27/14 04:50 PM
P
Paul_Fancsali Offline
P
Said this before Take the MSD and walk over to the trash can and dispose. Now get your point dist go buy a pertronix and install and I'll bet problem solved No you won't have a rev limiter but how often do you race the car? I know there are a lot of guy's getting rich because everyone has to have what some one else has in their car and they will go faster WRONG. I stick to pertronix or good old Kettering Points
Re: msd ignition woes [Re: B3422W5] #1511285
03/27/14 04:51 PM
03/27/14 04:51 PM
California
mickm Offline OP
mickm  Offline OP
California
well, our theory is that those low resistance wires are putting out enough RF to disturb the box.
i agree that it is not specifically the box, but something on my car, as i had the same behavior with FireCore's ignition box. but what it is has eluded me so far.
i am going to go through and check the connections at the firewall, will take care of that first. possible that a spotty connection isn't putting out a full signal, confusing things.
but it is very, very interesting to note that the only two things that have made a difference have both been related to resistance in the system: resistor plugs and a higher resistance spark plug wire.
next step is to rig a quick harness and put the box well inside the passenger compartment. as i said, if that doesn't take care of it, i give up, and am going to points.
Re: msd ignition woes [Re: mickm] #1511286
03/27/14 06:11 PM
03/27/14 06:11 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I had a problem with my MSD 2 years ago and brought mine to Gotelli Speed Shop. They had a tester there. Found out my MSD was good. Different problem than yours. I think any speed shop would have a tester.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: msd ignition woes [Re: Paul_Fancsali] #1511287
03/27/14 07:55 PM
03/27/14 07:55 PM
Arizona
Chris'sBarracuda Offline
Arizona
This..^^^^^^^^^
Chris..
Re: msd ignition woes [Re: Chris'sBarracuda] #1511288
03/27/14 10:56 PM
03/27/14 10:56 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I use shielded wire for both my pick-up and coil harness. It has braid around the two wires (which are also twisted) that can be grounded to the box. PM me what lengths you need and I'll send you some.
Doug
Re: msd ignition woes [Re: Chris'sBarracuda] #1511289
03/28/14 01:39 PM
03/28/14 01:39 PM
California
mickm Offline OP
mickm  Offline OP
California
This..^^^^^^^^^
Chris..
chris, not far from that, and probably would have done it a while ago except for the fact that the firecore box did the same thing. so it's more something specific to the car than the box.
but if relocating the box to the passenger compartment doesn't work, then that is probably what will happen!
Re: msd ignition woes [Re: mickm] #1511290
05/13/14 03:32 PM
05/13/14 03:32 PM
California
mickm Offline OP
mickm  Offline OP
California
well, just to keep this thread alive. one more test to go. i just made a 10 ft wire harness extension so i can put the MSD box in the passenger compartment as a test. hopefully i'll get to that soon, (most of the time i'd rather drive the car than work on things that don't affect driving it…).
this is it. if this doesn't solve the problem, i'm chucking the entire system and going with something new. haven't figured out what that is yet, but the best that car has ever run was with a 40 year old dual point distributor and an $18 napa coil, so that just may be it.
will post as soon as i have something...
Re: msd ignition woes [Re: mickm] #1511291
05/13/14 03:41 PM
05/13/14 03:41 PM
70sixpkrt Offline
70sixpkrt  Offline
Mick I have mine bolted on the side of the radiator support for the last 10 yrs with no problems. My other buddy has it in the same spot with no problems.
4-speed
3:54 Dana
Re: msd ignition woes [Re: 70sixpkrt] #1511292
05/13/14 04:44 PM
05/13/14 04:44 PM
California
mickm Offline OP
mickm  Offline OP
California
it's one of those bizarre things. the only thing i can say so far is that the box is affected by the RF running around under my hood. i have the box mounted under the battery at the moment. i'm thinking that with my situation, that will still be too close to all of it, but who knows?
i'm going to try the passenger compartment, and if that does it, done. that's where it will go. if not, another type of system is in order.
Re: msd ignition woes [Re: mickm] #1511293
05/13/14 04:46 PM
05/13/14 04:46 PM
an8sec70cuda Offline
mickm...yours is digital, his is not. The digital boxes are very sensitive to RF interference.
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Re: msd ignition woes [Re: an8sec70cuda] #1511294
05/13/14 04:55 PM
05/13/14 04:55 PM
California
mickm Offline OP
mickm  Offline OP
California
yeah, just saw that. good catch.
well, on with the plan! in the passenger compartment it goes!
Re: msd ignition woes [Re: mickm] #1511295
06/19/14 03:48 PM
06/19/14 03:48 PM
California
mickm Offline OP
mickm  Offline OP
California
so about to put an end to all this nonsense.
with the box in the engine compartment and the rev limiter set to 6100, the engine started to miss above 4k and was a mess by 5500 or so. usual, nothing new here.
made an extension and moved the box to the passenger compartment, and no miss at all, but did rev limit at around 5500.
now although i did a simple check on the tach earlier, i don't know that the tach is truly accurate.
so, this weekend i'm moving the box to the engine compartment, and once that is done i'll have a known good auto meter tach temporarily installed to see how accurate my tach is. once i know that, i'll go from there.
damn this has been a long, ugly one… the bad part about it is that through all this i didn't really learn anything in particular, just a long, frustrating haul...
Re: msd ignition woes [Re: mickm] #1511296
06/19/14 06:09 PM
06/19/14 06:09 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Hopefully that will be it. You need closure..:)
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: msd ignition woes [Re: mickm] #1511297
06/19/14 06:24 PM
06/19/14 06:24 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Electrical can be a brain exerciser for sure but you`re gettin stuff done and hopefully you`ll figure it out. I still have the same MSD-6 box and coil from many years ago and always mounted in the car and zero issues.............good luck.
