Re: msd ignition woes
[Re: mickm]
#1511279
03/27/14 12:19 AM
03/27/14 12:19 AM
Posts: 1,108 Massillon, Ohio
cudatom
Massillon, Ohio
oh, and the guy from MSD just told me that i CANNOT run the blaster coil horizontally. it must be run vertically, or there isn't enough oil to cover the windings, and it will heat up and break down.
from the coil instructions from MSD:
It is recommended to mount the PN 8202 and 8223 coils in an upright position. The High Vibration Coil, PN 8222, can be mounted in any position due to its epoxy potting compound.
Been running the same Blaster coil for 20 yrs and has always been horizontal, never had an issue.
Ok
[Re: camastomcat]
#1511282
03/27/14 04:59 PM
03/27/14 04:59 PM
Posts: 11,733 Portage,michigan
B3422W5
Portage,michigan
Been reading this post with interest...from my days as a field engineer for a computer maker it perked my interest.
Low resistance of the plug wires shouldn't be a factor, good or bad, assuming the wires are shielded, which most any wires on the market are.
Resistance is defined as r = E over I...e voltage, I is current. You( in a perfect world) want as little drop in voltage and current to where they are used, as possible. The more resistance a given foot of wire has, the more voltage and current it takes to overcome it, thus reducing effectiveness. Look at a plug wire as a drain in a sink. If the drain is perfectly clear, it will dispose of the most water. If it gets clogged up with hair, etc less water will pass through the drain. Plug wire is the same way, less resistance, more voltage and current get through, more resistance less voltage and current. That all said, a few ohms difference( the reading of resistance) in a given foot of plug wire isn't going to make a hill of beans difference in performance Its just a sales tool to sell wire..10 ohms or 100 ohms per foot, both are still way overkill. Msd stuff puts out a TON of juice My guess is the digital box you are using is picking up some kind of unshielded interference. My first thought would be to put the digital 6 on the fenderwell away from everything and try it. I had a digital 6 in my Duster that replaced a bad 6al box, never a peep out of it..was installed circa 2005-2006, and is still in the car today( I no longer own it) In short, move the box away from possible interference and try it, I suspect the issue will go away. just my thought..
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
[Re: camastomcat]
#1511283
03/27/14 05:47 PM
03/27/14 05:47 PM
Posts: 4,179 California
mickm
California
Here's a stupid question, and perhaps it's already been answered.....do you have the MSD tester?
didn't know there was a tester? where do i find one?
[Re: B3422W5]
#1511285
03/27/14 05:51 PM
03/27/14 05:51 PM
mickm
California
well, our theory is that those low resistance wires are putting out enough RF to disturb the box.
i agree that it is not specifically the box, but something on my car, as i had the same behavior with FireCore's ignition box. but what it is has eluded me so far.
i am going to go through and check the connections at the firewall, will take care of that first. possible that a spotty connection isn't putting out a full signal, confusing things.
but it is very, very interesting to note that the only two things that have made a difference have both been related to resistance in the system: resistor plugs and a higher resistance spark plug wire.
next step is to rig a quick harness and put the box well inside the passenger compartment. as i said, if that doesn't take care of it, i give up, and am going to points.
[Re: mickm]
#1511286
03/27/14 07:11 PM
03/27/14 07:11 PM
Posts: 3,685 South San Francisco, Ca
70sixpkrt
I had a problem with my MSD 2 years ago and brought mine to Gotelli Speed Shop. They had a tester there. Found out my MSD was good. Different problem than yours. I think any speed shop would have a tester.
[Re: Paul_Fancsali]
#1511287
03/27/14 08:55 PM
03/27/14 08:55 PM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Said this before Take the MSD and walk over to the trash can and dispose.
This..^^^^^^^^^
Chris..
[Re: Chris'sBarracuda]
#1511289
03/28/14 02:39 PM
03/28/14 02:39 PM
mickm
California
This..^^^^^^^^^
Chris..
chris, not far from that, and probably would have done it a while ago except for the fact that the firecore box did the same thing. so it's more something specific to the car than the box.
but if relocating the box to the passenger compartment doesn't work, then that is probably what will happen!
[Re: 70sixpkrt]
#1511292
05/13/14 05:44 PM
05/13/14 05:44 PM
mickm
California
Mick I have mine bolted on the side of the radiator support for the last 10 yrs with no problems. My other buddy has it in the same spot with no problems.
it's one of those bizarre things. the only thing i can say so far is that the box is affected by the RF running around under my hood. i have the box mounted under the battery at the moment. i'm thinking that with my situation, that will still be too close to all of it, but who knows?
i'm going to try the passenger compartment, and if that does it, done. that's where it will go. if not, another type of system is in order.
[Re: mickm]
#1511293
05/13/14 05:46 PM
05/13/14 05:46 PM
Posts: 13,417 Marion, South Carolina [><]
an8sec70cuda
mickm...yours is digital, his is not. The digital boxes are very sensitive to RF interference.
[Re: an8sec70cuda]
#1511294
05/13/14 05:55 PM
05/13/14 05:55 PM
mickm
California
yeah, just saw that. good catch.
well, on with the plan! in the passenger compartment it goes!
[Re: mickm]
#1511295
06/19/14 04:48 PM
06/19/14 04:48 PM
mickm
California
so about to put an end to all this nonsense.
with the box in the engine compartment and the rev limiter set to 6100, the engine started to miss above 4k and was a mess by 5500 or so. usual, nothing new here.
made an extension and moved the box to the passenger compartment, and no miss at all, but did rev limit at around 5500.
now although i did a simple check on the tach earlier, i don't know that the tach is truly accurate.
so, this weekend i'm moving the box to the engine compartment, and once that is done i'll have a known good auto meter tach temporarily installed to see how accurate my tach is. once i know that, i'll go from there.
damn this has been a long, ugly one… the bad part about it is that through all this i didn't really learn anything in particular, just a long, frustrating haul...
[Re: mickm]
#1511296
06/19/14 07:09 PM
06/19/14 07:09 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
Hopefully that will be it. You need closure..:)
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: mickm]
#1511297
06/19/14 07:24 PM
06/19/14 07:24 PM
Thumperdart
State of confusion
Electrical can be a brain exerciser for sure but you`re gettin stuff done and hopefully you`ll figure it out. I still have the same MSD-6 box and coil from many years ago and always mounted in the car and zero issues.............good luck.
