Re: msd ignition woes
[Re: MR_P_BODY]
#1511219
11/29/13 08:48 PM
11/29/13 08:48 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
There are many having ignition issues with the digital ignition boxes and from what I'm hearing they are caused from bad ground and the solution is pretty simple run a wire from the back of one head to the other and them to the negative side of the coil. This grounds the ignition system and Is fixing most of the issues people are having with the digital boxes.
Another thing I'm hearing is that you shouldn't ground anything to the roll cage, I know that doesn't make sense but it goes not ground properly especially in non-chassis cars. Run a ground wire from the battery and don't rely on the cage.
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
[Re: mickm]
#1511220
11/29/13 09:39 PM
11/29/13 09:39 PM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
It must be the digital version. Ive used 6AL analog boxes for years in 4 different cars. The only time I ever had a problem it was me not the box! I had the pick up wire backwards one time and the other time it was the distributor. If MSD has sent you 4 bad boxes perhaps its not the box that is your problem. Hope you get it worked out.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
[Re: GTX MATT]
#1511221
11/30/13 03:54 AM
11/30/13 03:54 AM
Posts: 4,179 California
mickm
California
Nope, not with the resistor plugs. You will have the same issue.
you mean without the resistor plugs?
i have some, i will give it a try...
[Re: mickm]
#1511224
11/30/13 09:39 AM
11/30/13 09:39 AM
Posts: 21,123 Niles , Ohio
therocks
Niles , Ohio
That rotor looks like crap.Looks like its burning and corroded.Id change it for the cost.GM had a big problem with the HEI setups.They would burn thru the rotor.The high voltages made them go bad.I replaced a ton at work.Rocky
Chrysler Firepower
[Re: therocks]
#1511225
11/30/13 09:47 AM
11/30/13 09:47 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Yeah.. if they look like that, usually the carbon ball in the cap is gone
[Re: MR_P_BODY]
#1511226
11/30/13 02:14 PM
11/30/13 02:14 PM
mickm
California
so where do i get a decent cap and rotor these days?
[Re: mickm]
#1511227
11/30/13 02:51 PM
11/30/13 02:51 PM
MR_P_BODY
I use either the MP cap or MSD(I have 2 different dist).... try a Firecore cap and rotor... Rich makes some nice stuff.. my next small cap will be his
[Re: GTX MATT]
#1511228
12/15/13 09:26 PM
12/15/13 09:26 PM
mickm
California
so, the latest.
i have a new box from MSD, and put it in with it set at 6300, and the same behavior. would not go about about 5700 or so. note this isn't the rev limit behavior, in that the rpm fluctuates a few hundred rpm, and it is missing badly.
moved the rev limit up to about 7300 or so, and it would go beyond 6k, just as before.
so i put resistor plugs in, (hats off to GTX MATT), and the missing was gone. it now stops normally at the rev limit, except that the limit seems to be 1000 rpm off. i had it set at 6300, and it was rev limiting at about 52-5300. upped the limit to 6500, and it climbed a bit, then 6800, and it climbed some more. set the rev limit at 7100, and it now seems to limit at 6100 on the tach consistently.
a while back i tested my tach against a sun tach/timing light, and my tach showed 2 or 300 lower than the sun tach, (i forget which), so i'm relatively sure that these numbers are close.
so. now it seems to run, but do i trust that the box will always hold the rev limit down at that limit, or will it let loose some time and let the engine spin to 7000+?
the resistor plugs seems to have solved the issue of it missing, but now i have the rev limiter issue.
i really don't know what else to do except leave it as it is or get the 6ALN box as i was advised to by the guy i talked to (see earlier post in this thread).
ideas, comments?
[Re: mickm]
#1511229
12/15/13 10:30 PM
12/15/13 10:30 PM
Posts: 701 Northern California
lilcuda
Northern California
I'm coming to the party a little late, but I'll give you my input. I have a friend who is an electrical engineer. He worked for Dynatek ignition about 20 years ago. They started out just doing drag bike ignitions, but have since branched out. Anyway, their major competition was MSD. He told me that MSD rev limiters were very "rough"for lack of a better term. The RPM would vary on the limiter by 500 or more RPM. The Dynatek stuff would be more like 100 or so RPM on the limiter. He made me a one-off limiter for my Barracuda since they didn't make one for V8s back then. They do now. Check it out here: http://www.dynaonline.com/skins/products/accessories/Dyna_RPM_Limiters/When it kicks in, it is very smooth and the car just falls on its face. I would look into one. Lee
'67 is an abbreviation of 1967 67' is an abbreviation of 67 feet They are not interchangeable.
[Re: lilcuda]
#1511230
12/15/13 11:23 PM
12/15/13 11:23 PM
mickm
California
I'm coming to the party a little late, but I'll give you my input. I have a friend who is an electrical engineer...
well, to fill you in quickly, i have had nothing but issues with the box since i got it, and i'm on my 4th box. i contacted someone who rebuilds and fixes MSD boxes (not associated with MSD), and after i got about 1 minute into my situation, he told me to stop everything, there is absolutely nothing wrong with my car, it's the box. the 6AL digital boxes, he said, are known to have these issues with the rev limiters.
i don't feel good trusting my engine to this, so i will probably either get one of these dynatek limiters or go for the 6ALN, which is what this guy recommended.
so far this seems to be limiting the rpm at exactly the same place each time, but i've only done a few trials. so it seems that MSD can get the limiter reasonably close, at least. but it seems there may be some completely off the wall scenario with my car, (which i haven't ruled out), as it's hard to believe that 4 boxes have all been bad, (although the first two were displaying completely different characteristics, and were entirely unusable).
[Re: mickm]
#1511231
12/15/13 11:57 PM
12/15/13 11:57 PM
MR_P_BODY
You may have hurt the rev chips you have been playing with... try some that havent been in the box while its been missing, all they are is a resistor
[Re: MR_P_BODY]
#1511232
12/16/13 01:43 AM
12/16/13 01:43 AM
mickm
California
in the digital 6, the chips are integrated into the box, and are proprietary.
you set the limit by two rotary dials on the outside of the box.
[Re: mickm]
#1511233
12/16/13 01:48 AM
12/16/13 01:48 AM
MR_P_BODY
I forgot you have a digital
[Re: hvyweight]
#1511236
12/16/13 03:03 AM
12/16/13 03:03 AM
mickm
California
i kinda read through the replies. Did you try to remove the tach out of the senario? i have seen tachs cause these issues.
Mike
no, haven't disconnected the tach. someone else brought this up, but this seems like a bit of a conundrum. if i don't have a tach, how do i know where it is cutting out?
it seems, so far, that the resistor plugs may have solved the breaking up issue, but i still have the rev limiter issue.
[Re: mickm]
#1511237
12/16/13 05:01 PM
12/16/13 05:01 PM
Posts: 5,173 CT
GTX MATT
CT
Not sure if you want to go this route, but Summit has the 6AL analog boxes on clearance for 170 (maybe leftover stock). At least your miss is gone though
