Re: msd ignition woes
[Re: mickm]
#1511298
06/20/14 04:46 AM
06/20/14 04:46 AM
Posts: 10,308 A Red State
SNK-EYZ
A Red State
Mick, Have you run it on a dyno? I just saw this thread and was wondering if I'm having the same issues. I've got a 6AL2 digital on my car and it's definitely having issues. Rev limiter set at 6500 and it wacks out about 5400. The power curve drops off but it "tries" to recover. I'll have to set the rev limiter higher and see how it does.
[Re: SNK-EYZ]
#1511299
06/20/14 10:01 AM
06/20/14 10:01 AM
Posts: 13,496 Marion, South Carolina [><]
an8sec70cuda
Have you tried disconnecting your tach? I have seen a tach cause all sorts of problems w/ misfiring even though it seemed to be working ok.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: mickm]
#1511300
06/20/14 01:13 PM
06/20/14 01:13 PM
Posts: 3,298 West Coast, USA
jbc426
West Coast, USA
Mick, You have the most amazing series of mysterious problems. I thought I was the only one who goes through this BS.
Best of luck. That car is awesome!
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: an8sec70cuda]
#1511301
06/20/14 01:46 PM
06/20/14 01:46 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I seen that problem on my brothers chevy... when I finally took off the tack lead it straightened right out
[Re: an8sec70cuda]
#1511302
06/20/14 04:24 PM
06/20/14 04:24 PM
Posts: 4,179 California
mickm
California
yes, have tried this. didn't make any difference. even put a disconnect down near the box so that the wire if disconnected at the tach, (even though it wasn't conducting), still wasn't acting as some sort of antenna.
[Re: SNK-EYZ]
#1511303
06/20/14 04:29 PM
06/20/14 04:29 PM
mickm
California
the engine was broken in on a dyno, and ran great.
for everything i have tried, (and if you look at the beginning post you will see the list), only 3 things have made a difference:
- resistor plugs - resistance plug wires - moving the box out of the engine compartment.
in the end i know it is still something funky with my setup. yes, the digital boxes have problems, but many, many people run them in or around the engine compartment without problems… or at least problems that they notice.
but i'm done messing with it. i am going to try one more thing though. i want to put the dual point distributor back in and eliminate the box altogether once more and compare how it feels. the time i did that i only took it for a few short runs and it felt fantastic. but now i want to check it again, as with the box in the passenger compartment i want to compare the two.
[Re: jbc426]
#1511304
06/20/14 04:32 PM
06/20/14 04:32 PM
mickm
California
john, don't i know it! to be honest, i'm starting to lose interest. seems like the time i spend trying to diagnose and fix problems is starting to tip the fun scale in the other direction.
[Re: mickm]
#1511306
06/20/14 04:39 PM
06/20/14 04:39 PM
Challenger 1
Cincinnati, Ohio
Been where you are now.
Unless it's a race car, I have found much more fun with my cars using stock parts. I have already gone really fast in my diggers, so for me it's now all about reliability with my muscle cars. Some stock parts perform just fine on the streets and don't keep your car from performing great, like fuel pumps and ignition.
[Re: Challenger 1]
#1511307
06/20/14 07:14 PM
06/20/14 07:14 PM
mickm
California
not having had the experience of really racing, the fun comes from having a car that is fast that can be used on the track as well as the street. nice situation to be able to get the go-fast out of your system on the track to that extent.
i'm starting to move more to your point of view, i must admit...
