Re: 88 W100 5.2 TBI troublshooting help [Re: dodgedart67] #1508053
10/05/13 09:36 AM
10/05/13 09:36 AM
scratchnfotraction Offline
yes,i have the one from my 88 truck on the shelf. shoot me your addy and i will send it, you cover the ride for it.
yours does have the 2 plugs correct? look like this?
Re: 88 W100 5.2 TBI troublshooting help [Re: scratchnfotraction] #1508054
10/06/13 10:45 PM
10/06/13 10:45 PM
Alabama
dodgedart67 Offline OP
Alabama
I have not tried another coil, I sent you an email scratchnfotraction
Re: 88 W100 5.2 TBI troublshooting help [Re: dodgedart67] #1508055
10/06/13 11:05 PM
10/06/13 11:05 PM
got it
i will get it on the way for you.
i have a good used coil from the 88 also, I will toss it in there with it.
Re: 88 W100 5.2 TBI troublshooting help [Re: scratchnfotraction] #1508056
10/11/13 01:49 PM
10/11/13 01:49 PM
Alabama
Alabama
Well so far I have replaced the hall effect, ASD relay, coil and computer and it still won't start
Re: 88 W100 5.2 TBI troublshooting help [Re: dodgedart67] #1508057
10/11/13 02:39 PM
10/11/13 02:39 PM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
Start with the basics:
Do you have spark?
Do you have fuel pressure?
Are the injectors firing? You may need to use a timing light to see that.
All connections solid?
Any codes on the computer?
That's where we will be able to get into diagnosing what the problem is.
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Re: 88 W100 5.2 TBI troublshooting help [Re: herkamer] #1508058
10/11/13 03:07 PM
10/11/13 03:07 PM
Alabama
Alabama
fuel pressure is ok, I made it run to check, I have no power at the coil, so the first thing I changed was the ASD relay because mine was busted, then the hall effect, then coil, computer, re did all fuseable links as well
Re: 88 W100 5.2 TBI troublshooting help [Re: dodgedart67] #1508059
10/11/13 03:38 PM
10/11/13 03:38 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Check the ignition switch itself.Its down on the column.Not the key switch.Also check the fuses.My Ram burned up the switch and no start.I had to take the connector apart and redo some ends when I replaced it.Rocky
Chrysler Firepower
Re: 88 W100 5.2 TBI troublshooting help [Re: dodgedart67] #1508060
10/11/13 05:44 PM
10/11/13 05:44 PM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
Send me a PM with your email. I have some troubleshooting pages out of a service manual.
Matt
69 Dart Swinger 340
and even more
Re: 88 W100 5.2 TBI troublshooting help [Re: herkamer] #1508061
10/11/13 07:51 PM
10/11/13 07:51 PM
Alabama
Alabama
pm sent
Re: 88 W100 5.2 TBI troublshooting help [Re: dodgedart67] #1508062
10/12/13 02:58 AM
10/12/13 02:58 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
.....Then I'm going to say that you have an open (corroded) wire in the main harness to the computer. It's not uncommon for battery residue to contaminate the harness...which causes havoc on wiring splices within. I'm willing to bet that there is a 12V feed wire to the computer that is rotten.... (White and red wire)
Start opening the harness near the battery and continue along till you're positive that all is OK.
Re: 88 W100 5.2 TBI troublshooting help [Re: superwrench] #1508063
10/12/13 11:18 AM
10/12/13 11:18 AM
Alabama
Alabama
I have checked some but not all, I did redo all the fuseable links to make sure they were good I know they cause trouble too
Re: 88 W100 5.2 TBI troublshooting help [Re: dodgedart67] #1508064
10/12/13 01:02 PM
10/12/13 01:02 PM
superwrench Offline
superwrench  Offline
Just start peeling back all the tape on the harness....it may be tedious, but at this point you've obviously wasted a lot of time and still gotten nowhere.
You should get a wiring schematic for that model.....You'll see what are the 12V feeds and grounds very quickly. At this point you have obviously lost power, or a major ground.
Re: 88 W100 5.2 TBI troublshooting help [Re: superwrench] #1508065
10/12/13 03:46 PM
10/12/13 03:46 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
superwrench is right on the harness.I had a 2.2 at work that was no start etc.Lost a major ground and would not start or spark the coil.It would crank all day.Ive fixed a lot of splices at work in the last 30 years.Rocky
Chrysler Firepower
Re: 88 W100 5.2 TBI troublshooting help [Re: therocks] #1508066
10/12/13 09:50 PM
10/12/13 09:50 PM
superwrench Offline
superwrench  Offline
Yep....I think I fixed a harness problem in the 91 to 96 Dakotas about every week!!! Same scenario with a rotten splice.....good money maker especially when you were working at the "Electrical" rate...!!! LOL
Re: 88 W100 5.2 TBI troublshooting help [Re: superwrench] #1508067
10/13/13 09:49 AM
10/13/13 09:49 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
SW GMs were famous for the headlight grounds.I dont know how many Cavalars and Sunfires I fixed.Ford was also known for corrosion in their plugs.Here in the rust,salt belt it was common.The green death took its toll on a lot of wiring.Rocky
Chrysler Firepower
Re: 88 W100 5.2 TBI troublshooting help [Re: therocks] #1508068
10/13/13 12:41 PM
10/13/13 12:41 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Good info guys. My son just brought home a $150 no-start 88 V6 Dakota. We'll try try to figure it out today.
Sheldon
Re: 88 W100 5.2 TBI troublshooting help [Re: RUNCHARGER] #1508069
10/13/13 10:01 PM
10/13/13 10:01 PM
Alabama
Alabama
So far I have found one fuseable link that I missed that pulled apart and a couple splices that someone has already soldered but still havent found the problem.
Re: 88 W100 5.2 TBI troublshooting help [Re: dodgedart67] #1508070
10/14/13 03:54 PM
10/14/13 03:54 PM
RUNCHARGER Offline
RUNCHARGER  Offline
We got lucky on ours. The fuel pump ran but would shut off right away, no spark but the computer threw a few unrelated codes (like battery recently disconnected). We figured it had to be the hall effect sensor and it was. He's got a good rustfree V6 Dakota 4X4 for total investment of $155. Hope you get yours figured out.
Sheldon
Re: 88 W100 5.2 TBI troublshooting help [Re: RUNCHARGER] #1508071
10/19/13 04:05 PM
10/19/13 04:05 PM
Alabama
Alabama
Well I have ran down the entire wiring harness and repaired a few questionable spots, everything that can be ohmed has been and is ok now, I have never had this much trouble finding a problem, think I will either sell it, put it in the back building for a while(tired of looking at it for now) or change it over to carb with regular ignition, no computer, I have most everything I need I think, even have a gas tank from an older truck without in tank pump, I appreciate all the input from everyone.
Thanks!!
Re: 88 W100 5.2 TBI troublshooting help [Re: dodgedart67] #1508072
10/19/13 05:20 PM
10/19/13 05:20 PM
superwrench Offline
superwrench  Offline
One thing you said way back in this post was that it "tried" to "catch".....Any chance that the timing chain has jumped or broken??? Have you checked to see if the rotor is in fact turning??? Or that it is not in phase (i.e. the chain has jumped)??
I'm not dead positive but I think the Hall effect gives the signal to the computer to turn on the power to the ASD/coil+ when cranking. If the distributor is not turning..... The ASD will always power the pump and coil up for a second when the key is first turned on. From there the computer needs to see a cranking reference (Hall signal) to start.
