440 6PK MOTOR
#1506048
09/22/13 11:59 PM
09/22/13 11:59 PM
Posts: 136 AZ, USA
moon
AZ, USA
Does the 440 6pk motor with a 6pk harmonic balancer need a weight on the torque convertor?
Re: 440 6PK MOTOR
[Re: 62maxwgn]
#1506056
09/23/13 10:43 AM
09/23/13 10:43 AM
Posts: 4,799 ILL
MLR426
ILL
What?
X2
69 1/2 no, 70/71 yes.
X3
MLR426
Re: 440 6PK MOTOR
[Re: MLR426]
#1506057
09/23/13 11:40 AM
09/23/13 11:40 AM
Posts: 1,319 Ohio
jlatessa
Ohio
Re: 440 6PK MOTOR
[Re: Mr.Yuck]
#1506058
09/23/13 11:41 AM
09/23/13 11:41 AM
Posts: 2,826 NY usa
540challenger
NY usa
I have never seen a steel crank motor use weights on the converter.
And how many unmolested Factory 440-6 have you taken apart??
You got to remember there was not a whole much of these motors out there.
Re: 440 6PK MOTOR
[Re: 540challenger]
#1506059
09/23/13 11:47 AM
09/23/13 11:47 AM
Posts: 1,319 Ohio
jlatessa
Ohio
Took apart 440 HP from a New Yorker (71) steel crank, big rods, eccentric on the harmonic and two weights on the converter!!!
Joe
Re: 440 6PK MOTOR
[Re: jlatessa]
#1506062
09/23/13 12:04 PM
09/23/13 12:04 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
Joe
Yep , starting with 70 the 440HP and 6pk engines were external balance and had weighted dampners AND converters .
Re: 440 6PK MOTOR
[Re: Mr.Yuck]
#1506063
09/23/13 12:34 PM
09/23/13 12:34 PM
Posts: 2,826 NY usa
540challenger
NY usa
hey ya learn something everyday.....
Yes you do, imagine all the guys back in the day who swapped in a 440-6 motor but bolted their old trans in the car. I bet that drove tons of guys nuts.
Re: 440 6PK MOTOR
[Re: Cab_Burge]
#1506065
09/23/13 05:30 PM
09/23/13 05:30 PM
JohnRR
I have, 1970-71 6 pak and 1971 375 HP HP motors You can have them converted to internally balanced and then use a stock type nuetral balanced converter
I had one done , didn't take much to do it .
Re: 440 6PK MOTOR
[Re: JohnRR]
#1506066
09/23/13 05:53 PM
09/23/13 05:53 PM
Posts: 1,319 Ohio
jlatessa
Ohio
If the converter balance is all you are worried about, get a B&M flex plate for neutral converters with an externally balanced engine.
The flex plate has a cut-out on the opposite side to mimic the weights on the stock converter. It is nice and sturdy, unlike the stock flex plate.
Joe
Re: 440 6PK MOTOR
[Re: jlatessa]
#1506067
09/23/13 06:31 PM
09/23/13 06:31 PM
Posts: 43,352 Bend,OR USA
Cab_Burge
Joe
I've heard of a lot of guys having problems with the B&M flexplates, converter bolt alignment and other problems I like and use the stock Mopar brand small (11 inch converter with the bigger 7/16 converter bolts) flex plates, both the SFI spec and stock street hemi non SFI specs, for all my race cars for the last 20+ yrs with no problems or failures I can't say the same for my friends who used the B&M plates on thier motors ![](/ubbthreads/images/graemlins/shruggy.gif)
