Long story short, I recently picked up a Procomp BB head to use for what I'm referring to as my "crash test dummy" porting R&D head. I tried to locate a single 75 cc Victor like my last set to do the same thing, but Jesse Robinson (RAMM) and I swapped some PMs and he confirmed that I could use a Procomp "clone" for the same purpose.
Before I purchased the head directly from Procomp in SoCal, I contacted Brian (ou812) at IMM about doing a good valve job on the head before I bothered to mess with it. Since his shop is only about an hour's drive from Procomp, I had them ship it directly to IMM, and he sent it to me once the work was done, along w/ a couple of Edelbrock valves as used w/ Victor heads.
To be blunt, other than the valve job, the Procomp head has enough fairly "ugly" things about it that I skipped even bothering to do a "before" flow test and grabbed the Makita. However, after having some questions re: the results, I picked the best looking (minimal casting flash, best short turn, etc.) of the clone's remaining three unported intake runners and picked the #3/6 for an “out-of-the-box plus a good valve job” test. That's shown in column A. This is the best I can do at this point to provide a “before” test.
Column B is the results from the first round of what I referred to as “basic prep” on #5/4 based on what looked to need work. This consisted of trimming down some big “humps” in the as-cast walls, cleaning up (but not reprofiling) the SSR, blending the valve job into the bowl, narrowing the guide, working the transition from the seat insert into the SSR, blending the CNC'd port opening, and touching up the chamber where the valve job had a stepped transition into it.
Column C is the results from doing some additional work to #5/4, such as widening the short turn, opening the wall near the plug more, and opening the bowl deeper on the exhaust-side of the port. Also, until now everything was primarily a cuttered finish, but I hit the reworked SSR w/ a 60-grit flapper and cleaned up the bowl w/ a 60-grit roll. No actual runner enlargement over the original design size was ever done.
Column D is the improvement between A and C, FWIW.
Lift ------ A ----- B ------ C ----- D
.050 --- 33.8 --- 31.6 --- 32.0 --- (1.8 )
.100 --- 67.6 --- 65.9 --- 66.7 --- (.9)
.200 -- 136.7-- 139.7 -- 141.6 --- 4.9
.300 -- 192.6 -- 202.4 -- 206.6 -- 14.0
.400 -- 245.2 -- 259.5 -- 264.3 -- 19.1
.450 -- 265.8 -- 281.8 -- 287.1 -- 21.3
.500 -- 287.1 -- 302.2 -- 303.9 -- 16.8
.550 -- 293.8 -- 317.0 -- 318.7 -- 24.9
.600 -- 304.5 -- 325.8 -- 325.8 -- 21.3
.650 -- 313.4 -- 333.1 -- 331.2 -- 17.8
.700 -- 315.2 -- 338.8 -- 337.0 -- 21.8
Something in the latest changes have begun to trade off .300-.500" improvements for small decreases above .600".
Despite having a 2.20" intake valve, the intake opening is only about 2.25" x 1.20" (standard BBM, not Max Wedge) which is more in line with a common small-block Chevy runner opening.
BTW, I have no intention of running Procomp heads and this purchase was strictly to give me a casting I could try and prototype some Edelbrock Victor standard-size ports of my own.
![](/ubbthreads/images/graemlins/wave.gif)
