wheel cylinder chaos #1509271
09/28/13 09:13 PM
09/28/13 09:13 PM
Central Ohio
BMChrysler68 Offline OP
Smarter than the average bear? I think not.
Central Ohio
I replaced the driver side front wheel cylinder on my Fury. I'm getting fluid through the flex hose, but when I hook it to the wheel cylinder, nothing. Hard pedal, but no fluid out of the bleeder and it isn't pushing out on the shoes. Did I buy a defective wheel cylinder?
1968 Plymouth Fury III
2dr FT, 383-4v, 4 speed
1972 AMC Ambassador SST wagon
360-4v, automatic
2014 Challenger R/T Classic 6-speed
Re: wheel cylinder chaos [Re: BMChrysler68] #1509272
09/28/13 09:38 PM
09/28/13 09:38 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
sure sounds like it
It's Swifty! Swifty, you toad sucker!
Re: wheel cylinder chaos [Re: BMChrysler68] #1509273
09/29/13 01:18 AM
09/29/13 01:18 AM
Take it out and disaasmble it to see if the aluminum pistons are frozen into the wheel cylinder
Re: wheel cylinder chaos [Re: BMChrysler68] #1509274
09/29/13 03:34 AM
09/29/13 03:34 AM
Take out the bleeder screw & see if it's plugged up
Re: wheel cylinder chaos [Re: RapidRobert] #1509275
09/29/13 10:21 AM
09/29/13 10:21 AM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
If it is pushing the shoes out the pistons are moving. Sounds like a bad/plugged bleed screw.
383, Hemi 4-Speed, AlterKtion, D60
Re: wheel cylinder chaos [Re: BMChrysler68] #1509276
09/29/13 11:33 AM
09/29/13 11:33 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
IS NOT
As in the shoes are NOT being pushed out.
Don't be the exception.
Re: wheel cylinder chaos [Re: BMChrysler68] #1509277
09/29/13 12:18 PM
09/29/13 12:18 PM
With the bleeder screw/hose inlet in the center of the barrel & the pistons in the ends even if the pistons were stuck (not likely with a new cyl) you'd still get fluid out of the bleeder screw (like when you gravity bleed) unless the bleeder screw is plugged (no fluid coming out) but there's no shoe movement either & neither of them is likely to have happened & both happening together is extremely unlikely. Now I see the chaos! Are you SURE the hose ain't plugged & that you ARE getting pressure AT the cyl?
Re: wheel cylinder chaos [Re: RapidRobert] #1509278
09/29/13 01:28 PM
09/29/13 01:28 PM
Fox River Grove, IL
HotRodRailroader Offline
Fox River Grove, IL
Remove the hose and have someone gently push the pedal and see if you actually have pressure or if what is coming out is leftovers. If you do have pressure time to check the WC out. You should be able to press the WC pistons in and if they are stuck they should pop and release. I've seen this a few times. If they move by hand and still no fluid you have a blockage inside. Try putting a tooth pic into the bleeder and clean it out. same with inside the WC where the bleeder goes. if no luck just exchange it for a new one. I would recommend replacing the hose anyways to prevent any contamination in the new WC. Good Luck
