made some headway on my 60' #1509866
09/30/13 08:53 AM
09/30/13 08:53 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
went to a different track yesterday(midmichigandragway) and made some improvements on my 60's. only difference to car was a new ICE ignition box & coil. best 60 to date was a 1.51 with the cal-tracs. first 2 back to back passes 1.499,1.468. bars in lower hole. john calvert says aslong as your not spinning going to the upper hole will not improve 60'. I put the bars in the upper hole and 1.456,1.473,1.468. shocks on 7. shock on 9 1.488. so what do ya think? upper hole or lower hole? best of the day was [Email]10.47@128.9[/Email]
Re: made some headway on my 60' [Re: mopar dave] #1509867
09/30/13 10:12 AM
09/30/13 10:12 AM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Make some shock changes on the lower hole then draw a conclusion.
Getting old just means you were smarter than some and luckier than others.
Re: made some headway on my 60' [Re: dannysbee] #1509868
09/30/13 10:40 AM
09/30/13 10:40 AM
Mt Morris Michigan
Mt Morris Michigan
been thru all shock settings with bars in lower hole. 7 worked best.
Re: made some headway on my 60' [Re: mopar dave] #1509869
09/30/13 11:48 AM
09/30/13 11:48 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I dont run Caltracs so I cant tell you whats best but I want to say thats a nice improvement in your 60. My best is a 1.50 on SS springs and 9" tires. Ron
Re: made some headway on my 60' [Re: mopar dave] #1509870
09/30/13 11:55 AM
09/30/13 11:55 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
Nice Dave! I also made improvements on mine as well this weekend, but mine is due to a fresh transmission, 1.47 60', 6.81 1/8.
My Caltracs are still on the lower hole, 1 flat driver side, 2 flats passenger side, shocks on 6.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: made some headway on my 60' [Re: FlyFish] #1509871
09/30/13 12:38 PM
09/30/13 12:38 PM
Mt Morris Michigan
Mt Morris Michigan
i'll post a vid in abit.
Re: made some headway on my 60' [Re: mopar dave] #1509872
09/30/13 01:12 PM
09/30/13 01:12 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
I would log 10 passes in the upper and lower hole at the best shock settings & go with the best average.
Re: made some headway on my 60' [Re: dannysbee] #1509873
09/30/13 01:58 PM
09/30/13 01:58 PM
Mt Morris Michigan
Mt Morris Michigan
the short times improved, but the 1/4 mph and et seem off alittle. best has been 10.39@131 and yesterday was 10.47@128. heres one from yesterday 2nd pass with bars in lower hole.
http://youtu.be/Qz3A7Mm5Gyw
Re: made some headway on my 60' [Re: mopar dave] #1509874
09/30/13 02:20 PM
09/30/13 02:20 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Your mph was down 3mph. Air was probably the hp difference. Et would have been worse if your 60 had not picked up.
Re: made some headway on my 60' [Re: dannysbee] #1509875
09/30/13 11:06 PM
09/30/13 11:06 PM
Mt Morris Michigan
Mt Morris Michigan
yes,from my best time. 129 is very normal. I have a new 4.30 gear to replace my 4.10, but not sure it would improve anything after yesterday. was planning on getting it installed and to the track 1 more time.
Re: made some headway on my 60' [Re: mopar dave] #1509876
10/01/13 08:47 AM
10/01/13 08:47 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
... john calvert says aslong as your not spinning going to the upper hole will not improve 60'.
I'd take that as a generality and tune for what works best for your car. I've never tried the upper hole position on my Challenger, but it's nose-heavy compared to your car and IMO the lower position helps w/ the weight distribution.
Re: made some headway on my 60' [Re: mopar dave] #1509877
10/01/13 10:05 AM
10/01/13 10:05 AM
Mohnton, Pa
DodgeCharger Offline
Mohnton, Pa
I just put Caltrac's on this year I've been to the track twice. My car is launching about like yours.The car starts to pick up the front end then it drops. My best 60' was a 1.46. Best ever was a 1.50 with SS springs. I didn't realize but yesterday going over the car I noticed my shocks were set on 6. I thought they were on 9. I don't know whether to loosen or increase the shock setting. But we both need to get the front up and hold it until we get off the line a few feet. I pitted next to my buddy in his mustang at the last race. He was getting consistent 1.39 60ft times with the front end 3 ft in the air running 10.60 et's.
I think it is all about getting the front end over the center of gravity just like pulling a wheely on a bike. When you do this all the cars weight is on the rear wheels and you will get the best traction.
I was told by someone with extensive testing to leave a .070 air gap on each side of the Caltracs. This has worked good for me but I think the fine tunning is in the shock settings and front end travel. Each time I lowered the front end the front tires pulled higher off the line and the 60ft went down. The only problem now is that I can only lower the front about and inch more. I may have to lower the rear but I really don't want to go that route.
Good luck
Re: made some headway on my 60' [Re: DodgeCharger] #1509878
10/01/13 10:20 AM
10/01/13 10:20 AM
PA
ajcasini Offline
ajcasini  Offline
PA
Guys I fought this 60' battle with my roadrunner last year. Car was 60' 1.44-1.48 wih caltracs and rancho 9way shocks. Car would begin to lift just as some are describing then give a wiggle and set the tires down 10-15' off the line. Was causing et variation on the top end from 10.38-10.45. Changed rear shocks to qa1 double adjustable. First weekend out car was a different animal on the line. 1.37-1.38 60' time et 10.30-10.32. The best improvement was consistency though. 60' stayed glued in thr 1.37-1.38 range thus et was much more consistent. Once you get to a certain power level the rancho/Calvert 9way shocks just aren't up to the task.
This is what worked forme.
Re: made some headway on my 60' [Re: DodgeCharger] #1509879
10/01/13 10:22 AM
10/01/13 10:22 AM
Mohnton, Pa
Mohnton, Pa
At some point you may have the car hooked up but limited by gears and converter. I am considering going to 4.56 gears over the winter. I have 4.10's now. My friend in the mustang is running 4.56 with a 29 inch tire.
Your rear tires look tall. What height are they?
Re: made some headway on my 60' [Re: ajcasini] #1509880
10/01/13 10:25 AM
10/01/13 10:25 AM
Mohnton, Pa
Mohnton, Pa
MY shocks have no compression damping. They only have resistance pulling them apart. That seems really strange. Maybe its possible the tire is rebounding off the track after the initial hit?
Re: made some headway on my 60' [Re: ajcasini] #1509881
10/01/13 10:26 AM
10/01/13 10:26 AM
Mohnton, Pa
Mohnton, Pa
Can you post a link or part number for the shocks your talking about? What do they cost?
Re: made some headway on my 60' [Re: DodgeCharger] #1509882
10/01/13 10:58 AM
10/01/13 10:58 AM
PA
ajcasini Offline
ajcasini  Offline
PA
http://www.jegs.com/webapp/wcs/stores/se...mp;pgGrp=search
They are expensive but one of the best investments I've made.
I am running 4.56 gear with 30x9 tire.
Re: made some headway on my 60' [Re: ajcasini] #1509883
10/01/13 11:23 AM
10/01/13 11:23 AM
Mohnton, Pa
Mohnton, Pa
Are you pulling the front tires higher or holding them up longer?
Do you have any video of your car leaving the line?
Re: made some headway on my 60' [Re: DodgeCharger] #1509884
10/01/13 01:01 PM
10/01/13 01:01 PM
PA
ajcasini Offline
ajcasini  Offline
PA
I do not have video of the car launching. However it did pull the tires about 18" and carried around 30'. For my car that is impressive given close to 4000lbs with me if the seat. Before was pulling them maybe a foot and carrying not much more than 15'.
Re: made some headway on my 60' [Re: ajcasini] #1509885
10/01/13 01:43 PM
10/01/13 01:43 PM
Mt Morris Michigan
Mt Morris Michigan
what did you end up with for shock settings? sunday I was pulling front tires about 4-5" and carrying them about 12".
