Re: Procomp BB head flow test
[Re: RAMM]
#1508118
10/03/13 06:02 PM
10/03/13 06:02 PM
BradH
Increasing intake width is very important with these. Stock narrow port window cause very abrupt width increase at short side leading to turbulence and stalling at the .650" and up. These things need to go Max Wedge-. All of this still won't fix the poor low/midlift numbers though. J.Rob
I probably shouldn't admit this here , but I've been looking at a bunch of SBC LS7 head stuff (Hmmm... possibly comparable port volume, same size 2.20" intake valve, good flow #s w/ standard CNC job and shows improvements w/ additional work ), and reading old stuff on SpeedTalk posted by some people like Darin Morgan, and it's given me some ideas.
1. Darin Morgain stated "Some mistakenly believe that if turbulence occurs after peak valve lift that its of no consequence. Nothing could be further from the truth! I have taken heads that went turbulent or flat out went backwards (which is the case for the LS3 and LS7 heads) after .650 lift and decreased low lift flow in order to make it keep going smoothly up to 1". The end result was more power every time and no loss in low end TQ. The head must be smooth all the way up past peak lift."
Well, those CNC'd heads I have definitely flatten out above .650-.700"; when Dwayne had 'em on his bench they actually started to back up above .650". On the other hand, I haven't bothered to test my "clone" head above .700", but so far the modified port seems to be pretty smooth all the way up the curve, except for some odd manometer fluctuation down at .200" or .300" (I don't recall exactly where right now). Guess it's time to screw the valve down another .100" and see what's up. ![](/ubbthreads/images/graemlins/scope.gif)
2. Both Jesse & Brian commented on the standard BBM port opening size being an issue, either as an outright flow restriction or acting as a choke point that causes the air to do "bad things" when it squeezes past that point and then has to slow down again over the SSR.
I'm not interested in hacking the opening to a full MW size simply because of the lack of an intake I believe is suitable for my combination that is that big. However, I'm looking into what the high x wide constraints are for something that starts out as a standard-port intake and considering going "a bit" wider and "a bit more" taller at the entrance and raising the roof a correspoding amount until it gets to the guide boss, tapering it down into the bowl.
Hughes' 2.40" x 1.30" "standard 440" port may be about the limit, but I'm curious if 2.35" x 1.35" would be better considering it was the extra height that required welding my RB M1 4150 intake's roof on the bank w/ the most core shift. That would still require a lot of to go that big on a standard-port intake... been there & done that w/ the Frankenstein M1.
I know some heads seem to respond really well going from standard to MW (Indy SR & EZ come to mind) and am curious how the Victor "clone" responds to a change in that direction. Funny that Edelbrock doesn't show any difference between their advertised flow #s for their standard Victor and MW Victor to give me an idea of what might happen, though.
[Re: BradH]
#1508119
10/03/13 06:18 PM
10/03/13 06:18 PM
Posts: 20,204 PA.
pittsburghracer
"Little"John
"Little"John
PA.
1. Darin Morgain stated "Some mistakenly believe that if turbulence occurs after peak valve lift that its of no consequence. Nothing could be further from the truth! I have taken heads that went turbulent or flat out went backwards (which is the case for the LS3 and LS7 heads) after .650 lift and decreased low lift flow in order to make it keep going smoothly up to 1". The end result was more power every time and no loss in low end TQ. The head must be smooth all the way up past peak lift." And that my Friend is why I went digital on my flowbench. I can pick up turbulence way before you can with fluid manometers. my son can be 36 feet away and working on his car and hear a head going bad. This is also why lots of guys are testing heads at 40 inches of depression or more at times. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: BradH]
#1508120
10/03/13 08:13 PM
10/03/13 08:13 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
I probably shouldn't admit this here ![](/ubbthreads/images/graemlins/whistling.gif) , but I've been looking at a bunch of SBC LS7 head stuff (Hmmm... possibly comparable port volume, same size 2.20" intake valve, good flow #s w/ standard CNC job and shows improvements w/ additional work ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) ), and reading old stuff on SpeedTalk posted by some people like Darin Morgan, and it's given me some ideas. This I believe is how we learn stuff. I personally dont care about make or model. If it works apply it if you can and move on. ![](/ubbthreads/images/graemlins/thumbs.gif) Great post. Matt
[Re: MattW]
#1508121
10/04/13 03:30 AM
10/04/13 03:30 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
How exactly did you widen the short turn? Pics along with these posts would be EXCELLENT!
Brian Hafliger
[Re: Brian Hafliger]
#1508122
10/04/13 09:26 AM
10/04/13 09:26 AM
BradH
My work on the short turn was trying to make the transition from the corners into the bowl more gradual and "broader", if that makes any sense. I didn't touch the center of the SSR out of concern about lowering it, since I figured it could use all the height possible at this point.
My photographic skills are even more rudimentary than my porting skills , but I'll see if I can take some any that actually show what I'm working on. ![](/ubbthreads/images/graemlins/luck.gif)
[Re: BradH]
#1508123
10/04/13 07:54 PM
10/04/13 07:54 PM
BradH
Good news: I went back into the port, opened up the runner from 2.25 x 1.98 to 2.35 x 1.25; widened the short turn corners, laid back the SSR slightly, opened up the channel between the cylinder wall-side of the guide and blended that area more into the bowl. Bad news: For all the work I did, the improvements were basically a wash... picked up a couple CFM at lower mid lifts, lost a couple of CFM at high lifts, and I confirmed the port starts to back up between .700" and .750" Good news: I took a bunch of pictures. Bad news: None of them are downloaded, and I'm sure a large % of them aren't going to be very good once I can review what I took. Good news: I finally did some probing w/ the J-tipped velocity probe. Bad news: I wasn't able to get very good readings and / or anything that looked "right". Overall: A waste of my time. ![](/ubbthreads/images/graemlins/drumhit.gif)
[Re: BradH]
#1508124
10/10/13 11:42 PM
10/10/13 11:42 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
this info wont be directly applicable to the std port heads, but i think it will give a good idea of what the differences are in flow between the new version heads vs the original ones that had the chamber farther away from the valves.
i had someone send me a MW Victor head they just got so i could flow it, and compare to some tests i have of the earlier version. unfortunately, even this comparison isnt really "apples to apples". the previous test was done in '09 on the version that comes with the valves, and the seats already cut. that head i just flowed as it came right out of the box with the Edelbrock supplied valves. this recent test was on a head that was bought as a "bare head", meaning unfinished guides, no valves, and uncut seats. i honed the guides just enough to get the valves in, then cut the seats how i would normally do for these heads, but that isnt the same type of valve job as how they come when the seats are done at Edelbrock. also, i used some Manley valves that are for an Indy head, so the exact shape of the valve is slightly different. nonetheless, the difference in flow between the two heads, especially in the lower-mid lifts, is more than what i would expect to see by just changing the valves and tweeking the valve seat. the new chambers are tucked in pretty tight around the valves, and there just isnt as much room for the air to exit the port......until you get the valve way off the seat.
so, my reason for posting this is, if the Procomp head is patterned after the original Victor head, then if you got some of the current Victor heads, you are probably not going to see low and mid-lift flow numbers like what you got out of the Procomp head without further reworking of the chamber to unshroud the valves.
anyway.....here is how the two chambers affect the MW heads
A- original Victor MW head, Edelbrock valves and valve job B- latest Victor MW head, Manley valves, PRH valve job, very minor blending in bowl under seat
valve sizes for both tests are 2.25" intake/ 1.81" exhaust. no chamber mods to either head.
intake:
lift-----A/B .100--67.4/62.8 .200-141.3/118.3 .300-212.5/174.9 .400-259.2/228.1 .500-289.9/283.1 .550-306.0/308.5 .600-318.7/331.7 .650-328.3/329.1 .700-336.0/330.9 .750-347.5/338.4 .800-348.3/338.4
exhaust:
lift----A/B .100--52.7/54.1 .200-109.2/99.2 .300-156.7/147.5 .400-191.8/183.5 .500-209.4/207.0 .550-214.5/214.5 .600-218.4/218.2 .650-222.3/220.7 .700-223.1/223.1 .750-224.3/224.3 .800-224.3/224.3
one other thing....and Brian can probably answer this, since i have done very little with Victor heads.....this new head seemed like the intake short turn was shaped differently than how i remembered the original Victor heads as being. this new head had what i would describe as a more "normal" final approach from the floor to the seat. i had recalled the earlier Victors as having the floor start to fall away pretty far away from the seat. it reminded me more of a stage 6 head floor, whereas this head didnt remind of a stage 6 at all.
EDIT: i saw the pics on the other post, and that Procomp head definitely has the early style chamber.
[Re: fast68plymouth]
#1508125
10/11/13 12:18 AM
10/11/13 12:18 AM
BradH
... my reason for posting this is, if the Procomp head is patterned after the original Victor head, then if you got some of the current Victor heads, you are probably not going to see low and mid-lift flow numbers like what you got out of the Procomp head without further reworking of the chamber to unshroud the valves.
Well, the spare set of Victors I have were the last set of the old style a parts warehouse priced at a "blowout" deal on RacingJunk a couple of years ago.
Also, thanks for all the info above. ![](/ubbthreads/images/graemlins/bow.gif)
[Re: BradH]
#1508128
10/24/13 03:58 PM
10/24/13 03:58 PM
BradH
Figured I'd post one last update before putting the Procomp head aside for a while. This has been a side project simply because I wanted to know what I could come up with myself for future reference, especially with my having a completely untouched set of the original Victors on hand. So.... - A, B & C were what I'd posted previously above - D is the result from what I mentioned on 10.4.2013 as “I went back into the port, opened up the runner from 2.25 x 1. 198 to 2.35 x 1.25; widened the short turn corners, laid back the SSR slightly, opened up the channel between the cylinder wall-side of the guide and blended that area more into the bowl.” - E is what I did in response to some feedback here, especially after seeing the high-lift #s start to go the wrong way between B & C and C & D. This work can be summed up as widening and laying back the SSR more, opening up the long-wall side of the entry to 1.30”, cleaning up some “stuff” in the chamber and doing what I expect is the final blending & polishing on this particular runner. Lift ------ A ------ B ------ C ------ D ------ E .050 --- 33.8 --- 31.6 --- 32.0 --- 31.6 --- 31.6 .100 --- 67.6 --- 65.9 --- 66.7 --- 66.3 --- 67.1 .200 -- 136.7 -- 139.7 -- 141.6 -- 142.6 -- 143.6 .300 -- 192.6 -- 202.4 -- 206.6 -- 208.0 -- 209.4 .400 -- 245.2 -- 259.5 -- 264.3 -- 264.3 -- 267.4 .450 -- 265.8 -- 281.8 -- 287.1 -- 287.1 -- 287.1 .500 -- 287.1 -- 302.2 -- 303.9 -- 306.3 -- 309.8 .550 -- 293.8 -- 317.0 -- 318.7 -- 318.7 -- 322.3 .600 -- 304.5 -- 325.8 -- 325.8 -- 327.4 -- 329.4 .650 -- 313.4 -- 333.1 -- 331.2 -- 331.2 -- 335.0 .700 -- 315.2 -- 338.8 -- 337.0 -- 335.0 -- 340.7 .750 ------------------------------------- 331.2 -- 336.9 Looks like I have managed to find “something” in the higher lifts that responded to the additional short-turn work that people on here suggested. Here are the "E" results from above vs. the average of all 8 #s from my Hughes CNC Victors. My work still comes up short in places, but I've found some decent results for the effort. Lift ---- C ------ H .050 --- 32.4 --- 33.3 .100 --- 67.1 --- 71.1 .200 -- 143.6 -- 153.6 .300 -- 209.4 -- 221.6 .400 -- 267.4 -- 273.1 .450 -- 287.1 -- 294.1 .500 -- 309.8 -- 310.2 .550 -- 322.3 -- 322.7 .600 -- 329.4 -- 336.3 .650 -- 335.0 -- 343.0 .700 -- 340.7 -- 346.1 I'm OK bagging this for a bit until I have time to come back in the future to see what I can find starting w/ another runner. Any car-related time I have in the immediate future will be spent working on The MoPig, since everything around here is starting to shut down as the colder weather moves in. TTFN on this topic. ![](/ubbthreads/images/graemlins/wave.gif)
[Re: JohnRR]
#1508130
10/24/13 05:54 PM
10/24/13 05:54 PM
BradH
“I went back into the port, opened up the runner from 2.25 x 1.98 to 2.35 x 1.25;
Is that a typo or did you NARROW the port window ?
Typo; correction made in previous post (but not the original from which I copied that). ![](/ubbthreads/images/graemlins/whistling.gif)
[Re: BradH]
#1508133
10/26/13 12:49 AM
10/26/13 12:49 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
I've been thinking about porting the std. port Victor's I have here from the magazine article...I would like to do a cnc deal, but honestly I think the MW head would be the best to do a cnc program for. If I ever get around to porting these I'll post some pics and info. I'd really like to sell them too. I have TD rockers for them as well. Sorry for pimp'n my shtuff... ![](/ubbthreads/images/graemlins/biggrin.gif)
Brian Hafliger
#2319566
06/11/17 09:43 PM
06/11/17 09:43 PM
Posts: 274 Granbury TX
Prochargedmopar
Granbury TX
After reading this post it seems you can buy these heads for $520 a set bare and ootb almost be equal to the ported sb heads that will cost ya triple that.
Hmmmmmm
"Old" member Registered: Sep 2001 Lost my credentials, I'm Back!! LOL 71 Ply Satellite Procharged 73 Dodge Dart Swinger 73 Ford F-100 390/Sniper efi/back to carb 01 Town and Country Limited 08 Dodge 2500 6.7 5" Deleted 02 Mercedes C230K 19 Camry
[Re: Prochargedmopar]
#2319788
06/12/17 11:33 AM
06/12/17 11:33 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I'm going to make a " generic" post to all this, as well as kind of piggy back to Dwaynes other ProComp post. I dont have time to do much more.sorry.
I have an actual dead nuts comparison, on a car of a ProComp " Victor", vs a Eddy Victor ( hughes CNC) head, on a car, with no other changes. The car is a 68 GTX, 3570# bracket car. Last Fall, the car would run ( 511CI) 9.50-9.60s with the STD port Pro Comps, .650 cam. Same car, year before, same combo, with CNC Victors, same ET's, but with 1-2MPH more, maybe a bit more in killer cold weather. The guy never rejets the car, just runs it as it wants, and dials from there. He is a VERY good bracket racer,former National Summit Champion, so he knows how to get a car downt he track. 511CI, M1 intake, 1050-8896, nothing special at all, 1.5 TD rockers. ( the rocker fitment SUCKS on the ProComps).I know you would all like way more info, but thats what I can provide, just too busy to be pulling all sorts of data out, and have to rely on whats stuck in my little brain for now.
What I can say about the ProComps, is the guides are the biggest issue in my opinion,( seats are fair) and they will wear out VERY quickly ( less than 50 runs even), as they are junk. Some sort of crappy phosphorous bronze. I have done RHS heads fairly recently, same issue, change to maganese bronze, problem solved. The heads work ok for what they are, certainly not anything I would " suggest", but as noted many times over, the cost to get them " right" is just too much. Changing out 16 valve guides, profiling, porting clean up, milling decks, new valve job, the average guy cant pay that bill for a cheap set of heads. Those that can do it themselves, it kind of turns into a mad scientist project, because " they can".Just sharing a real world story.
RIP Monte Smith
[Re: CompWedgeEngines]
#2319842
06/12/17 01:09 PM
06/12/17 01:09 PM
Posts: 2,094 central texas
krautrock
central texas
this brings up a question for me, the castings a few different folks are using that are the "sidewinder" heads, are they replacing the guides or do they have better guides to begin with?
